Question about Vacuums
Hola HL-2008 Automatic Pet Feeder - Vacuums
Why is the pet hair power brush not spinning?
Amazon.com: Customer Discussions: Shark pet hair & power brush
www.amazon.com/...pet-hair-power-brush/.../1?_...
Amazon.com, Inc.Jun 24, 2012 - I needed the belt and couldn't find one so I used a black heavy ponytail band in its place and it works, I don't know how long it will last, but until I ...
My shark pet hair power brush tool will not spin - Fixya
www.fixya.com/.../t13829250-shark_pet_hair_power_brush_tool_will_n...
Jul 30, 2012 - Posted on Jul 05, 2015.
Sep 21, 2015 | Shark Rocket Professional Self-Propelled...
GET AN XV-21 FROM GOING HAYWIRE IN CORNERS
I suggest you remove power from the unit completely, including disconnecing the batteries. Reconnect and voila!
Feb 23, 2015 | Neato XV-21 Pet & Allergy Automatic Vacuum...
My neato is showing a message :my vision was blocked. please press ok (3000). How do I fix this?
Dust off your drop sensors. Using a cotton swab, clean the two drop
sensor windows on the bottom of your Neato Vacuum. Power cycle the unit, removing the batteries if necessary. You should be good to go.
Sep 26, 2014 | Neato XV-21 Pet & Allergy Automatic Vacuum...
Where can i buy replacement side brushes on line for x500 robot vacuum
Try a site called www.ereplacementparts.com. They carry parts for stuff I never heard of.
Nov 12, 2013 | Neato Robotics Neato XV-21 Pet & Allergy...
How to attach pet tool adapter? Do I disconnect the flex hose (handle end)? If so, how?
Hi Sarah! The flex hose doesn't need to be removed to use the pet tool adapter. Just attach the pet tool to hose and begin vacuuming.
Jul 27, 2013 | Bissell Powergroom Pet Vacuum
The brush is clean and spinning but it isnt picking up anything and just pushing pet hair around.
You mentioned pet hair. Remove the brush cover and check for a plug (possibly pet hair). Sounds as though you have a plug somewhere and it's not allow the suction to pull it through. Also check your filter and clean or replace as necessary. Hint; Never let you container get over half full, it reduces the suction.
Nov 02, 2010 | Bissell 6591 Power Trak Revolution Bagless...
My Bissell Pet Eraser brush only rotating on the bare floor setting, when on the pet setting, it won't rotate. What is the problem? Thanks.
it sounds like something is backwards. the brush should only rotate when using it on carpet, it should never rotate on the bare floors. check the belt for propper installation
Jan 03, 2010 | Bissell Upright Vacuum - The Pet Hair...
My Hoover pet cyclonic is no longer picking up pet hair
You need to replace the belt that drives the beater bar.
Jim
Dec 01, 2009 | Hoover Vacuums
Last time I used my Bissell Pet Hair Remover vacuum it smelled like something was burning and it left a black mark on the carpet. What should I do?
When you smell burning like that it usually indicates that the belt is worn and slipping on the motor shaft. You probably need to change the belt. You can get the belts for your model here:
Bissell Pet Hair Eraser Belts
Nov 11, 2009 | Bissell Upright Vacuum - The Pet Hair...
Vacuums Logo
231 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
