Question about Berg FURNITURE Wave
BERG FURNITURE CONVERSION INSTRUCTIONS FOR TODDLER BED TO FULL SIZE BED
I have a europa baby chatham lifestyle crib. color is tea stain. date of production is May 18, 2006. I am looking for a conversion kit to convert from the crib to the toddler bed. where can I locate a...
I know its been a while but if you're still looking for the toddler rail or even the full size bed rails call Lajobi (the manufacturer) at 888-266-2848 or email them at info@lajobi.com. I bought this same crib in 2006 at Baby Depot and I ordered the toddler bed rail through them in 2009 for around $60. Now I'm ready for the full size bed rails but the crib has been discontinued. The manufactuer has a compatible bed rail in the same tea stain for $149 plus shipping.
Oct 12, 2010 | Toys
Does the da vinci convertible crib convert to a twin size bed, or does it just go toddler to full?
This Model only goes from Toddler to Full Size with conversion kit.... http://www.milliondollarbaby.com/collections/emily
The Emily Mini Crib goes to Twin bed.
Jul 11, 2010 | DaVinci Emily Crib
Delta soho 5 in 1 crib where can I get the conversion kit for the toddler bed and where can I get the rails for the full size bed
You can find Delta soho 5 in 1 crib conversion kit on amazon. Click here Amazon com Delta rails and take a look. I hope this was helpful. cheers
Jun 29, 2010 | Delta Soho Crib
Missing conversion kit
I ran into a similar problem but found this out from a website when I ran a search:
The Sorelle Full Size Bed Rails (Sorelle Adult Rails / Full Size Bed Rails)
are designed to work with the following Sorelle Cribs: Madison, Tamcrest, Caroline, Vicki, Cottage, Chantelle, 9000 series, Turnberry, Anne's Lace, Manhattan, or Vista. When your child is ready to make the move from a toddler bed to a full-size bed with a headboard and footboard, you'll need these rails to make the conversion. Like all Sorelle furniture, the rails are eco-friendly, too. Each product by Sorelle is manufactured with water-based paints and odorless glue. And, Sorelle also participates in a reforestation program.
  • Dimensions: 59" X 31" X 51"
TabbedUI.prototype.initialize();
Mar 02, 2010 | Sorelle Vicki
Converting crib to toddler bed
It should have come with the toddler rail when you purchased the crib.  Simply remove a few screws and take the front of the crib off (what would be the footboard).  Then simply slide the toddler rail in the tracks.
A purchase of adult rails is required to make the conversion to a full size bed for the next step.
What color is the crib?  Call at 770-974-8895 if we can help with your toddler rail.
Sep 10, 2009 | DaVinci Emily Crib
Simplicity 4-in-1 sleep system: need to convert to full size bed
Request conversion instructions from Simplicity. This is important from a safety standpoint.
Aug 12, 2017 | Simplicity for Children Ellis 4 in 1 Sleep...
Convert to toddler bed
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here:
http://www.pali-design.com/index.php?path=customer_services&template=faq&section=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed
To convert a crib into a toddler bed you must loosen the two front gold bolts left and right side of the crib and remove the dropside (the front gate that goes up and down). After removing the dropside be very careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail)
To install a streight (toddler) rail loosen the two front gold bolts left and right side of the crib and remove the dropside, once you have removed the dropside replace with the streight rail. Always be very careful and make sure you tighten back your two gold bolts in the front.
Oct 14, 2007 | Pali Sabrina Crib
Berg FURNITURE Wave Logo
220 people viewed this question
Top Berg Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Berg Baby Gear Expert? Answer questions, earn points and help others
