Question about Sakar iConcepts 69452 Webcam
I went through most of the installation but when I clicked on close it shows installing, to go to the next step but it's just taking along time to go to the next level which is launch control center for kodak webcams button to open the application
HOW TO REMOVE CLOSED APPS IN APPS HISTORY?
Some apps that I delete, always show back up on my iPhone every time I sync it. It gets pretty annoying and I want to manage my apps manually. Follow the steps below!
Step 1: Open up your iTunes 11 and plug your iDevice into your computer.
Step 2: On the top right of your iTunes screen, click on the name of your device.
Step 3: Go to the "Apps" tab and scroll down until you see "Automatically Install New Apps", make sure that it is unchecked.
Step 4: If there are any apps that you don't want to show up on your iDevice, click on the "Remove" button right next to them. The button will change to "Will Remove", which means that the app will be removed from your iDevice the next time you sync it. The same thing goes for the "Install" buttons next to the app. Always sync after you choose every app that you either want to remove or install.
Step 5: Go onto the "Settings" app on your iDevice.
Step 6: Scroll down to "iTunes & App Store" and open it.
Step 7: Scroll down until you see the "Automatic Downloads" category and turn off both of the "Apps" and "Updates" sliders.
Step 8: Sync your iDevice and you should be able to manage your apps manually
Here's hoping that helped!
iPhone 5, iOS 7.0.2, Works on every iPhone and iPod!
Apr 21, 2016 | Cell Phones
Laptop not responsing
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 11, 2013 | Dell Computers & Internet
The application configurations incorrect
Title: Office installation
Step 1: Insert the Microsoft Office 2007 Enterprise CD. If the Setup Wizard does not automatically begin, then click Start > Run > D:\setup.exe
Step 2: Enter the Product Key from the back of the CD jacket. Note: This is a unique code. Please keep in a safe place! Click Continue.
Step 3: Check the box "I accept the terms of this agreement" and click the Continue button.
Step 4: Choose an installation option, Upgrade (removes Office 2003) or Customize (keeps Office 2003 installed and adds Office 2007, allowing you to use them both).
Note: Outlook 2003 will be uninstalled in either option. Outlook will be updated and your user settings and mail will migrate to the new version.
If you click Upgrade, go on to Step 5.
If you click Customize, go on to Step 4a.
Step 4a: Click the radio button for "Keep all previous versions."
Click the Installation Options tab, left-click the first drop down box and click Run all from My Computer
Click Install Now.
Step 5: Installation will begin. It may take 15-30 minutes to finish.
Step 6: Click Close to complete the installation.
Step 7: The first time you launch any Office program, you will be prompted to activate the software. As long as you have an active Internet connection, choose the default option and click Next
Step 8: When the activation finishes, click Close.
May 13, 2011 | Microsoft Office Professional 2007 Full...
When i start install for office 07 it is asking for a folder name that does not exist on my computer something that appears to be a web address so i can't continue what should i do
Hello:
It's not a web address, its a file location. It's asking you where you want to install it, is it not? I haven't done an install of Office2007 in a while but that does sound right to me. Just click Continue or Next.
May 13, 2011 | Microsoft Computers & Internet
How to install microsoft office?
HI, Step 1: Insert the Microsoft Office 2007 Enterprise CD. If the Setup Wizard does not automatically begin, then click Start > Run > D:\setup.exe
Click Continue.
Click Install Now.
Step 7: The first time you launch any Office program, you will be prompted to activate the software. As long as you have an active Internet connection, choose the default option and click Next.
Step 9: Click OK to finish.
I HOPE THIS WILL BE HELPFULL TO YOU .
PLEASE DON'T FORGET TO VOTE ME .
GOODLUCK
Jan 21, 2011 | Microsoft Office Professional 2007 Full...
Suddenly device went to white screen and JUM Error 545 came up, nothing works, will not reset
Here is the procedure to resolve:
Step #1
Before starting make sure that BlackBerry Desktop Software is installed on the computer.
Step#2
Make sure that you have installed updated device software installed in your PC. Check this link to get update device software from carrier OS download site.
Step#3
Users can perform a full or selective backup of the data using the Backup and Restore tool in BlackBerry Desktop Manager by completing the following steps:
  1. Connect the BlackBerry device to the computer running BlackBerry Desktop Manager.
  2. Open BlackBerry Desktop Manager.
  3. Double-click Backup and Restore.
  4. Select Backup to perform a full backup or select Advanced to perform a backup of specific databases.
  5. Choose a location to save the backup file, then click Save.
Step#4
To perform a clean install of the BlackBerry Device Software, perform the following steps:
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click the Application Loader icon.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Click the check boxes next to the names of the applications you want to load, and then click Next.
  6. Click Advanced, and then click the check box beside Erase all currently installed applications.
  7. Click Next.
  8. Click the check box next to Do not automatically backup the application data during the loading process.
  9. Clear the box next to Backup and restore applications installed wirelessly.
  10. Click Next > Finish.
  11. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager
Hope it helped.
Nov 26, 2009 | RIM BlackBerry Pearl 8100
How do I download software back on blackberry
Step #1
Step#2
Step#3
  7. Click Next.
Please rate this if it fixes your issue
Jun 08, 2009 | RIM BlackBerry Storm 9530 Smartphone
Got this Bold two days ago & it started yesterday by shutting down & then re starting but showing "uncought exception : java.lang.nullpointer.exception" about 8 times then it stops. Then theres all...
Technically speaking you should just return the phone and get a new one.
If you are feeling adventurous, you can try upgrading/reinstall the software on the device.
Here is the procedure to upgrade the software.
Step #1
Step#2
Step#3
Step#4
  7. Click Next.
Jun 03, 2009 | RIM BlackBerry Bold 9000 Smartphone
Blackberry endless reboot
Try a firmware update on your blackberry. I do not know which country you are in which service provider you are with so please check carefully when going through step 2.
Check below steps for OS upgrade -
Step #1
Step#2
Step#3
Step#4
  7. Click Next.
  11. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
May 27, 2009 | RIM BlackBerry Curve 8310 Smartphone
No audio in my laptop prisario 700
First u check it in device Manager,whether sound driver is install or not.If sound driver shows yellow mark then sound driver is not installed.I tell the following steps to install sound drivers.
First u install the UAA driver.After installation,u restart laptop.Next u install the Audio drivers.Installing this driver may result in an error. But continue with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse C:\swsetup\****** folder . Select the .inf file, click open and Continue with the onscreen instructions.
If ur laptop have Windows vista operating system then u click on Start - Programs - Recovery Manager- Recovery manager.In that recovery manager,u click on next button.Its shows the software reinstalltion page.There u select the NO and clink on next button.Its shows the Hardware drivers reinstalltion page.U select YES and click on Next button.Its shows the Hardware drivers list.There u select the Audio driver and click on next button.After reinstalltion,u restart laptop and check it.If u get same problem then u take from nearest service center.
Thanks
Feb 28, 2008 | Gateway Solo 5300 Notebook
Sakar iConcepts 69452 Webcam Logo
Top Sakar Computers & Internet Experts
micky dee
Illimar Saatvali
Illimar Saatvali
Are you a Sakar Computer and Internet Expert? Answer questions, earn points and help others
