Question about D-Link DIR-615 Wireless Router
How do i enabled my router? - D-Link DIR-615 Wireless Router
    Sergeant:
    Champion:
  • 217 Answers
Using the ethernet cable, plug in directly in to your computer.
Go to the set up screen (the url will be printed on the unit) and go through the set up procedure.
Once done, you should be able to work from it wirelessly
Posted on Dec 30, 2010
How do I reset my password?
In the below example i'm setting password as cisco for enable mode & Virtual terminals of router
1)Connect to the router and follow the below steps
Router>
Router>enable
Router#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#enable secret cisco
Router(config)#line vty 0 4
Router(config-line)#password cisco
Router(config-line)#login
Router(config-line)#exit
Router#exit
Router con0 is now available
Press RETURN to get started.
Test:
Router>enable
Password: (type cisco to enter into the router privilaged mode)
Router#
Aug 09, 2015 | Computers & Internet
How do enable upnp on belkin router
Since you aren't specific about the model of Belkin router you are using, I can only give you some general advice. This is what is have from MY Belkin router manual. Yours may be different....
Enabling/Disabling UPnP
UPnP (Universal Plug-and-Play) is yet another advanced feature offered by your Belkin Router. It is a technology that offers seamless operation of voice messaging, video messaging, games, and other applications that are UPnP-compliant. Some applications require the Router's firewall to be configured in a specific way to operate properly. This usually requires opening TCP and UDP ports. An application that is UPnP-compliant has the ability to communicate with the Router, basically "telling" the Router which way it needs the firewall configured. The Router ships with the UPnP feature disabled. If you are using any applications that are UPnP-compliant, and wish to take advantage of the UPnP features, you can enable the UPnP feature. Simply select "Enable" in the "UPnP Enabling" section of the "System Settings" page. Click "Apply Changes" to save the change.
Jun 29, 2015 | Belkin Computers & Internet
Wifi is turned off. How do I turn it on?
Stuart,
Some NetGear routers have a wireless button to enable/disable the wireless feature. Look for a wireless LED on the front of the router, if it is off check the back of the router for a wireless button. Press the button for 5 seconds to turn the wireless feature on/off. If that doesn't work you may need to login to the router to enable the wireless feature. Here's a snipet from the NetGear knowledgebase:
1. Type http://192.168.0.1 or http://192.168.1.1 in an Internet browser - some routers use the first URL while others use the second. If one of these does not bring you to the router's login screen, see If You Cannot Log on to Your Router.
2. Enter the user name and password; the defaults are admin and password unless you have changed them. NETGEAR strongly recommends changing the default user name for your network security.
3. Check Wireless Settings > Advanced > Enable Wireless Router Radio. For newer routers with a Genie interface, click on the ADVANCED tab > Advanced Setup > Wireless Settings > Enable Wireless Router Radio.
Note: You will need to uncheck two separate Enable Wireless Router Radio box if your router is dual band. One for the 2.4GHz and one for the 5GHz network.
I hope this helps.
Mar 15, 2014 | NetGear N150 / RANGEMAX 150 Router
How to enable wireless multimedia
Got this from Apple website:
his applies only to third-party routers. Apple AirPort products do not have a setting to enable or disable WMM.
WMM must be enabled for devices to connect. Disabling WMM on your wireless router can prevent the following Apple products from connecting to an 802.11n Wi-Fi network:
  • iPad
  • iPhone
  • iPod touch
  • Apple TV
If you are unable to connect to an 802.11n Wi-Fi network on any of these devices, check to ensure that WMM is enabled and configured correctly on your wireless router. If you require additional assistance, please contact your router manufacturer.
Jan 28, 2012 | D-Link Computers & Internet
Vista attempts to connect with the router "unsecured network"
Hi Friend,
If the security is enabled on your computer then on router the security has to be enabled.
Please follow the steps:
1.Open the router page (192.168.0.1)
2.Enter the username and password
3.ClickWireless settings and fill the section as mention
Name(SSID)-As per your choice
Region-As per your location
Channel-6
Mode-Auto
Security options
WEP
Security Encryption
Authentication-Automatic
Encryption strength-64bit
Security Encryption key
Key1-type a 10 digit password
Click Apply. Turn off the router for 30 seconds and turn it on again.
I hope this will resolve the issue.
Regards
Chiranjeet
May 22, 2010 | NetGear WGT624 Wireless Router
My signal is not security-enabled. I have my MAC
try access 192.168.0.1
thats actually the gateway for d-link router. there's an option there to enable the security of our wireless network.
Apr 01, 2010 | D-Link AirPlus DI-614+ Wireless Router
How do I enable UPnP on this router WRT160N
on WRT160N router UPnP is enabled by default.
You don't need to enable it.
If you want to check the settings of the router then you will need to open the set up page of the router. Router set up page is a page where you can check/change all the settings of the router.
Is there any computer connected to the router. Check the Ip address of the working computer and open the router set up page.
Once you open the router seyt up page, click on Administration Tab. On that page at the bottom you will see UPnP. It must enabled.
Click Here for more information about router and
networking
Feb 04, 2010 | Linksys WRT160N Wireless Router
I need to change my nat type from strict to open
This router does not have the typical "strict or open" NAT types. Looking at the manual, it looks like what you want is NAT enabled and SUA only enabled.
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906173729&ModelIndexflags=0,420041221102511,420041221102520,420050117110858,420050117110916,420050117110934,420050831093216,420050831095441,420060420160946,420060420161739,420060816160116,420080815092146,420090427144843
Page 133 has the details.
Log into router
go to the NAT tab
Enable NAT
Enable SUA only
Apply the change.
Nov 18, 2009 | Zyxel P660HW-D1 Router
Cannot get the drop downs to work to enable security
I used to have the same router but upgraded to the wireless N model. What I didn't like about this router is you could enable security from a button on the router itself. Frankly, either you use security...or not. This on/off feature is for the birds.
I use macaddress filtering and don't like WEP. There were a few times that I accidentally or inadvertently enabled WEP at the router. Not desirable....and it also would lock out many of the administrative features on the intranet page.
I would reset the router. Go to your local router IP at:
http://192.168.1.1/
Feb 21, 2009 | Linksys Wireless-G WRT54G Router
Port fowarding and remote desktop
Port forwarding is not the only thing that you have to enable to access your home network. Firstly do you just want to access your router from the outside? If that is the case enable remote login via the administration tab.
If you want to login to your computer from the outside then you must first enable remote desktop and enable port forwarding on your router.
You enable port forwarding for port 3389 which is the remote desktop port. So start port is 3389 and end port is 3389 after that set a static IP on your computer that you want to access.
You can enable remote desktop by following the directions below at the link '
http://www.microsoft.com/windowsxp/using/mobility/getstarted/enableremote.mspx
After doing this. What you do is go to the status tab of your router. Look at the IP there.
On the remote computer lauch remote desktop and enter that IP then click connect. IT will then ask you for the username and password of the computer behind the router that you want to login to. After that you should be able to get in.
If you need any clarifications regarding this you may message me and id be glad to help.
Oct 06, 2008 | Linksys Wireless-N WRT150N Router
D-Link DIR-615 Wireless Router Logo
14 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
