Question about Wiremold Raceway V700 Surface Metal Raceway Cable raceway
How is it mounted - Wiremold Raceway V700 Surface Metal Raceway Cable raceway
I THINK YOU CAN BUY U SHAPED CLIPS WITH A HOLE IN THE MIDDLE THAT YOU ATTACH TO THE
WALL WITH TOGGLE BOLTS OR SOME OTHER TYPE OF FASTNERS. A 10 FOOT LENGTH SHOULD BE SUPPORTED TW ICE,
HOPE THAT HELPS
FRANK
Posted on Dec 30, 2010
  • fch0013 Dec 30, 2010
    THIS SITE IS HELPFUL.
Iam no mech but is it hard 2 change the motor n transmission mounts in a 96 ford thunderbird 3.8 engine if it is whats the going price 2 do so i dont get taken
It is fairly easy to do if you have a lift, but it is possible to do on the ground with a jack and jack stands. You will need to be able to unbolt both sides of the mount and support the engine with the jack while you replace the mounts. If you download the autozone app to a smart pone or tablet it will give you a repair estimate calculator,
Mar 09, 2018 | Ford Cars & Trucks
Frontmotor mount torque
Rear mount mounting bolts: 43 Ft-lbs
Side engine mount bracket mounting nuts: 40 ft-lbs
Transmission mount bracket mounting bolt/nuts: 40 ft-lbs
*Front mount mounting bolt: 47 ft-lbs*
May 24, 2014 | 2001 Honda Civic
Replace engine mounts are they the same mounts on 2010 front an rear
Hi Anonymous, there is only two motor mounts on rubber mounted engines, one in the bottom front of engine and one at the top. 99% of time is it's the front motor mount that goes bad. The front motor mount is not the same as the top. The rear shocks act as a rear motor mount. Please visit website below:
Harley Touring FXR The Glide Pro Front Motor Mount user objective review
Good luck
Mar 24, 2014 | Harley Davidson Motorcycles
The brake lights that we need 2 fix r on the trunk /hood.( what holds the spoiler if there was 1) looked all over. either cant find or see or get 2 it?
This is right out of the manual. Hope it is what you are looking for. Cobra. :-) Lamp, Rear Hi-Mount Removal
  1. Slide rear hi-mount lamp cover (13A656) away from back window glass (42006) and remove rear hi-mount lamp cover.
  1. Remove one screw retaining rear hi-mount lamp (13A613).
  1. Lift edge of rear hi-mount lamp and pull away from back window glass.
Installation
  1. Follow removal procedure in reverse order.
  1. Slide rear hi-mount lamp cover onto rear hi-mount lamp to engage retainers.
    Hi-Mount Rear Lamp
    Item Part Number Description 1 921 Bulb 2 56929-S2 Screw 3 13A613 Rear Hi-Mount Lamp 4 13A656 Rear Hi-Mount Lamp Cover 5 15A442 Rear Hi-Mount Lamp Wiring
Jun 05, 2010 | 1997 Ford Thunderbird LX
What accessories to use for what?
You would use your windshield mount and suction it to the plastic horse shoe mount as a dash mount, and there is tons of other mounting options that you may wish to look at.
You can find many different TomTom mouting solutions such as vent mount, viser mount, cup holder mount, vehicle specific mount, windshield mount along with dash mount options at www.autonavdirect.com or www.autonav2000.com.
Good Luck
Apr 03, 2010 | Tomtom One XL GPS Receiver
I have an Olevia 332 b11 LCD tv. I want to mount
There should be at least 4 mounting holes (VESA mount), and they should be used.
Dec 17, 2009 | Olevia 332V LCD TV
Need the correct torque specs for 2004 silverado 1500 calipers
  • Tighten the 2 brake caliper mounting bolts to 108 Nm (80 ft. lbs.) . Caliper Mounting Bracket to Knuckle, Front (15 series) 175 Nm (129 ft. lbs.) Caliper Mounting Bracket to Knuckle, Front (25/35 series) 300 Nm (221 ft. lbs.) Brake Caliper Mounting Bolt Rear (15 series) 42 Nm (31 ft. lbs.) Brake Caliper Mounting Bolt Rear (25/35 series) 108 Nm (80 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JC5/JH5) 200 Nm (148 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JH6) 165 Nm (122 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JH7) 300 Nm (221 ft. lbs.) Caliper Mounting Bracket Bolt Rear (NYS) 200 Nm (148 ft. lbs.)
    hope this helps
  • Mar 28, 2009 | 2004 Chevrolet Silverado
    Can thris protron tv be mounted on a wall?
    it can be mounted, they sell a universal hanging kit, you will see 4 holes in the back of the tv, thats where you put the screws for the mount
    Jan 11, 2009 | Protron PLTV-4250 42 in. LCD Television
    Wiremold Raceway V700 Surface Metal Raceway Cable raceway Logo
    204 people viewed this question
    Top Wiremold Computers & Internet Experts
    David Payne
    David Payne
    Are you a Wiremold Computer and Internet Expert? Answer questions, earn points and help others
