Question about Fisher and Paykel Dishwashers
Fisher & Paykel Nautilus Dishwasher Model: 87604920 Problem: Constant beeping while displaying "F4"
  • 351 Answers
SOURCE: fisher & paykel Nautilus dishwasher
pull the dishwasher out and push down on the top of the dishwasher were the door latch is ,its not making conntact with the microswitch.but you could also have a broken handle.these are both common faults on this model.hope this helps.
Posted on Mar 20, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher & Paykel Nautilus Dishwasher
F4 is a fault code telling the controller that the water is not heating up. This can be caused by either a faulty heater plate, a bad connection between the plate and controller, or the controller itself. If you wish to fix this yourself, changing the heater plate is a fairly involved repair and should be done by someone with a high degree of mechanical ability.
Posted on Dec 11, 2008
  • 784 Answers
SOURCE: F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Posted on Jul 03, 2009
  • 69 Answers
SOURCE: F4 error fisher & paykel nautilus dishwasher
F4 is a heating error- dishwasher has not reached temperature in allocated time. If intermittent fault, problem is usually with electronic board, which has temperature sensor attached. Sometimes the wiring to the control board burns out and can give intermittent false readings causing F4 error. Disconnect from power, remove front panel (4 screws down each side). You can now see wiring going to control board- check for burnt wires. Also check temperature sensor (small square with two purple wires) is stuck to inner door panel- if this is not stuck to inner panel, temperature sensor will not work properly. If in any doubt, call in the experts!!
Posted on Mar 09, 2010
  • 3247 Answers
SOURCE: hi ya. we have a fisher and paykel nautilus
This means something wrong with the water heater.
Most likely you will need to replace it. It will look something list this.
Will need a technician to fix it if you are not very comfortable to handle such equipment.
Please rate this solution.
Posted on Sep 03, 2010
Fisher and paykel nautilus dishwasher
Does it fill with water? I would guess a fill/ drain/ heating problem. See if you can eliminate any of those.
Apr 12, 2013 | Fisher and Paykel Dishwashers
I have just moved into a rental with a fisher and paykel nautilus dishwasher. I have turned it on at the switch and it keeps beeping with F1 displayed
F1 display means Flood has occurred. Call the company for more assistance. Here is a link- http://www.fisherpaykel.com.au/admin/pdfs/pdf_usecares/521766I_DW920_ugm_NZw.pdf
Dec 08, 2012 | Dishwashers
Hi ya. we have a fisher and paykel nautilus dishwasher. and it has a fault. f4 is on the panel. and its not draining water. help please
Aug 24, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
May 25, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Dec 09, 2008 | Dishwashers
What is F4 error on fisher paykel dishwasher?
Oct 29, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher & paykel Nautilus dishwasher
Mar 19, 2008 | Dishwashers
Dishwashers Logo
83 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
