Question about Vacuums
How do I change the belt in an upright vacuum?
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=755349
Generic problem for all Vacuums
How do I change the
Posted by budnvic on Jul 08, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Well, I can try to tell you a how to for a generic vacuum, but we really need more information as per the brand name and model # in order to tell you the best way to change the belt on your current vacuum. Most vacuums have a removable bottom plate o which will release by screws, clamps or levers and the bottom plate should come off or the top cover will come off. Then the belt should be exposed. Then cut off the belt, lift up on the brushroll side where the pulley is and place the belt on the pulley, then reinstall the brushroll – now use a belt puller or screwdriver and pull / stretch the belt onto the motor pulley – then track the belt by rolling the belt in a straight line – if the install worked then reinstall the top cover and or the bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 08, 2008
How do I change the belt on the Bissell Proheat
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
vm
Mar 14, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Dyson upright vacuum cleaner makes horrendous noise
It might be a simple as changing the clutch belt and the drive belt and cleaning out the brush roll. You can get replacement belts here:
Dyson DC07 Belts
Dec 08, 2009 | Dyson DC07 All Floors Bagless Upright...
Change belt on 7920
heatman101
cvzncbn
Mar 29, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Eureka Altima Bagless Upright Brush is not spinning
You probably just have a broken belt. The belt needs to be changed about every 6 months regardless. I believe yours takes a style EXT U(Extended life upright), or a regular Eureka "U" belt works fine too.
Nov 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Changing the belt?
Take off the bottom plate covering the brush roll. The belt runs from the brush roll to the motor shaft. Get a new belt, it will strectch to go around both.
Apr 29, 2008 | Hoover U5163-900 Upright Vacuum
How to change the belt on a Hoover High Performance upright vacuum cleaner
Most of the Hoover upright vacuums service from the bottom and to start remove the bottom plate, that should expose the belt – if this is the case, some Hoover’s might be self propelled, if not the self-propelled vacs have 2 belts and the non self propelled models have one belt – so remove the belt(s) and then lift up on the brushroll and slide the belt onto the belt pulley then take a screwdriver tool with a hook on the end and stretch the belt onto the motor shaft – once this has been done the track the belt(s) and it should straighten out and run straight, re-install the bottom plate, plug in and test. If you cannot get @ the belt from the bottom the look for 2 or 3 screws – remove the screws and the top cover will lift off and then follow the procedure mentioned above… Questions? Please feel free to contact your local vacuum dealer in your area or in the yellow pages or contact the Hoover factory for more details.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 22, 2008 | Vacuums
Vacuums Logo
59 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
