Question about Sony KDS-R60XBR2 Television
Tv display black screen afyer replacing lamp - Sony KDS-R60XBR2 Television
  • 57 Answers
Hello my name is rico and i work on tvs sometimes. check your lamp again, and check the lamp cover. make sure that your lamp is lighting, otherwise maybe you have bad light engine. please feel free to call me if need more help with tv . 602-810-7149 i live in mesa az
Posted on Dec 30, 2010
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
Black screen
busted lamp. please increase the volume of the tv even thought there is a black display. if a volume comes up then chances are the ccfl lamp is busted that is why you get black display.
Apr 06, 2012 | Vizio P42HDEA Television
How long do I have after the lamp replacement warning comes up before I have to replace the lamp?
You can use the Lamp even if the TV displays the message to replace the lamp. However, the performance of the TV, i.e the picture may become dark, entire screen may display in black after some time. If you can view the videos normally even after displaying the message, you may continue using it.
Thanks for understanding.
Feb 02, 2011 | Sony KDF-50E2000 50" HDTV
Toshiba-10 yrs old. screen goes to black with sound.
Hello, :)
There is a how, and a why, but first, let's start with the how. Portable TV's have LCD, (Liquid Crystal Display) Screens. But the Screen is merely a vivid illusion created by the rapidly moving electrons flowing through the crystals themselves causing color contrast ratios to shift so fast, hence creating the image.
And now the why: the TV uses a back illumination to light up behind the screen. That is why the screen goes black. Normally in LCD's, there are CCFL, (Cold Cathod Floruscent Lighting), these are tiny lamps that should be replace easily. google replacement model for your TV, and aslo type model # plus ccfl lamp. :)
Apr 02, 2010 | Televison & Video
Green light is on but screen is black
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I heard a pop and screen wet black. red lamp
Lamp inside TV is broken and requires replacement. Pop sound was its breaking sound.
Lamp replacement procedure is written in user manual, pretty easy.
Please buy Sony original lamp for TV safety and avoid aftermarket/ cheap lamp.
Let me know if you need to download user manual copy.
Thanks.
Sep 12, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Black screen- laptop only works with external monitor
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
If your Dell has a S-video output it could connect to a TV or a video device, which allows for a TV option.
Jul 24, 2009 | Dell Computers & Internet
Lamp replacement
Sure, I do by myself. Seat on the floor in front of the TV
!st. step: Grasp both side of the silver front cover with your
fingertips and pull it from projection display.
Then remove it.
2nd. At your left hand you can see a black knob. Turn the
open/lock knob to the left. Pull the black unit that have
the lamp inside. Cover out and down to open.
3rd. Loosen the lamp (black unit) screw with screwdriver.
Grasp the handle of the black unit lamp and slowly
remove the unit.
4th. Insert the new lamp black unit being careful. Tighten the
black unit lamp screw with a screwdriver.
5th. Close the lamp cover. Turn the lock/open knob to the
right.
6th. Replace the silver front cover. Finished.
R. Vega from Puero Rico
Apr 28, 2009 | Panasonic PT-52LCX65 44" HDTV
Samsung HL-R4667W black screen, display says "Lamp"
it means you need to replace a lamp when it says that
Jan 30, 2009 | Samsung HLN5065W 50" Rear Projection...
Sony KDS-R60XBR2 Television Logo
57 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
