Question about Ovens
I have a freestanding "Maytag
2 Suggested Answers
  • 5370 Answers
SOURCE: I have a Maytag Gas
Yes you can keep updated.After you replace the part.And let us know about the results. " the touch panel has completely gone unresponsive" as per this it indicates faulty touch key pad control panel board.This board has to be checked and replaced.--------Helpmech.
Posted on Jan 03, 2011
This touch 850 series double oven is only heating up to 170 when dial is on 350 do I have a bad element?
Elements usually either work or they don't, if it comes on the but does not give enough heat the thermostat is bad. If it was cleaned inside recently, check the routing of the stat lead perhaps its kinked etc.
Mar 16, 2015 | Maytag Ovens
Maytag gas oven has an F1 code. Model # CGR3740ADW.
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Feb 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
I have an in the maytag gas oven that keeps beep and show f-1 when its shut off
This simple test will help determine whether the ERC (Electronic Range/oven Control or Clock) or the touch pad is defective when this error code is present.
1. Disconnect power to the range/oven (unplug the range/oven power cord or turn the power off to the range/oven at the circuit breaker). It is very important that the power to the range/oven has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC/EOC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back (usually accompanied by a beeping sound).
7. If the code comes back and the beeping as well, replace the ERC(control board). If it does not, replace the touch pad.
Nov 02, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
I have a Maytag Gase Double Oven Range Precision Touch 750 Series and having a problem with temperature control for lower over how can I fix. Jim
Hello Jim,
Can you clarify the problem you're having, or how the temperature control issue manifest's itself, i.e. can't set temp in display, too hot, too cool, won't ignite etc.
Just some clarity to move you further, hope I can assist further.
thank you
Oct 27, 2009 | Ovens
Oven heats for 5 minutes then shuts off
The touchpad has a ribbon connector to the main control. Remove the control panel re-insert the touch pad ribbon into the main control tab. If it is not a bad connection the touchpad will have to be replaced.
Jul 07, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven turning off
F3 - E4 Oven temperature sensor (RTD) opened (lower oven, if double oven). You will have to replace this failed sensor to restore normal operations. If your oven is a double version, it will be located in the lower part. If its a single range, it will be located in the oven compartment. The Oven Temperature Sensor has failed.
Please rate and god bless:)
Apr 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
