Question about Alpine CDA-9887 CD Player
I've just bought a 2nd hand 9887r unit and installed it, but having big problems with the CD player. Most CD's I try come up with an 'Error' and don't play, or the play is skipping or sounds choppy/wavy. Out of about 12 CD's I tried (which worked fine on the previous player), only one works reasonably well, but not every time. any ideas? dirty lens perhaps? cheers
KaeZoo
  • 156 Answers
SOURCE: Alpine car cd player has no volume
It's possible that you have a shorted speaker wire. If one of the speaker wires is pinched, grounded or shorted it will cause the deck's internal amplifier to shut down. The easiest way to check is with a multimeter's resistance function. Remove the CD player and unplug it. Set your multimeter for "resistance" or "continuity". Attach the black probe to chassis ground; you can use the black ground wire in the deck's harness, clean dash metal, or the outer ring of your cigarette lighter. Use the red probe to test each of the speaker outputs in the harness: white, gray, green and violet. If you find a speaker wire that shows any continuity with chassis ground, then that's the cause of the problem. A speaker with a damaged voice coil may also cause the deck to shut down. To test this, probe the positive and negative leads of each speaker and test the resistance between them. For example, to test the left front speaker you'd put the red probe on the white wire and the black probe on the white/black wire. Each speaker should read a minimum of 3 ohms of resistance. If you get a lower reading then it might be causing your problem. If you don't find a problem with any of the speaker wires, then chances are the deck's internal amplifier has failed.
Posted on Jun 09, 2007
sir fixalot
  • 146 Answers
SOURCE: alpine 9881 cd will not play sound
If you had to connect the remote amp turn on lead from the headunit to the factory amp turn on lead you may find your problem there.
On many headunits there are 2 blue remote wires 1 for antenna and one for amp turn on. The antenna remote only supplies power when the radio is playing not when playing CD's. If you hooked the antenna wire to the amp trigger then the amps shut down when you play a cd. If that's not it let me know and I will research further.
Posted on Jan 04, 2008
c renner
  • 43 Answers
SOURCE: radio has sound but not the CD player or iPod
Your amp is not turning on - what you should do is connect the "blue/white - remote turn-on lead" to whatever wire you have the "blue - power antenna" output from the Alpine connected to now. That should solve your problem.
Posted on Mar 08, 2008
SOURCE: alpine 9885 - no sound with cd's or ipod
have you fixed it yet? if not try this. your car probably has factory amplified speakers. hook up the remote wire AND the power antenna wire to the blue factory amp wire and it should work just fine
Posted on Jun 19, 2008
SOURCE: alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Posted on Aug 31, 2009
Hello, I have a Technics HiFi system - I've had it for 10 years. The problem is that the CD player skips and jumps. I've tried cleaning the CDs but there are no scratches on them. I've also...
Its time to replace the optical unit ( lens ) of the CD player. Brace yourself the unit on some of those old players can cost more than a new DVD player.
Jun 02, 2011 | Audio Players & Recorders
My Acer Aspire 6920G does not detect nor play bluray discs after switching to Windows 7. I may be missing drivers but have no clue what and where to get them. Please help.
Hi goodevening
there so so many reason why does not detect a blueray disc after you switching windows 7
1st may be your cd/dvd driver have a problem,
(solution) try to use other cd/dvd driver
2nd may be the window 7 installer you've use have a missing file.
(solution) try to re install the o.s but dont use the same cd you've use try other installer.
3rd your blueray disc is the problem
(solution) use your blue ray disc in other p.c window xp if running in xp try to use other pc using a window 7, if running in other unit may be your pc need to upgrade.
May 14, 2011 | Computers & Internet
2001 Lexus LS430 6 Disk CD Player "CD ERROR"
Nope thats what you have to do....they are they only ones that can repair that unit
that is a common problem with those cd players
Aug 27, 2009 | 1996 Honda Civic
No Disc Error
there is no fix you bought someone else's junk
May 08, 2017 | The Singing Machine DVD/CDG Karaoke System...
Daewoo Car CD Player Code
try codes 6620,0191,6012,4797,or 1305 i will try to find some more but i need the seiral number to know for sure they have diff ones for each unit
Dec 10, 2008 | 2001 Daewoo Lanos
E1 Error on Panasonic CQ-C1110W Car CD Player
If you receive an error reading or the cd ejects automatically briefly after being inserted, the headunit needs to be repaired or replaced
Jul 01, 2008 | Panasonic CQ-VD7001U Car DVD Player
Cd error
i would need the brand and model of the unit to be able to help you
Mar 30, 2008 | Car Audio & Video
Alpine CDA-9887 CD Player Logo
43 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
