Question about Mitsubishi WD-57733 57" HDTV
When I turn the tv on, either manually or by remote, the power stays on for just seconds then shuts itself off.
  • 57 Answers
Hello my is rico, check your lamp, lamp cover, fans. second power on the tv when it shuts off itself hold buttons menu and input or device, it will start blinking , it will blink 1 or 2 and then its gone pause for a second andthen will start blinking again count the blinks like, 2,3 -2,2 it means code 23 or 22 and then needs call misubishi for the codes means. if you need more feel free to call at 602-810-7149 at anytime i live in mesa az
Posted on Dec 31, 2010
Toshiba 65UL610U Wont stay on
Is the problem with the remote or your TV? Does it stays on if yiou turn your TV on manuall?
If so, you may have a contact problem with the remote and should take it to a repair service to get it cleaned
Jun 08, 2015 | Toshiba Televison & Video
Wont stay on when cold
This sounds like a power regulator issue. Check the site www.TvRepairKits.com for a "shrinking and expanding" video kit for your model. It also fixes the random off/on when the tv is cold
Mar 06, 2013 | Philips Televison & Video
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
36 magnavox tv shuts off by itself
MAGNAVOX TV ONLY. 5-10 SECONDS AFTER TURN ON AUTO TURNS OFF-NO LIGHT STAYS ON-I AM FRUSTRATED BUT IT SEEMS LIKE THE OFF ON SWITCH JUST CLICKS BACK TO OFF-ALSO DOES SAME THING BY REMOTE
Jan 16, 2008 | Philips Magnavox MS3652S 36" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Standard tv
I have the same problem with a 20" RCA. If I turn on the TV from the unit itself, it goes off in 2 seconds. If I use the remote (universal) it always stays on. Just a solution that works for me. Best, Rickjsn
Nov 15, 2006 | Philips 25TR19C 25" TV
Mitsubishi WD-57733 57" HDTV Logo
285 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
