Question about Yamaha DVD-S520 DVD Player
The door on our Yamaha DVD is stuck open and the messgae blocked appears. Is it time for a new one?
Guys I managed to fix the problem myself by opening up the unit and remounting the floating disc that holds the dvd/cd's in place during play.
Posted on Dec 31, 2010
    Problem Solver:
  • 7 Answers
Yes, it could be getting old
DVD stuck in my Yamaha DVD-c6761 DVD/CD player. How do I get it out so my player will open and work properly again.
Unbend a paper clip.Look very closely at the area around the CD/DVD drive door until you find a really small hole - it almost looks like an accident (probably just below the door). Insert the paper clip in the hole (don't be afraid). Push the paper clip gently to press the spring-loaded latch.Your CD/DVD tray should open right up. That's it. Deals Prices
Jan 10, 2014 | Audio Players & Recorders
Good evening. I have a Thomson DTH 5000 I am unable to retrieve a dvd from it as the drawer appears to be stuck!! any ideas as to how to sort out this problem. Many thanksja
Take the cover off the device, and look for anything blocking the DVD tray. If nothing can be seen, remove DVD by hand, and try manually pushing open the tray after pressing the open button.
CAUTION: Once the tray moves, get your fingers out of there FAST! The tray might not be able to cut you, but it will hurt like no other if your fingers get stuck in there!
Once the tray is open, push the open button a few times to open and close the tray. This will loosen any debris that may have blocked it. If it still won't move, then the motor has gone out or been disconnected. Have someone with experience working with electronic circuit boards take a look at it to determine the problem.
Hope that helps!
Feb 13, 2011 | Audio Players & Recorders
Have a dvd stuck in the unit. door will not open.
Your going to need to open this u if the door will not open and manually take the dis out by hand, now if you feel you cannot do that then your going to need a tech shop locally do it for you. But its easy you just pop off the screws the cover should slide oven you localte and take the disk out. now once your in there you can see if there was any damage 9 times out of 10 the disc got miss feed.
Good luck if you have any additional questions let me know otherwise please leave your positive feedbakc and ratings.
May 02, 2010 | Bose Lifestyle 38 DVD Home Entertainment...
A dvd is stuck in the dvd player
something stuck our dvd-door.
1. open the dvd
2. remove the thing that block our dvd door (like paper, tissue, paperclip)
or
maybe our dvd mechanic door had block by dust
-----basicaly, clean it.
in my case. I knock the upper top of the dvd door hard (but not by hammer, by my hand) while i push open button (the menu open/'open' word is display at the menu). if u're lucky, the dvd door will open
Sep 29, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
The dvd is stuck mid way not opening or closing
Try unpluging unit, then plug back in and press open/eject.Also look for a tiny hole on front door used to insert paperclip end, push in this will open tray.
Sep 04, 2009 | Yamaha DV-C6280 DVD Player
The disk tray won't open. There is a dvd in the tray and I played it back but, when I tried to eject it, the tray door would not open.
check if something is blocking the door to open.if no then the gears in the internal area are either worn out.apply the oily substance in the sides of the dvd gears to make it move frequently.
thanks.
Oct 29, 2008 | Lite On Televison & Video
Drive light gets stuck on at reboot
Try swapping the Jumper block ( Small plastic pin connector ) on The Back Of the DVD Drive. If using both Hard-Drive And DVD Drive on the Same IDE Cable. The DVD Should be set as Master And Hard-Drive As Slave, Or Vice versa.
Failing This, put The Hard Drive On Primary IDE Channel, And DVD On Secondary Channel.
These suggestions, have been made as it appears from your problem listed, that the 2 drives Are Conflicting with each Other.
Finally, is to try a different 4 pin ( Molex ) power cable to either device/Drive. if you have a single rail Power supply unit. the 2 units sharing a joint power cable, may be draining the PSU.
Hope this helps.
Mike @ compurepair.
May 11, 2008 | AOpen DUW1616/ARR DVD RW Dual Layer Burner
BLOCKED MESSAGE ON YAMAHA DV-S5450 DVD PLAYER
The DV-S5450 may use a belt-loading mechanism. The belt is typically black rubber band with a diameter of approximately 2 cm. It is commonly found in front-loading CDROMs for computers also. Often, as a result of age, usage, humidity, etc the belt snaps, rendering the loading impossible. The loading motor doesn't just pop the tray in or out. It also engages a clutch assembly that raises an inserted disk or lowers a disk to be ejected; this explains why you can't simply force out the tray. Clearly in your case all the electronic signals are there and the loading motor does turn.
Solution: switch off and unplug the unit and then open it up. Do a quick inspection to see if you can locate the broken rubber band. If you can, remove it and take it along with you to the nearest repair shop for exact replacement. If you are finicky around technical work, simply a competent person do it for you. Good luck.
Jan 18, 2008 | Yamaha DV-S5450 DVD Player
Skipping, stopping and 'blocked'
Yep the lazer is gone or shot if you like.you can get a replacment at $111.00 pounds sterling.
Dec 12, 2006 | Yamaha DVD-S520 DVD Player
Yamaha DVD-S520 DVD Player Logo
125 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
