Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave spacemaker shuts off after a few seconds then asks you to rest clock
  • mjlangevin Dec 31, 2010
    shutting off the breaker was the first thing I did before attempting to get a solution from FixYa. By the way that was "shuts off after a few seconds display sputters then reads RESET clock." I think basic common sense would lead you to try to reset. I hope EXPERT advice is still on its way for the money.
The problem with your GE microwave is a bad cooling fan. Check it for continuity with a multimeter and make sure the fan blade is in place. There is a tech sheet behind the top grill or inside the control panel that will give you the proper motor resistance value. If your motor is good then you will need to replace the bad control board.
Posted on Dec 31, 2010
  • 2,069 Answers
Turn off the breaker in your electric box and then turn it back on, to see if the controls reset.
Sometimes when we start the Spacemaker microwave it will run for a few seconds and then shut off, requiring restarting the clock. Do you think this is a short in the system requiring a service call?
Your magnetron is failing.
See
this FixYa solution. even if your model number is different.
May 31, 2010 | GE Microwave Ovens
The unit keeps shutting down after running for about 5-10 seconds, then I have to rest everything, i.e. clock, month day year..Whats wrong with it. It's 5 years old..
It's probably a bad magnetron.
See this FixYa solution. even if your model number is different.
May 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker jvm1650sh01 starts to microwave then loses power
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker shuts off after a few seconds and asks for the clock to be reset
Ge Spacemaker comes on ok but after a few seconds the noise level goes up significantly and it does not heat. It keeps running until the time runs out but it doesn't heat.
Feb 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
Oct 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Reset clock, ge spacemaker xl1800 times out after 2-3 seconds
There's a simple fix for this. Unplug the unit. Take off the top grill with 2 screws. Remove the 1 screw that holds the touch pad unit. Lift up on touchpad unit and lift out. Put a piece of aluminum foil inside a large zip lock bag and tape it to the back of the touchpad unit and reassemble. GE put the magnetron to close to the control board causing stray microwaves to interfere with the board. The foil shields it.
May 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Oven shuts down after a few seconds into cycle time for cooking
The magnatron (heating element) is located in the cavity behind the control. If it's leaking microwaves onto the electronics, this will occur. This means the Mag should be replaced and a radiation test run on unit.
Mar 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
46 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
