Question about Kitchen Ranges
I have an old WWII Coleman (1943) single burner field stove that I would like to take apart, clean up, and fire it up! Are there any instructions out there to do this? Thanks, Dan.
  • 868 Answers
None that are any different to cleaning a new stove.Use pipe cleaners and a oven cleaner for best results,you may use a wire brush and naval jelly if rust is there. Please Rate This !!
Posted on Jul 08, 2008
How do i light 533
can you tell me more about your model?
Mar 14, 2014 | Coleman Camping, Backpacking & Hiking
How do you convert a coleman 425e into a propane stove
Is there a reason or a need? I cannot imagine why you would want to, except as a point of interest for your camp kitchen. A new propane stove would work better and not cost all that much, relative to the work and cost of putting fittings, pipes and burners into the old stove box.
Feb 07, 2013 | Coleman 425e 2 Burner Vintage Used Camping...
The electronic ignition (piezo lighter) on my Coleman 2-burner propane camp stove just quit sparking to 1 burner. It still lights the 2nd burner. A fix?
I've had this issue a few times. Complete cleaning of the under side of the burner and all components of the ignition system fixes it every time.
The slightest bit of carbon build up is the probable cause. I would suggest cleaning the contact with 400 grit or higher emory cloth. This will remove any contamination from the ignitor,
Aug 06, 2012 | Coleman 2 Burner Camping Propane Stove W/...
How do you remove the burner part of a coleman grill/stove? I trying to give it a good clean. I got the 4 screws off and grill fuel bar, but for the of me, how do you remove the burner part. Kelly
The Coleman website has a pretty excellent list of owners manuals. (Here's the link for the 9921A700)
I believe that you unscrew the burner assembly on the right, which will then let you remove the cooktop to clean inside and re-assemble.
This procedure is not listed on the Coleman website or in the owners manual, however it appears to be fairly straightforward. I'd recommend using some teflon tape on the threads when screwing the burner assembly back on.
Aug 18, 2010 | Coleman Propane Grill Stove 9921-700
WWII production M1911 Value
Your pistol is worth a lot of money, even in these times, I would say between 800 and 1000, possibly less. Go to gunbroker .com and look them up. You will see what they sell for.
Feb 15, 2010 | Sport & Outdoor - Others
Black soot on Coleman propane burner
Had same problem. Coleman tech support said, " clean with pipe cleaners". No directions....I would think they would provide a step by step protocol. So, I chose to take the knobs off and use the pipe cleaner where I could. I was able to take one of the two burner control knobs apart. After sticking the clean in every nook I could find, I put back together, and the flame on that burner is back to normal,
Good Luck--Daryl in Burnsville, MN
Sep 11, 2009 | Coleman Grilling
Coleman dual fuel - troubleshooting steps
Got my solution by talking to a fellow at REI. He showed me how to take the Coleman apart and check for problems.
Jan 04, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
I have a Jenn-air electric stove model S125, which is about 20 yrs old. Lately, the ventilation system quits after about 25 minutes. I usually turn it on manually, but it goes on automatically during...
The answer your provided by email only confirmed what I suspected -- that the vent system was probably overheating and would cut out at a certain point.
Thank you for fast reply. I may have to get a pro to confirm this, as I'm an old lady with NO skills for taking stove apart and installing new vent motor.
Dec 29, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Having a problem with burners not generating .
so you have a yellow flame, not blue?
my mate had same problem. He now uses unleaded, adding 10 drops Redex to a gallon.
He was also told not to overfill the tank - just 3/4 full.
Works much better but he says not perfect.
Ian
Aug 24, 2008 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman Peak 1 Model 400 stove We have had this stove for 20 years at least. The last couple years a problem has begun and has gotten worse. The stove will leak liquid fuel all over the base which then...
I have heard two things that could improve your stove. I had the same "bursting into flame" issue last weekend while camping. First, move the black handle back and forth a few times. That is supposed to clean the jet. Second, take the generator off and hit it with a blowtorch. That should clean out the deposites on the inside. Or you can purchase new generators (just make sure you get the correct one).
Aug 03, 2008 | Kitchen Ranges
Kitchen Ranges Logo
154 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
