Question about Albatron Computers & Internet
Hello, I have a Albatron KX18D Pro II motherboard. While booting up I received CMOS checksum error - Defaults Loaded. My choices are Press F1 to Continue or DEL to Enter Setup. I re-booted several time and the error continues to occur. I am not sure what to do. Do I accept the defaults or go into Setup to make other changes. I tried find out if this motherboard has a battery that require replacement. But based on my investigation I was uable to locate a battery.Also where can I find the latest updates for my motherboard. I hope you are able to assist .Thank You In Advance
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
Changed the pile bios it is the probleme
Posted on Apr 23, 2017
CoachTim
  • 202 Answers
SOURCE: Your CPU may have a problem
Have you removed all memory, other cards and unhooked all other drives to see if a short exists there? With a 300W PS some other component may be pulling too much that the CPU can't start so it tells you the problem is with the CPU or The CPU its refering to is on the video card? Good Luck, Tim
Posted on Feb 10, 2007
steve6375
  • 395 Answers
SOURCE: Asus P4B Motherboard
Press DEL to enter setup and set Reset to Defaults in Exit menu. If you have USB keyboard, make sure you enable Legacy USB and USB keyboard settings, save and exit and reboot.
Posted on Aug 08, 2008
1234s282
  • 144 Answers
SOURCE: I need the user manual for an old Albatron Kx18D
ftp://ftp.albatron.com.tw/FAE/Manual/Mainboard/KX18_Series/KX18D_Pro-KX18D_ProII
If you found this useful , please rate below
Kind Regards
1234s282
Posted on Jul 02, 2009
gherna1
  • 190 Answers
SOURCE: Soyo KT400L-2AA5 Motherboard - CMOS checksum error - Defaults loa
This message is usually accompanied by another more explicit, like: "Memory changed from 1GB to 2GB. Press F1 to continue". The message should display and go away after pressing F1. Since you cannot press F1 because the keys do nothing, chances are your keyboard is disconnected, which should display a message indicating this failure.
Try pressing the ScrLk (Scroll Lock) key as messages are being displayed to catch all
messages (they go by quickly) and stop them before they disappear.
If that's the case, then reconnect the keyboard and try again.
Posted on Aug 20, 2009
  • 81 Answers
SOURCE: When my Albatron PX845PEV Pro (Rev:800) R1.00 is
You will need to press delete and keep tapping it as soon as you turn it on. You should then be in the BIOS, look around for an option that is similar to "Reset to Default Settings" and use that option. If you are still experiencing that problem, try clearing the CMOS by unplugging the power cord from your computer, take the battery on the motherboard out for at least 10 seconds, then put them all back it.
If it is still not working, you can use another computer to find the BIOS Update/Firmware for that motherboard. Make a bootable floppy disc and then flash the BIOS. That information can be found in the motherboard manual.
Posted on Mar 08, 2010
Dell Inspiron 530. At start up gives CMOS checksum error defaults loaded. Options press F1, F2 or F12 computer does not react. Has new CMOS battery. RAM OK. Did CMOS clear and password reset. What else can...
When a Power Supply is plugged into power, there is a constant 5 Volts present. The 5 Volt Standby Power.
You press the Power On button.
This in turn presses against the Power On switch, located inside it's plastic assembly.
The Power On switch is a Momentary Contact Switch.
Temporary closing it activates the Soft Power On circuit.
A 5 Volt circuit that utilizes the 5 Volt Standby Power.
The Soft Power On circuit 'excites' the Power Supply, and turns it on.
(Sounds like a seedy novel)
The first chipset (Integrated Circuit) to receive power is the BIOS chipset.
The Basic Input/Output System program is initialized.
BIOS looks to see what devices are connected, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System.
A checksum is computed as an error-detecting code, to protect the BIOS settings stored in CMOS.
Each time the computer is turned on, this number is re-computed; and checked against stored values.
If they do not match an error message is generated, to tell you the CMOS memory contents may have been corrupted; and therefore some settings may be wrong.
Your BIOS assumed the settings were incorrect, and loaded BIOS default settings; stored in BIOS.
(Default = factory settings)
CMOS Checksum Error Defaults - Loaded
New battery? Nope didn't help.
Clear CMOS, and password reset? Nope didn't help.
Leaves Virus as the problem, or hardware component/s on motherboard; are bad.
My thoughts?
Bad motherboard.
("BAD motherboard. NO,...........you know you have been bad,....don't give me that look. You're a bad motherboard."
Lol!)
That's my diagnosis.
(Unless you put the CMOS battery in upside down.
+ goes UP)
Regards,
joecoolvette
Mar 17, 2013 | Dell Computers & Internet
Gateway gt5220 has cmos checksum error - defaults loaded
Open the cpu cabinet cover then pull cmos cell from motherboard for 10 minutes then all settings defaults.Then when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then set bios settings.Let me know if you need further assistance.Thanks for using FixYa
Nov 18, 2011 | Gateway GT5220 PC Desktop
Cmos checksum erroe defaults loaded
press del to enter setup.then choose default bios setup. then save and exit.pc will restart.
Nov 17, 2011 | Gigabyte GA-945GCMX-S2 Motherboard
AFTER SWITCHING ON, SCREEN STAYS FROZEN AFTER SAYING CMOS CHECKSUM ERROR- DEFAULTS LOADED
When starting your PC, the following error message is displayed:
CMOS wrong
CMOS MEMORY size WRONG
CMOS Checksum Bad
Warning! CPU has been changed please re-enter cpu settings in the cmos setup and remember to save before quit!
You are prompted to:
Press F1 to resume
Press F2 to load default values and continue
This is due to the fact that the CMOS, which contain data related to the BIOS, has been reinitialized and that your PC has been reset to factory settings.
Solutions:
Reinitializing the BIOS
  • Change BIOS battery
    • If the problem persist this may be due to the fact that the battery powering the CMOS (when the computer is shut down allows the CMOS to store information), is depleted.
    • The CMOS battery is a small pin found on the mother board, you can refer to the manual provided with your motherboard to change it or have the nearby computer technician change it for you if you don't want to risk any damage.
    • More information with: Replacing the battery of your motherboard (CMOS battery)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | Sharp Actius PC-RD10 PC Notebook
Aug 20, 2009 | Soyo AMD KT400 Dragon Ultra Black (K7VX4B)...
Cmos checksum error - defaults loaded
Ports are usually labelled - look carefully.
Try manufacturers manual.
Could be that keyboard is the larger 5 pin DIN socket (old IBM AT keyboard).
Aug 10, 2008 | Computers & Internet
Aug 04, 2008 | Computers & Internet
CMOS checksum error
rahul23petit
"CMOS" checksum error default loaded" means ur mother board cmos battery fail (which is locate at mother board), to solve this problem replace it by new one (u can buy it form any computer accessories shop). all oher problem happen for it.
Jul 06, 2008 | EliteGroup BKi810 Motherboard
Your CPU had a problem
TRY TO RE SET THE CMOS BATTERY
Dec 18, 2007 | Albatron Nforce2 (KX18D PRO II)...
Computers & Internet Logo
46 people viewed this question
Top Albatron Computers & Internet Experts
Matthew Spark
Matthew Spark
Roy May
Are you an Albatron Computer and Internet Expert? Answer questions, earn points and help others
