Question about Coleman 6.5hp - 80 Gallon Vertical ASME Oil - Lube Air Compressor CV6548049
Can I lay a coleman 6.5 hp - 80 gallon vertical air compressor down on its side to transport it?
  • 21 Answers
To lay the compressor over the oil should be drained
Posted on Dec 30, 2010
6.5hp 80 gallon tank when it gets hot it shouts off
need a little more info. Does it shut off because it tripped the breaker? overload? does it boug down and stop? does it stop when trying to restart? is the compressor get hot enough to change the color of the discharge tube?
Dec 17, 2011 | Coleman 6.5hp - 80 Gallon Vertical ASME...
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
Compressor starts up fine the kicks out?
Cold weather will freeze the water the compressor normally makes and this can prevent the switch diaphragm from releasing....
Jan 30, 2010 | Coleman 6.5hp - 80 Gallon Vertical ASME...
Should I lay the compressor on its side?
I would advise you drain the crankcase of oil before you do that.
Jan 27, 2010 | Coleman Powermate 60 Gallon Air Compressor
Compressor spewing Oil
hi your machine will discharge oil from the vent if your rings or bores are worn ,if the oil comes out with the air the your valves are broken or not sealing
hope this helps
ian
Mar 22, 2009 | Coleman 6.5hp - 80 Gallon Vertical ASME...
Head bolt torque spec
220-300 inch lbs work from center out
Jan 15, 2009 | Coleman 6.5hp - 80 Gallon Vertical ASME...
Oil level check
chack oil mwith the dipstick unscrewed.also if yours has a site glass be sure the oil level is in the center of the glass
Dec 15, 2008 | Coleman 6.5hp - 80 Gallon Vertical ASME...
Coleman 6.5hp - 80 Gallon Vertical ASME Oil - Lube Air Compressor CV6548049 Logo
228 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
