Question about Canon Rebel XT / EOS 350D Digital Camera
To change the "exposure compensation" it's saying
    Brigadier General:
  • 11,967 Answers
When you change the exposure compensation setting, the camera will change the aperture, the shutter speed, or the ISO depending on the mode you're in and the shooting situation. That's what "compensation" means.
Posted on Dec 31, 2010
My wonderful Coolpix recently seems to be letting in too much light when I go to take a picture..worked fine before
It is mostly due to changing the exposure compensation. You can change it from +2 ....0 ....... -2. +2 Makes it Brighter while -2 makes it darker... On the back of the camera you will see an OK button surrounded by a disk that on the right side shows [+/-]. You use this to change exposure compensation. When you get the camera READY to take a photo you can use that [+/-] button. When you push it you can adjust it to zero (o) normal or to make it lighter or darker.
Sep 29, 2015 | Nikon Coolpix S3300
Too much brightness when using s6800
I do not know the S6800 model specifically however, nikon cameras all generally work in the same way. Somewhere on your camera, probably a button or in the menus, there is an exposure compensation setting. The symbol Nikon uses for the button is a "+/-" enclosed in a circle (often half black on white/white on black printing). Press the button and you will either see a zero, a positive or negative number or a a scale with zero in the center with positive numbers to the right and negative numbers to the left.
If the exposure compensation is not at zero, set it to zero. Your exposures should now be correct. If it is already at zero, set it to a negative number to reduce exposure and darken the picture and to a positive number to increase exposure and lighten the picture. Let me know if this solved your problem.
Jul 31, 2014 | Nikon COOLPIX S6800 Digital Camera Black
Over exposed photos
Your exposure compensation might not be set correctly. Just behind and to the right of the on/off switch you will see a small button with a "+/-" symbol. That is the exposure compensation switch. When you press it, you will see a number displayed on the LCD. If the number is positive, that is your problem. Positive numbers increase exposure and negative numbers decrease exposure. Set the compensation to 0.0 by turning the rear thumbwheel while depressing the exposure compensation button.
Jan 09, 2014 | Nikon D90 Digital Camera with 18-105mm...
When I turn my camera on it automatically flips to show the exposure compensation button. The only way I can get it to go away and take a photo is to push the lock button and then it lets me take a photo....
Why don't you push the exposure compensation button (the one that's half-black/half-white with a plus and minus) make sure the setting is on "0" and push the button again to turn it off.
Nov 01, 2010 | Nikon Coolpix 5700 Digital Camera
When i took a picture with my nikon d70 the the outcome is quite bright where to adjust. i'm a beginner
1. You could lower the ISO setting. 2. You could lower the "exposure compensation" setting. It's the button that's half-black/half-white with a plus and minus. There are many other ways but you really should carefully read your instruction manual and experiment.
Oct 29, 2010 | Nikon D70 Body Only Digital Camera
My Canon Rebel XT is overexposing shots in the Auto and Program mode by 1 or 2 stops. How do I fix this or compensate for it?
You can go into "exposure compensation" and lower the setting as you desire. It's the button that's half-black/half-white with a plus and minus.
Oct 29, 2010 | Canon Rebel XT / EOS 350D Digital Camera
How do you set the apeture on a Kodak Easyshare DX4530 camera?
1 In any Still mode, press the Menu button.
2 Press to highlight Exposure Compensation , then press the OK
button.
3 Press to select the Exposure
Compensation setting.
 If pictures are too light, decrease the
value.
 If pictures are too dark, increase the
value.
4 Press the OK button to accept the change.
5 Press the Menu button to exit the menu.
6 Use the camera screen to frame your
subject. Press the Shutter button half-way
to set the focus, then continue pressing
completely down to take the picture.
This setting remains until you change the
Mode dial or turn off the camera.
here is the link for the manual if the details are not clear http://www.retrevo.com/d/ds/progress?doc=9f1ccaf06b7e8ecedf71c821d3c1fb02&rk=0.5443618496384233
Oct 03, 2010 | Kodak EasyShare DX4530 Digital Camera
How do you change the shutter speed on the finepix s5500?
That depends on the selected shooting mode.
In Program AE, press the exposure compensation button and then up/down on the 4-way button to change the shutter speed/aperture combination.
In Aperture Priority AE you can control the shutter speed indirectly. Press the exposure compensation button and then up/down on the 4-way button to change the aperture, and the camera will adjust the shutter speed to suit.
In Shutter Priority AE press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. The camera will adjust the aperture to suit.
In Manual press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. You'll have to press left/right on the 4-way button to select the appropriate aperture.
Mar 08, 2010 | Fuji FinePix S5500 Digital Camera
Camera over exposes
If you have the manual, check to see what settings you have tor the exposure.
On some cameras if you hold the button down half way it sets the exposure so if you move it to another area, the sky or sand won't effect the exposure.
More simply, there are general settings for the camera, beach, sunset etc that will compensate for the exposure.
Just throwing in my 2 cents.
Oct 31, 2009 | Cameras
Photography menu operation
You are on the fully automatic shooting settings, and as such, are prevented from making exposure (etc.) adjustments. Change the shooting mode to manual, and they should all be accessible.
Sep 19, 2007 | Fuji FinePix F10 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
73 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
