Question about Compaq Presario CQ60-220US PC Laptop
How can I connect Screen to a TV via HDMI interface, whta windows OS do i need.
  • jan_v_lindsk Dec 30, 2010
    How do you mean enable the HDMI screen. should there be defined 2 screens on the lap-top
    or can you make a hardcopy picure what you mean.
  • jan_v_lindsk Dec 31, 2010
    In principel you gave the right answere.
    my problem was solved when I first connected the HDMi cable to the PC and the TV, and after that started the PC so the cable was conncted when the PC started, Tha can be useful for other persons with this problem.
    So now it works.
    Happy new year to you.
  • 161 Answers
You will need to purchase an HDMI cable then plug it into your laptop and then plug it into a HDMI compatible TV. Then from there you will go to your display properties and enable the screen. Any OS should be compilable :)
Posted on Dec 30, 2010
  • 2 more comments
  • dirtlover661 Dec 30, 2010
    Right
    click on your desktop and hit personalize, then scroll down and go to
    display settings. If There is two boxes. one With 1 in it and two with 2
    in it then you may just have to enable it. My laptop has a shortcut for
    it you have to hit fn then the f6 key at the same time to enable a
    second monitor :)
    i think for your laptop is fn + F8 key to enable the TV as a secondary monitor :)
    Here is a screen shot of my system with using hdmi. Mine is set up using hdmi as the main monitor and my laptop screen as secondary. I got to these setting by right clicking on the desktop backround and hitting personalize then a window cam up and in that window I clicked display settings :)
    Usually laptops have a key on it so that the hdmi will work as a second output. Like my computer has a f6 key that says HDMI right below it. So what your do is hit the fn key and then you hit the key that says HDMI or has like a little picture of two monitors :)
Guys, Recently i got LG 22" LCD TV. It has VGA port and HDMI port. When i connected my CPU cable toLCD via VGA port it didn't show anything, :"( i checked input MENU on remote then it shows only 4...
HDMI [High Definition Multimedia Interface]. VGA [Video Graphics Array]. AV [Audio Video]. By these definitions itself talk to you about the inputs your TV have; and it do not support VGA. Output from PC is VGA. Without a VGA input with the TV, you can't connect the PC to TV. I think I'm clear. http://electronicshelponline.blogspot.com/
Jul 09, 2014 | Televison & Video
Wd65738 blue screen
blue screen means no video signal, if the source is on hdmi ensure the cable is rca or in simple audio video jacks which u will have to connect in the dvi input of the tv reason is hdmi means high definition interface and transmits by hdcp like the data of an internet meaning its digital platform which the tv can only process thru the dvi inputs or component y,p,b
Jul 17, 2013 | Televison & Video
Protron tv says input signal out of range when connecting laptop via hdmi
The TV can't process the digital signal. It might be out of range.
Nov 26, 2012 | Protron PLTV3250 32 in. LCD Television
No audio input from TV on DVD Home Theatre
U have audio signal incompatibility. If the audio output is digital it may not work with an analog input, etc.
May 08, 2017 | Audio Players & Recorders
How to i connect my laptop into television with high definition multimedia interface
First what you need is a HDMI cable.
Second look for HDMI port at the side of your laptop. (It may not be the model of your laptop.)
Third look for the HDMI port on you T.V. (It may not also the model of your T.V.)
After confirming those connection on your T.V. and Laptop, you can just the HDMI cable to connect you Laptop to T.V. Also you need to choose HDMI on your T.V. settings and for your Laptop you can just switch the display by pressing FN+F4 or F5.
Hope It helps.
May 14, 2011 | Compaq Presario CQ60-204NR Notebook
How can I connect Screen to a TV via HDMI interface, whta windows OS do i need. The TV screen is blank on HDMI2. When I try to right click in desktop screen I can only find one screen definition. I have...
Right click on your desktop and hit personalize, then scroll down and go to display settings. If There is two boxes. one With 1 in it and two with 2 in it then you may just have to enable it. My laptop has a shortcut for it you have to hit fn then the f6 key at the same time to enable a second monitor :)
Dec 30, 2010 | Compaq Presario CQ60-220US PC Laptop
I am looking to purchase a new Dell computer. In
HDMI is digital and uncompressed signal while the above mentioned interfaces are analog. A digital source is translated into less precise analog signal in an analog interface. After that signal is sent to the television and then converted back into digital signal to display on screen. Due to this, some distortion of picture quality is caused at each translation. HDMI removes the analog conversion and preserves original signal and delivers richest, sharpest picture. Separate audio signals are required by other video interfaces. Due to large amount of bandwidth available in HDMI, it not only transmits video but audio channels up to eight digital audio channels can also be transmitted through HDMI. The entire process becomes simple because a number of wires are replaced by a single wire. It also delivers much better performance.
The HDMI “Type B” have 29 wires while standard HDMI or “Type A” has 19 wires. Motion picture industry and other professional applications use “Type B” HDMI wires. HDMI enabled components talk to each other via an interface that is why it is also called Intelligent HDMI. All-in-one functionality of remote and other interoperable features are provided by HDMI but not by other technologies.
High-Definition and enhanced video and other standard formats are supported by HDMI. Backward compatibility with DVI (Digital Video Interface) is also supported. DVI/HDMI cable can be used to connect HDMI interface in high-end graphic cards that have DVI port. DVI/HDMI cable has HDMI connector at one end and DVI connector at the other. Another point to note is that degradation of signal can occur if the length of the HDMI cable exceeds 5 meters (15 feet).
At least one HDMI interface was provided in many high-end televisions since 2005. Two HDMI interfaces provides more flexibility and three might be better in cases where one wants to connect a game console. As the TV industry installs HDMI interfaces into more peripheral components, multiple interfaces will become common on TVs.
It is good to have it.
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 15, 2010 | Dell Inspiron 580 Desktop Computer (Intel...
How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Jul 09, 2008 | Denon AVR-3805 Receiver
Compaq Presario CQ60-220US PC Laptop Logo
226 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
