Question about Fluidmaster INC #B1F09 9" Faucet Connector
Flapper closes way to quick. Have to hold handle down for complete flush. This is in an Amer. Stand. toilet. I have adjusted the chain and the flapper dail with no help. I work in the plumbing Dept. at Home Depot so I have knowledge and experiance with flappers and toilets.
  • Anonymous Mar 19, 2014
    flapper drops too soon
  • 312 Answers
Hi, American Standard uses a special large type of flapper that is designed for it. If I recall correctly,
It is black plastic with a device designed to delay the closing of the flap. It also has a special chain that is not like other flappers. Home Depot should stock these flappers. Fluidmaster makes a version of it that they sell.
Hope this helps,
Best Regards,
Mark
Posted on Dec 30, 2010
Toilet does not have good flush
The power of the flush has nothing to do with the fill valve. It has to do with the flapper. When the flapper is opened, the surge of water into the bowl is what causes the toilet to flush. If the flapper closes too quickly, it will take away from the powerful flush. Try to find the correct flapper for that type of toilet and stay away from the "universal" flappers.
Feb 06, 2014 | Home
Flapper valve closes too quickly
Fill the breather hole (1/8" hole) inside the flapper.This is designed to let air out so the flapper will sink. Now it floats longer letting in more water. 25%percent more in my case.
Apr 22, 2012 | Home
HAve to hold the flush handle down for several
change and or adjust the flapper valve if the chain is to long flapper wont stay open long enough for the water to drain into the bowl
May 30, 2010 | Toto CST414M-11 Aquia Dual Flush Elongated...
How can I adjust the float, I have wellworth complete solution class five (11471-0). It seems like the float goes down quickly, with emptying the remaining water. I have set the right water level, and yet...
what happens is the float is not staying open for long enough, by shorting the chain that goes to the flapper might help but you can only shorten it so much or the flapper does not close all the way then the toilet is just running and running. No you don't want that so the other thing you can do that might work is when you go to flush the toilet just hold the handel down for 5 seconds this will keep the float up and open for the Right amount of time. Other wise the other way to fix it witch is a old school trick is that you need to find a nice small piece of foam, witch floats and is about the size of a old half dollar and as least half inch thick, you place that on the chain that goes to the flapper so when the toilet is flushed the flapper will float and stay open . IF you do this just make sure to use a good piece of foam and secure it properly where it wont come off the chain.
May 18, 2010 | Kohler K-11470-0 White Wellworth Complete...
Flush valve closes before toilet flushes completely?
lift off cover and adjust =shorten length= between flapper and handle lever
Apr 26, 2010 | American Standard Colony 2388.012.222...
I have to hold the lever of my Eljer one-piece toilet to flush it. How to adjust it?
lift off cover and shorten flapper to handle chain/rubber connection flapper not opening all the way
Apr 11, 2010 | Eljer Toilet Onepiece Canterbury ...
Crane toilets don't flush properly, ball comes down too quickly
adjust the flappers-- either adjust the length of the lift line-from flapper to handle and or the flapper itself not properly mounted on tank seat
Mar 10, 2010 | Crane Plumbing Home
The flush valve does stay open long enough after flushing
Which style of flush valve do you have? If it is the dual-flush option (solids/liquids) I do not know how to adjust those. If you have a traditional style, then the flapper or ball is closing too soon. You need to adjust the guide arm (flush ball) higher or shorten the chain between the flapper and the handle. Adjust this carefully or you will have it fail to seat and the toilet will constantly run.
I hope this helps.
(who needed to replace the fill valve and the flapper at her home earlier this week)
Feb 19, 2010 | Kohler - Toilet - Two-piece - Highline -...
Toilet flapper closes too fast, can't figure out the best position to adgust the chain.
See this PDF document link below for a product from Fluidmaster which allows adjustment for the time for the flapper valve to remain open after flushing:
http://www.fluidmaster.com/pdfs/555c_instructions.pdf
Apr 28, 2009 | Dishwashers
Fluidmaster INC #B1F09 9" Faucet Connector Logo
297 people viewed this question
Top Fluidmaster Plumbing Experts
Mack Baxter
Andrew Bugbee
Tom Chichester
Are you a Fluidmaster Plumbing Expert? Answer questions, earn points and help others
