Question about Panasonic PT-56DLX25 56" HDTV
Panasonic pt-56dlx75 I was wondering if you could tell me how to reset the timer after I have installed a new lamp. Can you help me? Thanks! Tracy
  • 3 more comments
  • brown6254 Dec 06, 2008
    lamp meter reset
    Reset lamp meter
  • foxxmotox Dec 30, 2008
    neet to reset lamp meter. please help. thanks.
  • dond720 Jan 28, 2009
    reset the bulb timer
  • jsyjms77 Feb 22, 2009
    i was wondering if you could tell me how to resset the timer after i have instaled a new lamp. Can you help me
    thanks
    jessy james
Thanks!
Keith
Posted on Nov 08, 2008
Can I reset lamp timer without remote. Lost remote
It cannot be done without the original remote---they are not that expensive--Google the model number with "remote" and do not bother with a universal remote.
May 27, 2012 | Panasonic PT-56DLX75 56" HDTV
Tip
Panasonic PT-61LCX66 Lamp Timer Reset Models No. PT-52LCX66 / PT-56LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Here are the steps to reset the Lamp Timer for your Panasonic Multimedia Projection HDTV:
  1. Plug your Television in.
  2. Press the POWER button on the TV or the remote control.
  3. Press and hold the VOL- button on the TV, while holding the 0 button on the remote control for at least 5 seconds.
  4. When the reset procedure is complete, a confirmation screen will appear.
  5. Release the buttons and the LAMP indicator will go out.
Download the TYLA1001 Replacement Lamp Installation instruction guide here.
I hope that helps.
on Apr 11, 2010 | Panasonic PT-61LCX66 Television
Tip
Panasonic TYLA1001 Manual Lamp Replacement Instructions Models No. PT-52LCX66 /...
Are you missing the Installation Instructions for your Panasonic TYLA1001 Replacement Projector Lamp?
A digital, pdf version of the TYLA1001 Lamp Replacement Instructions can be downloaded from here.
Once installed, reset the lamp timer of your Panasonic Multimedia Projection HDTV by following these steps.
I hope that helps.
on Apr 11, 2010 | Panasonic TYLA1001 TYLA1001 Projector Lamp
I have a panasonic pt-56dlx75. the lamps are okay i had them checked but my tv will not turn on, no blinking red lights just a green blinking light in the power button. I can also still hear a fan working...
I am not familiar with your TV but the blinking light is generally the error code! You will need to count the blinks, that will tell you what is wrong with your TV! Wish I could help you more!
Jan 07, 2011 | Panasonic PT-56DLX75 56" HDTV
Ineed to reset the lamp timer on my panasonic pt-56dlx75-k tv I installed a new lamp
terryc43,
This should solve your problem.
1. Turn on the television.
2. Press the down button on the TV Display (not the remote)
3. While pressing the volume button, press the "split" or "PIP" button on the remote.
This should reset your lamp timer.
Thanks for using FixYa and for the great rating!!
hardrocko
Oct 28, 2010 | Panasonic PT-56DLX75 56" HDTV
Where do I purchase and how do I replace a picture lamp for a panasonic PT-56DLX75 56 in. HDTV Television ? I live near Sioux Falls, South Dakota.
Hi there this online store has the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=PT-56DLX75
this link has your TV manual and check page 67 it will show you were the lamp is located in your TV
http://service.us.panasonic.com/OPERMANPDF/PT56DLX25.PDF
this link shows you how to replace the lamp
http://www.fixyourdlp.com/guides/panasonic/TY-LA2005.php
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Oct 11, 2010 | Panasonic PT-56DLX75 56" HDTV
How do I reset the lamp timer on my panasonic dlp tv?
Most Panasonic lamp driven TV's use either the PIP or SPLIT button on the remote control pressed simultaneously with the VOLUME down on the TV. These two buttons must be held in that position for more than 6 seconds then a box should appear on the screen letting you know the timer was reset to zero. The instructions usually come with the lamp as they are not in the owners manual. Please take a few moments to rate my answer. Thanks....
Nov 20, 2009 | Panasonic PT-56DLX75 56" HDTV
Reser timer for lamp
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Mar 02, 2009 | Panasonic PT-52LCX66 Projection Television
How do I rest the lamp times on my DLP TV Panasonic PT-56DLX75/PT
The reset procedure is usually documented in the owner's manual. But if you can not locate that, please update this with the model number of hte set and we'll get that info for you. Please note that the procedure is relatively simple, but dependent upon the model number.
Thanks,
Dan
Feb 05, 2009 | Panasonic Televison & Video
I was wondering if you could tell me how to reset the timer after I have installed a new lamp. Can you help me? tv is a panasonic pt-56dlx25 Thanks, dave
Plug the power cord back into the properly grounded wall outlet. Then press the POWER button on the projection display or the remote control to turn the power on.
2. While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneosly for more than 5 seconds.
3. Whe the lamp time reset procedure is complete, the screen will display "LAMP TIME WAS RESET TO 0." When the lamp time is reset, the LAMP indicator will go out
Dec 30, 2008 | Panasonic PT-56DLX25 56" HDTV
Panasonic PT-56DLX25 56" HDTV Logo
524 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
