Question about Samsung HMX-E10 Camcorder
Before I ship this thing back to Samsung to get it fixed I figured I would post the problem here and see if I can fix it myself. I have managed to get my camera stuck in some kind of factory test mode by holding the menu and power buttons. From the looks of it, it's in the auto focus testing, nothing I do including removing the battery seem to get it out of this test. After talking with Samsung support they said that the unit needs to be serviced, but as I have found in the past that is usually just code for "We can't find a solution for you on our script, send it to us so someone who knows what they are talking about can fix it." So my question is has anyone had this happen and knows how to get the camera into normal working mode again?
techman
  • 3130 Answers
SOURCE: Mechanical problem "C.EMG" from my SC-A30 camcorder
This is a great little inexpensive camcorder here in the states. My experience with this model with those symptoms have been mode switch problems or a broken cam that throws the camcorder mechaism out alinment. These babys are nothing like the full size camcordersas you need special alighment jigs and lots of luck(lol) Reason i say that is because the manuals are not the most complete with the mechanical alighnment and you have to have some experience with other brands as afetr all mostly work about the same way in several ways as theres only so many ways to move a tape. These camcorder also suffer rfom the dreaded sony cap problem where they used those small serface mount caps made by panasonic and when you have on in for service you ended up in most cases replaceing several at a time as you would find all sorts of other tiny problems that the customer forgot to tell ya like veifinder problems and the shutting fown after a few hours ect ect. Best thing for you is to order a manual or ship it out to a repair depot to have fixed BUT in tellin ya its probably cost prohibited because of the time it takes to sevice these pups. Good Luck
Posted on Apr 12, 2006
tvtek
  • 1284 Answers
SOURCE: Samsung HCP4752W
You can not change a value in 480p or 1080i unless that is the incomming signal type. Unless you really understand these setting I would be careful of changing any.
Posted on Apr 15, 2007
  • 5 Answers
SOURCE: SC-D363
hmmm, the only thing i can think of is to try the easy Q mode and see if it works ok , when it is in easy Q mode it puts the video camera at a default setting and you cant change any of the menu options until you take it out of easy Q.
hope this helps
Posted on Jan 08, 2008
SOURCE: Samsung YP-T9j won't turn OFF - Automatic Test Mode
How do i reboot and delete everything off
Posted on Sep 24, 2008
SOURCE: Camera won't record a D comes on screen and eject tape comes up.
users manual
Posted on Jan 27, 2009
Takes 40 minutes to power on my ln40a550p3fxa
have the same problem it is the main board but no one will post the fix. It can't be that hard to fix! Have a BN94-022079A its similar to your board looks the same and has the same problems. Anyone willing to post the fix for this board. Theres some guy on ebay fixing them for 75 bucks, you send your board in they do the repairs and ship it back
Feb 26, 2013 | Samsung LN40A550 LCD TV
HP 5100tn There is a streak running down the left side of everything I print. I believe that the fuser is shot, but I figured that maybe I could remove the fuser somehow and try and fix it myself, maybe...
You can't really clean a fuser effectively. You will need to replace it. Replace the cartridge first because a cartridge will do this. I suspect it is the cartridge.
Aug 24, 2017 | HP LaserJet 5100tn Printer
Lens stuck half way outm weird beep sound can I fix it
I get the three beeps also but the lense is fully retracted. I'm no expert but I've had this camera fixed once (would not focus) and is going back in for this latest issue. I like the little thing but I wish it would not break as much as it has. On the other hand I've had great esxperiences with smasung's warranty service. If your camera was purchased less than a year ago it is still under warranty and a quick call to samsung will get you a shipping lable to an authorized repair center free of charge. You only pay for shipping to the repair center.
Good luck
Jul 14, 2009 | Samsung BL103 Digital Camera
SCREEN IS BLURRY WITH COLORS SCRAMBLED.
You can buy the new convergence board assembly from Vance Baldwin and replace yourself. Its about $80 plus shipping.
Dec 29, 2008 | Samsung HCL4715W 47" Rear Projection...
Wavy red lines ,double vision
This is a convergence problem and if you can solder, you should be able to fix this yourself. First open up the back and locate the convergence ICs. These are large black ICs attached to a heatsink and should be marked STKxxx. Post the markings here and I'll confirm you have the correct ones. Try resoldering the pins on the ICs. If that fails to resolve the problem, you will need to replace them.
Keep me posted,
Dan
Nov 13, 2008 | Samsung HCM4215W 42" Rear Projection...
JVC GR-D770U
No Prob...I had the same problem with my GR-D72U. There is a defect in the CCD image sensor. JVC will fix it for FREE! All it will cost you is shipping it to them. Go to http://www.jvcservice.com/service/CustNoticeCamcorder.asp?PgReq=DspDtaDtl&MdlNbr=GR-D72US&Pgm=CCD , download the rapair request... Send it off to your nearest service center and they ship it back all fixed up in less than a week. I must tell you though, you ONLY have until Dec. 31 2008 to do this. Not only did they fix mine, they cleaned the heads but also buffed out a scratch. After you get yours fixed, post as many helps as you can to others.
Aug 02, 2008 | JVC GR-D770 Camcorder
Broken d52w19
Hi ,here is some of the tips found on www.repairworld.com no convergence- replace fuse FL231 near flyback or in front of flyback also solder flyback pins alot of these sets have poor connections,they are having alot of trouble from ribbons that connect from bottom tuner broad going to convergence broad also connectors that ribbons plug into so far there is more infor on the HD52w59 .The next set i get in my shop the first thing is to solder power supply broad,then see what happens so far the 2 sets i have now i havent been able to fix,but im not quiting untill i fix them or throw them back to customers.
Feb 03, 2008 | RCA D52W19 52" Rear Projection Television
Samsung Player will not recongnize DVD
I had the same problem and after reading and trying allot of disks I found the following to work.
Used Maxell - RW disk. Did a complete format on my computer (takes a while). Burned a DVD using Vista DVD burner with only a Jpg as per one of the other posts. Once the disk plays. Stop and goto disk management and format using DVD-V (VR did not work).
I know its not pretty but at least its better than throwing it in the garbage bin.
Sep 19, 2007 | Samsung DVD-R130 DVD Recorder
Help i want to fix it myself!!!
yes, you can but you need the right tools and follow the instructions, but you better think the cost to repair because,you'll need parts , tools. shipping expenses ,time to expend and guidance to do the job,just the tools and the parts you may need can cost to ,you no less than 100.00 if you want to try let me know
Jun 10, 2007 | RCA 32V420T 32" TV
Samsung HMX-E10 Camcorder Logo
53 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
