Question about Dryers
How do I install a new belt for my very old Beaumark dryer model #64050429 serial# AC540467
tzweeb
  • 318 Answers
SOURCE: Dryer won't start
belts, as in 2?? you do have an old speed queen. did you make sure the blower is able to turn freely?
if so then you most likely have a bad winding in the motor. it is costly to replace and you should go out and get a new dryer. too much money to fix this old unit.
by the way the model number is under the front panel in the center, on a metal plate.
doesnt matter since you know its 25 years old and its time to update.
Posted on Jan 22, 2009
dragonsthatk
  • 547 Answers
SOURCE: Replace dryer belt
http://www.partstap.com/ please go here for diagram thank you please rate me
Posted on Feb 22, 2009
Healeyman
  • 1198 Answers
SOURCE: Hotpoint Dryer belt broken
http://www.pcappliancerepair.com/model-display.php From what I see, you have to remove the front, and maybe the drum to get at the belt. See what instructions come with a new belt.
Posted on May 12, 2009
Maytag317
  • 1136 Answers
SOURCE: The belt is broken. How do I install a new belt.
Hi, UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
There should be instructions that came with the belt. I will try and explain how this goes on. The idler pulley fits in a slot right in front of the motor. Put the belt over the drum with ribs touching drum. Now, thread the belt through the idler pulley wheel and bracket and set the belt on the motor pulley. The ribs should rest in the grooves on the motor pulley.
I hope this helps you. If I can assist you further, please let me know. Please rate me performance so that others as well as myself will know how I am doing.
Thanks
Vic
Posted on May 23, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a Hotpoint Dryer and the belt snapped, we
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt,felt seal, and drum.
Remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
The route of the belt will go around the motor pulley first, then it will go around the idler arm bracket with pulley, then around the drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Posted on Nov 15, 2009
Why won't my dryer turn ?
It sounds like the belt is broken, it is a big belt that turns it around the drum..you can look up your dryer by finding the make and model and serial number on the back someplace, then look up which part number you need, if you dont know how to install a new belt, a handy man may be able to help you for much less than getting manufacture to come out unless its under warranty still, good luck
Sep 08, 2014 | Dryers
How do I fix the squeaking when the dryer starts up in a fridiadare gallery dryer with model number 341as1 and serial number x021308125
It quits down after it runs awhile?
Your Belt and Rollers are getting old. Live with the short term Squeek or replace the Belt and Rollers and idler
Dec 15, 2013 | Frigidaire GLER341A Electric Dryer
Beaumark model 660504191 - makes a noise drum off
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 13, 2011 | Kenmore Dryers
My beaumark dryer model # 640504191 has a motor issue
Sounds like a tension device came loose alowing motor to move into bad spot and cant run now
Aug 23, 2009 | GE Dryers
Replacing the belt on general electric washing machine model WWA7304PML GOT IF OFF TRYING TO PUT THE NEW ONE ON
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, look for the "Dryer Belt Diagrams" link under the "Special Features" section. Diagrams M, D, or L under the General Electric section will show how your dryer belt goes back on. If you need assistance in determining how old your dryer is, post your serial number and I can determine for you. I hope this helps you.
Jun 09, 2009 | GE Washing Machines
May 12, 2009 | Dryers
Dryer won't start
Jan 22, 2009 | Dryers
Needing 15-20 year old apartment sized dryer belt.
go to a Maytag service agent
even the unit is old , there is a good possibility that the belt is still in use or was discontinue recently and they may have spares
Aug 19, 2017 | Zanussi TC180W Electric Portable Dryer
Dryer wont spin
Take the back off  of the drier after unplugging and the beklt goes from the motor pully all the way around outside of the the drum.You can't miss it. Most of the Kenmore drier belts are the same. WE have apliance repair parts stores locally.If you also do , go to the store with the old belt and match it up.
Dec 19, 2008 | Kenmore 63942 Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
