Question about Audiovox RCA EZ1000 Digital Camcorder EZ1000
I have two small wonder EZ1000A cameras. One of them will not read the minisd card. It says incorrect format when the camera is turned on. RCA said to reformat the mini sd card which I did. That didn't work. I also bought another micro sd card and had the same problem with it. The other camera(same model) reads the sd card fine, it's problem is that it will only turn on if I take the batteries out and put them back in.
3 Suggested Answers
SOURCE: RCA Small Wonder ez101
You can't. The slot on the top is for "authorized retailers" to dock the unit to create CD/DVD from the video.
http://www.mysmallwonder.com/support/ez105FAQ.aspx
I own one and also could've sworn the documentation (long gone) stated it could be used this way, but the RCA site says no.
Posted on Jul 06, 2008
  • 1575 Answers
Hi
Lets review some probable causes
  • On the memory card at the side is a slide for 'opening or closing' the card.Slide it to 'open'.
  • Make sure the card you are using is supported.i.e. your camera can support the size of the card.
  • It could be a defective card you are using.Try another card.
Posted on Jul 02, 2012
RCA Small Wonder
Hi
Jul 01, 2012 | Audiovox RCA Small Wonder Digital...
Lost my ac dc adapter need new one for rca small wonder camcorder
You can try www.ebay.com. I found the following AC adapter for the RCA Small Wonder camcorder:
http://cgi.ebay.com/RCA-EZ209HD-Small-Wonder-camera-CHARGER-AC-ADAPTER-/140516900106?pt=Batteries_Chargers&hash=item20b775bd0a#ht_1469wt_723
Mar 01, 2011 | Cameras
I got an RCA small wonder 1000EZ camcorder. I came with a micro sd adapter. How do I install it?
The micro sd card goes into a card slot located on the top of the camera under a little rubber door, and the memory card will only fit in it one way.
Sep 30, 2010 | RCA Video Cameras
I loaded my computer using Manager instructions
Does this camera use a memory card? If so, try using a separate card reader to download your pictures.
Sep 06, 2009 | Cameras
Olympus xd card formatting problems.
If you like the camera and XD cards then I would use the USB cable to download the photos from the camera. When you plug the USB cale into the camera and then into the computer, the computer should recognize the camera and set it up as another disk drive. Copy or move the pictures from the card to your Photo location. Use the "Safely Remove Hardware" icon in the system tray to disconnect the camera and your done. The camera can format the XD card and the computer can read it through the camera.
May 28, 2009 | Olympus FE-340 Digital Camera
Card error
Try turning off the camera. While it's off remove and reinsert the memory card. If the same message appears, you should re-format the memory card. CAUTION: Formatting the memory card will delete anything on it. Copy the files off of it before formatting.
Here is your manual:
http://support.casio.com/pdf/001/EXZ60_e.pdf
Apr 28, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
7D and CF2 Card Problem
I know it says to format the card in-camera but have you simply tried to use the card with the computer format? I have several 4 Gb cards for my camera (7D) and I have occasionally used the computer format without noticing any problems. Maybe you'll get lucky too.
Feb 12, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
SD Card Stuck
There are only two types of SD cards. MiniSD and SD. No matter what brand of SD card you buy they are all the same size and compatibility and same thing goes for the MiniSD cards no matter what brand MiniSD card you buy they are all the same size and compatibility. It is the wonders of standardization, anyone that uses the SD or MiniSD name they must produce all their cards to certain specs. I know you did not buy a SD card and try to put it into a MiniSD slot, that is impossible (unless you used a hammer). The card just got stuck, or maybe you put the card in the wrong slot? My camera's ION battery looks close to my SD card. Anyway your going to have to remove it and you are going to have to use force if needed. I would use needle nose pliers (just don't squeeze THAT hard) use just enough force to pull it out and try not to wiggle it out.
Aug 31, 2005 | Canon PowerShot A520 Digital Camera
"Memory card cannot be read"
My camera used to do the same thing--once I got the pictures off my card, I left it in the card reader, right clicked on removable media (my computer + removable storage) chose to "format" and formatted it on my computer. It seems to have fixed the problem, and my camera now reads it fine. I tried to format it on the camera before, but it didnt work.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Audiovox RCA EZ1000 Digital Camcorder EZ1000 Logo
99 people viewed this question
Top Audiovox Video Cameras Experts
NOEL
NOEL
Tony Parsons
Tony Parsons
Are you an Audiovox Video Camera Expert? Answer questions, earn points and help others
