When trying to copy or scan on my HP Photosmart C4400 printer I recieve a large black line down the document. This only happends when using the scanner.
  • 312 Answers
THERE IS A DUST PARTICLE LODGED ON THE PIECE OF GLASS ON THE SURFACE SCANNING SECTION OF YOUR SCANNER. The scanner section has a long 8 1/2 inch or longer piece of glass that is about 3/4 of an inch wide. Clean the piece of dust or whatever off of it and the line will go away.
I normally use a cotton swab with alcohol on it and get it off .
Good Idea is to clean the whole piece of glass off from time to time.
I hope this has been a help to you.
Best Regards,
Mark
Posted on Dec 30, 2010
My printer has new carthridges prints from computer but does not make copies
Try scanning from MS Paint or Acrobat & see if it works. If it does, the HP/Vista software is probably at fault. If not, the scanner is probably faulty.
Did it ever work or did you just plug it in? (Did you load the correct drivers?)
Apr 22, 2014 | HP Photosmart C4400 series
My hp photosmart c4400 wont make copies
Printer will not work without Color cartridges. You need to install color ink even if your using Black print only.I work for HP but my posts and replies are my own.
Make it easier for other people to find solutions, by marking my answer with \'Accept as Solution\' if it solves your problem.
Click on the BLUE KUDOS button on the left to say.Or Still having Problem Then follow Us For
HP Support "Thanks"
Apr 22, 2014 | HP Photosmart C4150 All-In-One InkJet...
On my Photosmart 2575 all in one printer when I scan documents there is a large black line down the center. I can't figure out what's wrong. Help?
if you scan so many documents the inside of the glass or the printer is full of dirt from the inks.So you have to open it and clean it very well especially the glass.Maybe you have and a strange sound...
Jul 04, 2010 | HP Photosmart 2575 All-In-One Printer,...
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
Scan image is not its actual size
Check the following. Open your HP solution centre, settings,scan settings, Scan picture settings or scan document settings. on the right hand side youll get scan pic setting again and check the setting in that box. Check also settings print settings, printer settings, check here for print or scale size
Aug 15, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Nov 15, 2008 | HP Photosmart 375 InkJet Printer
Black lines when scan and copy documents
It is because coping is not the best way to get a perfect copy on the printer, Try scanning with computer using black and white photo it will come out much better if you are doing a pic. then use color picture.
Feb 17, 2008 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart 3313 All in Printer
Hi, I really appericate all your efforst. You can try the steps in the below webpage to fix the issue. Here is the weblink: =========== http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00410921&cc=us&lc=en&dlc=en&product=439491&dlc=en&lang=en =========== Just click on the weblink or copy the entire weblink and past it in the address bar of the internet explorer and press enter this will open a webpage with title" HP Photosmart 3200 and 3300 Series All-in-One - Copies, Faxes, or Scans Have Vertical Black Lines" this sould fix the issue.. Regards, Barret.
Sep 06, 2007 | Office Equipment & Supplies
125 people viewed this question
jasbo
jasbo
