Question about Sport & Outdoor - Others
Auger on snowblower turns sporadically and results in snow not being blown. Could it be the shear pins?
  • 293 Answers
It is most likley the gearbox. The bronze gear fails from not being greased. If the shear pins sheared, it would not work at all.
Sorry, but hope you can use this info to remedy your problem.
Matt
Posted on Dec 31, 2010
I have a Yamaha ys 626 snowblower - how do I fix a non moving auger?
Most snow blowers have a "shear pin", (or roll pin) that links the auger to the drive shaft. It is there in case you strike something hard with the auger. The shear pin will break and protect the auger, the engine, and the operator. The shear pin can be purchased anyplace that services snow blowers, and it can be replaced by the owner.
Jan 10, 2015 | Garden
How to change shear pin
With the motor OFF, the shaft shouldn't rotate, so you should be able to rotate the auger by hand until the holes line up.
Mar 01, 2014 | Craftsman Sears Snow Thrower Manual Model...
Mtd yardmachine snow blower 305 cc auger wont turn
This is a fairly frequent problem that is easily fixed. What happened was the snowblower's auger was either overloaded or got jammed (ice, debris - something other than snow). Rather than twist, damage or break the auger itself, an inexpensive part called a "shear pin" is designed to fail. A shear pin employed between the auger sleeve and drive shaft that is inside the sleeve. You may have broken one if one side of the auger spins) or both (if both sides of the auger spins). Purchase several replacements for your particular machine to have on hand. Do NOT replace s shear pin (or shear bolt) with a regular bolt under any circumstances! Check the video linked below on how to replace the shear pins. Good luck!
Feb 09, 2014 | Yard Machines 28" Two-Stage Snowthrower
Rear auger turns front auger not turning
From your information above, it sounds like a broken gear or tooth on the auger gearbox. (this could happen if you hit an object and your shear pin did not break, instead breaking your gear) Hope this helps.
Jan 25, 2014 | Simplicity I924E 2-Stage Snowblower...
Right side of snowblower is constantly clogged with snow
Check the R.H. auger my guess is you have a shear pin that has broken and needs to be punched out and replaced. If it rotates freely (cleaned out of snow) then that's likely your problem. You can prove that by watching the shaft the auger is riding on if the shaft moves with the auger shear pins ok. If the auger moves seperate from the shaft the shear pin is at fault.
Feb 21, 2013 | Ariens Garden
Swisher 27" snowblower front impellers turn free
Hi Craig,
Most snowblowers incorporate "shear pins" between the motor and auger. A shear pin looks similar to a nut and bolt or pin that couples the drive to the auger - but it designed to break or shear off to prevent damage to the auger or motor in the event of a jam or overload. They look like these:
Only the shear pin recommended for your particular brand and model snowblower should be used. Under no circumstances should a regular bolt or other steel pin be used instead of a shear pin. Check your manual or consult with Swisher to determine the correct shear pin for your snow blower.
I hope this helps & good luck!
Dec 21, 2012 | Garden
I have a new Troy Bilt Snowblower. My father ran over a large extension cord while blowing snow, which in turned wrapped the cord around the auger shaft ends. I can now only get one side of the auger to...
Your snowblower has 4 shear pins keeping the front auger safe. Use the manual to locate them if you are unsure where they are and how to change them. Since your snowblower is new I am going to assume you have the manual.
Your snowblower came with 2 spare shearpins. Check up by the handles and see if they are still there. If you don''t have them go to your local Lowes, Sears, or MTD repair shop to get new ones. DO NOT USE STANDARD BOLTS!
The drive shaft coming out of the gear box is one, solid piece all the way across the snowthrower so if one side is turning there is a 95% chance it's the shear pins.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 11, 2011 | Troy Bilt 5.5hp Self Propelled Mower
HALF OF AUGER NOT WORKING
When you got something caught in the auger, the shear-pin probably did it s job and broke, to save the gear box. Remove the old shear pin and install a new one
Mar 02, 2009 | Craftsman 16" High Garden Tractor Snow and...
Sport & Outdoor - Others Logo
69 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
