Question about Logitech Harmony 1000 LCD Touchscreen Remote Control
Programming compatibility Can I use windows vista home to program this remote
  • Anonymous Dec 20, 2008
    Vista does not recognize the Harmony 1000 remote, it searches for alternative drivers, does not find any, even if I prompt to the disk
    Problem Solver:
  • 19 Answers
Yes, here is the link to the software: http://www.logitech.com/index.cfm/440/373&cl=us,en?osid=13
Posted on Jul 09, 2008
Will not function with Windows 7, what is wrong?
Not all programs that worked in Windows XP will run in Windows Vista or Windows 7.
I suggest you try compatibility mode to see if it helps.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1) Right click on the Program
2) Click on Properties
3) Click on Compatibility tab
4) Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
If the compatibility is not successful, then try and runthe Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking theStart button.
Then click Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, clickRun programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
If you run Windows 7 Professional or Ultimate version, install Windows Virtual PC and Windows XP mode (http://www.microsoft.com/windows/virtual-pc/default.aspx) and execute your software in Windows XP.
If you run Windows 7 Home Premium, try VirtualBox (www.virtualbox.org) or VMware Player (www.vmware.com) and install a separate copy of Windows XP (either Home Edition or Professional) for that purpose.You can find virtualization software free of charge that will run on Windows 7 Home Premium.
Hope this helps.
Oct 28, 2010 | MGI Software PhotoSuite 3 for PC
Is there a scrapbooking program that will work with windows Vista?
Hello dmozao, There are a few scrap booking programs that will work with Vista. If you already have the Scrapbooks Plus you may want to try running it in compatibility mode. To change the mode do the following:
  • Right click the programs icon
  • Select Properties
  • Select the compatibility tab
  • Check the "Run this program in compatibility mode" box
  • From the drop down menu select Windows XP
  • Click Apply then Ok
  • Try running the program again.
The compatibility mode has helped me save some money in the past. If this solution was helpful then please rate it. If not, reply back and I will list a few native Vista scrapbook programs. Thanks, Edward
Aug 22, 2010 | IdeaSoft Scrapbooks Plus (727298900149)...
Can I run Printmaster Platinum 16 with windows vista
Yes you can !!!
The Windows® Vista2_bing.gif Program Compatibility Wizard can allow older programs that were not designed for use with Windows® Vista to run on Windows® Vista.
The Program Compatibility Wizard prompts you to test the program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows® XP2_bing.gif, set the compatibility mode to Windows® XP and try running the program again. If successful, the program will start in that mode each time. The wizard also allows the use of different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
To run the Program Compatibility Wizard, complete the steps below:
  1. Close all programs and windows and return to the desktop.
  2. Click the Start button on the Windows® taskbar. The Start Menu will appear.
  3. Click on Control Panel. The Control Panel window will appear.
  4. Click on Programs. Additional program options will display.
  5. In the Programs and Features section click the link Use An Older Program With This Version of Windows. The Program Compatibility Wizard will launch.
  6. Click Next to Continue.
  7. Click the “I want to choose from a list of programs” radio2_bing.gif button and click Next. A list of programs will display.
  8. Select the program that is to run in a Compatibility Mode and click Next to continue. A list of Compatibility Modes will display.
  9. Click the radio button next to the desired Compatibility Mode and click Next. A list of display settings will display.
    NOTE: These display settings are not available options in Windows® Vista. They are only available when running a program in Program Compatibility Mode. The only reason to choose either of these settings is if you are experiencing difficulty installing or running an older application designed to run in Windows® 95, Windows® ME or Windows® 98. If all options remain unchecked, then the current Colors and Screen Resolution settings will not be altered.
    By default, Windows® Vista uses visual themes that may change the appearance or behavior of other programs, especially those games or educational programs that include intensive graphics and animation. To prevent the visual themes from affecting these programs, check Disable Visual Themes.
  10. Choose the desired display settings and click Next to continue. Administrator privilege options will display.
  11. Choose the desired administrator privilege setting and click Next to continue. A Test Your Compatibility Settings window will display.
  12. Verify that the settings are correct. And click Next to continue.
    NOTE: If the settings are not correct, click the Back button to return to the previous screen (or screens) and make the necessary changes.
  13. With the correct settings selected and showing in the "Test Your Compatibility Settings" window, click Next. The selected program will launch.
  14. Run the program to test the settings.
  15. After testing the settings, or close the program to return to the Program Compatibility Wizard.
    NOTE: After the program is closed, a window with the question "Did the program work correctly?" will appear. The "Yes. Set this program to always use these compatibility settings" will be selected.
  16. If the program functioned properly using the compatibility mode that was selected above click Next. The Program Compatibility Data window will open.
    NOTE: If the program did not function correctly, click "No, try different compatibility settings" and complete the Wizard. After completing the wizard, try the program again.
  17. Choose Yes or Now and click Next to continue. The Completing the Program Compatibility Wizard window will appear. Click Finish to close the window.
  18. Launch and use the program.
NOTE: If you have questions regarding the Program Compatibility Wizard or Windows® Vista (or both), contact Microsoft®, or go to http://www.microsoft.com for additional information
Mar 31, 2010 | Broderbund PrintMaster Platinum 16
UFT seems to run with Vista but odd screen
Some XP programs incompatable with Vista; you may have to upgrade UFT...had this prob with a lot of my high $ programs....loaded XP on 2nd HDD, and use it for non-Vista compatable programs.
Mar 20, 2010 | The Learning Company Ultimate Family Tree...
WINDOWS VISTA LIVE SAFETY SCANNER
vista safety scanner is compatible with all version of vista OS. there are no issues about it.
Feb 17, 2010 | Microsoft Windows Vista Home Basic for PC
I have installed a windows program on my computor only to find that it will not run on my vista program is there a patch to allows this to happen?
check the program's website for compatibility issues. see the "system requirements", and also check if your windows vista is 32 or 64 bits.
Aug 28, 2009 | Microsoft Windows Vista Ultimate Edition
Running c graphics program in windows vista
Maybe try to put the completed exe on the desktop.
Then click to the program with the right button and then
set the Windows compatibility mode.
Jan 09, 2009 | Microsoft Windows Vista Ultimate Edition
I am trying to move my Bookkeeper program to a new Vista Computer. I am getting a message that I am trying to run an older version of Bookkeeper with newer pogram. My old computer is XP and the new one...
Most programs written for Windows XP also work in this version of Windows, but some older programs might run poorly or not at all. If an older program doesn't run correctly, use the Program Compatibility Wizard to simulate the behavior of earlier versions of Windows.
• Open the Program Compatibility Wizard by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
NoteTo find out if your programs (or programs you plan to buy) are compatible with Windows Vista, go online to the Windows Vista Compatibility Center. This website contains a comprehensive list of programs, computers, and devices that have been tested to work with Windows Vista.
Oct 24, 2008 | Computers & Internet
I am trying to install my software on my new computer, ia the Windows Vista
Read the system requirements of the software...if it is software made for another operating system ..... Most programs written for Windows XP also work in this version of Windows, but some older programs might run poorly or not at all. If an older program doesn't run correctly, use the Program Compatibility Wizard to simulate the behavior of earlier versions of Windows.
Oct 23, 2008 | Computers & Internet
QV ver6 (Win 95/98/NT) compatible with Vista?
If you right click on the shortcut and go to the Compatibility tab you can check the Run this program as an Administrator option. This worked for me.
Jun 23, 2008 | Parsons QuickVerse 2005 Expanded Edition...
Logitech Harmony 1000 LCD Touchscreen Remote Control Logo
41 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
