Question about Refrigerators
I have a Kitchen Aid wine fridge KUWA244PSS0 that will not run. I started taking it apart and noticed alot of dust buildup on the coils. What probably is not working and how should I proceed fixing it?
  • Refrigerators Master
  • 2,605 Answers
Welcome to FixYa.
I suspect by your description the fridge either has a faulty overload protector or the compressor itself is seized. This is typically a by-product of the coils becoming clogged thus creating overheating of the start device on the compressor.
If you feel like you can trouble shoot further I`ll try to assist you or you may decide to call a professional appliance technician.
I don`t know the age of your fridge, but I should mention...
** Most of the Whirlpool built fridges have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay. Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to Whirlpool/Maytag/Amana/Kitchen-Aid.**
If you have a multi- meter you can check the compressor to see if the windings are ok.
**First, Unplug the fridge**
Remove the panel at the back down at the bottom. This should gain you access to the compressor.
On the side of the compressor will be the start relay/overload assembly such as this image...it may be enclosed in a black plastic cover as well.
Pull off the relay & overload and you'll see 3 pins in the form of a triangle...
With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin.
You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms.
On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good !
If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit.
i.e.
The above package contains info and hardware on how to connect it.
**NOTE : the HS410 ( 3 in 1 ) should be considered just a temporary "fix" as opposed to an actual "repair" in should not be relide on for long term reliability or safety, but rather the factory replacemnet part 8201786... i.e.
The above start device kit contains instructions on "how to" install kit. Cross reference with your model number when contacting a parts depot to be sure.
Hope that help`s move you forward if nothing else. If so please take a second and rate the reply and a testimony to your inquiry you received here at FixYa.
Thank you and good luck.
Regards,
Macmarkus :)
Posted on Dec 30, 2010
Danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes.
Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
Sep 26, 2016 | Danby Silhouette Dual Zone DWBC14BLS 13.90...
Freezer not getting cold and dripping water
I own a similar Kitchen Aid fridge that had a defrost icing issue: Kitchen Aid KSRP25FNBL00
> Ice had plugged the drain hole at bottom of chill coil section inside the freezer compartment.
> I learned that the coil, circulation fan was not working, but condenser was working.
> I paid a tech to replace the circ fan, about $200, including a new swiss-made fan. He said it was unusual for these fans to fail, but not unheard of.
Expensive, but saved the purchase of a new fridge. Has worked great for 6 months since then.
HOpe that helps.
Al Zayha
Mar 09, 2014 | KitchenAid (KSRD22FKST) Side by Side...
KITCHEN AID SIDE BY SIDE KSRP25FSMS01 We first niticed the freezer and fridge not being cold enough, then it stopped making ice. The freezer would not freeze things but still felt cold. I cleaned the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 18, 2010 | KitchenAid Refrigerators
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to...
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to defrost.have not plugged it back in yet.but in the freezer behind the panel there was ice build up to the right of the evaporator fan on the plastic scroll.i cleaned that upturned it on and noticed that there was very little air coming through the top air scoop vent in the fridge side.when I open the freezer door it allows more air though(probably to compensate).anyway I read alot on this issue and some say it's the defrost timer boardsome thermostat.the compressor stays pretty hotbut the freezer works fine.please help.
Jul 07, 2010 | Refrigerators
Kitchen aid KSRG25FKSS04 freezer is not freezing
Hello, few things to check:
1) Remove dirt / dust that has accumulated on the condenser coil located on the back of the fridge, or underneath. Use a vacuum to clean off with.
2) Remove dirt / dust in / around compressor area. Make sure you turn power off first as there are several areas in this area that can "bite."
3) Look for heavy frost / ice buildup in the freezer compartment. Defrost if necessary.
4) Make sure the fan is blowing in the freezer compartment.
5) Make sure there is air flow from the vent at the top of the refrigerator compartment. This air is driven by the fan in the freezer (most models).
6) Loading a lot of unfrozen food into the freezer compartment will have the appearance of the fridge going out, but is actually functioning normally as it removes heat from the food so it will freeze.
7) Your thermostat is not working correctly. Move it to the coldest setting if not already done so. Listen for the compressor to kick on. If it doesn't, bad t-stat.
Thanks
Jul 12, 2010 | Frigidaire FRS26KF6E Side by Side...
My fridge is working fine but my freezer is not keeping the food frozen it is a kitchen aid side by side any help?
Cleaned the condensor coils? If not locate the coils either underneath (open both doors and remove the toe kick) or in the rear (remove the back panel). Use a vaccum or long brush to get any dust, hair or debris off these coils. These coils are allowing the refrigerant to cool down and if hair or dust is all over them they cant release the heat efficently. This kind of stuff will insulate the coils and the heat cant escape or release. Otherwise you are dealing with a freon issue. If the unit is running but not cooling correctly anylonger it probably has lost some freon and will continue to lose it. Hopefully this helps.
Jan 24, 2010 | Nor-Lake Norlake Refrigeration 4' x 6'...
Need to relace thermostat on kitchen aid wine cooler kuws246ebl2
Hi, The silver thing is not a wire. It is the sensor tube for the thermostat. The new thermostat will come with the sensor. Be sure and notice how and where the sensor goes in the wall. I hope this helps
Vic
May 20, 2009 | Refrigerators
Divider strip between fridge and freezer is hot
First take the grill off at the bottom under the doors look at the grate under the frig That is your condenser it will probably be covered in dust clean it off the see if you can fill air blowing under the frig there is a fan under there that keeps that coil cool and it runs around the door to keep condensation from build around the doors if no air is blowing take the back panel behind the Frig and there should be a fan running if the compressor is running this will also cause the compressor to over heat and will not cool as well but it might just need to be cleaned Good luck
Apr 03, 2009 | KitchenAid KSRG22FK Side by Side...
Kitchen Aid Fridge
how long does it take for fridge to cool if its not been used in months?
Nov 23, 2007 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Kitchen aid superba fridge not cooling
Check your evaporator fan, defrost thermo., or defrost heater. One of these parts out are what causes ice to buildup on your evaporator.
Sep 01, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
146 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
