Question about Magellan RoadMate 1440 Car GPS Receiver
When i turn my gps on the little ciircle thing that spins goes around one and a half times then stops the in a minute or so a picture of a computer with i guess a cable goin to a usb symbol then that has a cable goin to a picture of a gps with a x through it what does that mean if it means update it! how do you do that
    Problem Solver:
  • 19 Answers
You have corupted data on the gps./
send it to service
Posted on Dec 30, 2010
Washer stops during normal wash cycle for a minute or more, and then continues. Would replacing the timer fix it?
If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
May 23, 2014 | Whirlpool Washing Machines
Freezer does not freeze at top half and fan stopped working
your full freezing system is gradually damaged.
Mar 21, 2013 | Daewoo FRSU20IA Freezer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Tv won't come one and blinks red 7 times then stops.
When the bottom half of the picture goes out this usually indicates a failure of the lower Y driver module. When this module fails it will often take out the Y sustain module and when that happens the set goes into over current shut down. Both boards will have to be replaced. All of this is assuming you have a Plasma set and not a LCD flat panel.
Jun 02, 2009 | Philips Televison & Video
I have a Garmin C330 and it wont turn on, what can I do?
One thing you should try if you havn't already is to push the reset button. This button is hidden under the thin frame around the screen. Look carefully and you will see a little half moon cut in the frame. Slide your finger nail under and carefully pry the frame up a bit then work your way around the frame lifting as u go. Now look again and you will see the reset button.
Mar 22, 2009 | Garmin nuvi 350 GPS Receiver
Message problem
That sign is GPRS go to network seting and stop GPRS
Feb 05, 2009 | Nokia 7373 Cellular Phone
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
3 years ago, i had the same problem with a samsung 36", when i switched it on it would stay on for around half an hour, i tried to switch on straight away, but it wouldnt, i had to leave it for an hour or so, then it would stay on for about 5 minutes. And the same thing the next day (half an hour then 5 minutes). I left it into the repair shop, it had to get a circuit board replaced at a cost of £315, dont know how much it will cost to get fixed now, as i could buy the same tv for a little over that now.
Apr 14, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Mitsubishi 57" HDTV - has sound and timer light flashes
I had the same problem and my local repair guy soldered a defective sensor so that it goes around that problem. I also had to buy a new bulb. Now my picture is "cloudy" and the repairman has no idea why. I am waiting for them to call back on it.
Mar 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Spins and then does not spin, I have to coax it by moving the drum???
Becca, your washer has a "delay" built into the timer in the final spin cycle. This is called a "neutral drain" setup. Here's the scenario...
The drive motor has 2 directions, forward and reverse. This affects the transmission the same way...forward= Agitate, reverse= Spin. However! On yours, when it goes into spin, the transmission doesn't engage immediately. (This gives the machine time to drain the water out before it spins. Water is heavy... 8.6 lb's/gal. When you have 20 gal's of water in the tub that's 172 Lb's! That's alot of weight for the motor to spin up, so they designed it to get rid of all that weight first.)
The way the washer does the neutral drain is a combination of two things. Here's how;  The timer will get to the spin cycle (reversing the motor, engaging the water pump, and placing the transmission into "neutral" [<---I'll get to that in a minute]. Then after 8 or 9 minutes draining, the timer will PAUSE for about 5 seconds, then re-engage. This "pause" feature shifts the transmission from "neutral" to "reverse" so it will spin the clothes.
Your problem could be one of the two. Timer not "pausing". OR transmission not shifting out of neutral.
The timer is out of warranty if it's over a year old. Runs about $200 for replacement (or around $130 if you do it yourself). If the transmission is the cause, it's under warranty for 5 years.
The problem you're facing is getting an accurate diagnosis as to which of the 2 components is the cause. The symptoms you describe would lead me to the transmission first. The neutral pawl in the tranny has failed and is not engaging the reverse gear would be my first impression.
Test this... place the washer timer at the very beginning of the Spin/Drain cycle on the "Heavy" cycle. Pull the knob and let it run. Monitor it closely with your ears. About 8 minutes into the drain, the timer should pause for a 5 seconds or so, then start up again. Listen for the "pause" (machine stops completely, no noise). If it does, the timer is OK. If it pauses, restarts and the transmission doesn't engage? It's a failed transmission..
I know this is probably not what you wanted to hear, but if I'm accurate in my blind diagnosis would you please rate my response?
BTW, if it turns out to be the timer, I can walk you through the replacement of it.
Oct 15, 2007 | Kenmore 15864/15862 Top Load Washer
Magellan RoadMate 1440 Car GPS Receiver Logo
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
