Question about Craftsman Nailer Kit, Palm Air Driver
I have a craftsman 18g Model 351183100 brad nailer that I need to replace the bumper in. Sears Direct says that they are no longer available and no after market ones are suggested. Any after market makes available for this part? Thanks in advance. Frank
3 Suggested Answers
  • 163 Answers
SOURCE: bought Craftsman electric brad nailer
You should be able to get the instruction manual from www.searspartsdirect.com just enter in the model # of your kit.
Posted on Apr 05, 2011
Looking for a on/off switch for a craftsman 8" bench grinder
Sears Craftsman is usually easy as Sears Parts Direct has diagrams and part numbers.
However your switch number 31919063033 is no longer available. I would suggest checking out online places like Digikey or Newark for a switch that will work for you. As long as the Voltage, amperage and number of poles and will fit in the space provided you should be OK.
Link to Sears Parts Direct.
Searching Model For Search Your Way 31919063 2
Link to Newark
Switches Relays 60 674 Products Found
Link to Digikey
Electronic Components
Aug 19, 2014 | Craftsman Grinders
Craftsman evolv braid nailer leaks air around the trigger when i try to nail. it does not nail sears no. 00915206000 mfg no. 42081 (for kit) on gun model:6G28/F50
Air leaking from trigger when trying to nail indicates that the headvalve is stuck or headvalve orings are dry and allowing air to pass. Remove the head and pull out the headvalve piston. Examine orings for cuts or broken (replace as needed if orings worn and cannot make seal). If headvalve was stuck/dry, lube with plenty of silicone paste lube (sold at Lowes in the plumbing dept. ). Should be good to go. Good luck
Jun 30, 2011 | Craftsman 184060184070184080 Brad Nailer...
I have a craftsman 16 gauge finish nailer, model 918441. it is not advancing the nails. not certain how to adjust. cannot find the manual. is the manual available on line?
Assuming that the nails are correct for gun (16g nails measure .055) and feeder is actually applying pressure to nails (feel spring pressure as you close clip), most likely problem is driver is not returning to top of cylinder. This is caused by low pressure to gun, bent driver, lower bumper missing pieces/cracked, worn oring on piston or lack of lubrication. Remove cylinder and examine condition of lower bumper, replace if broken/cracked; check outer cylinder for check valve in place (usually small band or oring covering series of ventholes) ; replace piston oring as needed, make sure driver not bent. Parts available at sears web site. Good luck
Sep 08, 2010 | Craftsman Tools & Hardware - Others
I need a piston stop part#4357.00 craftsman 16 gauge finish nailer model # 351.183210, im told by sears part is not available, any other finish nailer with the same part?
same thing here, I believe it was made by porta cable looked at their nailer, looks the same trying to get that part should be around $14 plus shipping
Jul 29, 2010 | Craftsman Garden
Craftsman nailer striker is stuck down after firing.
my porter cable nailer does the same thing. what is the problem
Jan 26, 2010 | Air Tools & Compressors
Need a manual for craftsman 18 ga comb
go to sears.com where all of these manuals are found in downloadable form.
Oct 29, 2009 | Air Tools & Compressors
My Sears Craftsman 18 gauge brad nailer won't nail unless I release the nails from supply, remove the front cover, slide up I think it's called a striker, then replace the cover, re-set the supply and...
Your driver is not returning. Depending on the model that you have there could be a couple of problems. The most likely is that your piston stop is crumbled and some of your seals are worn or damaged. Whether or not you can fix the nailer depends on if the parts are available from Sears Parts Dept. If you would like some more information about fixing your nailer please post which model it is that you are trying to fix and I can see if the parts are available. I will post the information back to you.
Oct 12, 2009 | Tools & Hardware - Others
Craftsman Nailer Kit, Palm Air Driver Logo
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
