Question about Dell M782P Monitor
Sir my name Imran Akbar. I have a dell m782p monitor.Sir my monitor is some time hanged.The power light on and green but no disply on screen.some time picture tube on and disply show but control menu is not opne, without control menu locked option.What i do? I have all tools instruments.
SOURCE: Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Posted on Oct 23, 2007
  • 32 Answers
SOURCE: Dell e173fp monitor power
These monitors are a pain to open up. The inverter circuit for the backlight is on the right side of the monitor when veiwed from the front, part is c5707(marked) or 2sc5707(actual part number) around $1, there are 4 of them, one or 2 usually fail. Sometimes this failure can cause damage to one or more of the corresponding transformers which can can be visibly be seen affecting(melted) the yellow wrap. Be sure to check for dry joints around the affected area as the boards are very badly made, primarily around these transistors and transformers or the fault could reoccur soon after the repair. The same fault occurs in the dell 19", part number is 2sc5706. I hope this helps you out.
Posted on Feb 26, 2008
  • 9 Answers
SOURCE: Monitor not turning on and no power- Dell E198FP
I am guessing you might have fried your monitor... i'm not sure
Posted on Feb 05, 2009
  • 1684 Answers
SOURCE: Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
  • 1684 Answers
SOURCE: Dell Monitor Problems
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 17, 2009
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Monitor light flickers on orange never goes to green.
Sir,
You are suggested to check if you serial cable is in fine condition and it properly pluged into the Monitor and VGA. and do also try changing the serial cable .
Aug 30, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Screen is blank
Two things in the problem one would be with the power supply unit another would be due to pins bent on the cable itself check those and make sure that is not the case.
OR there may b problem with ur system cpu. so check it by wellknown person also.
Aug 10, 2009 | Dell M782P Monitor
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
Monitor dosn't atart
Check SDL,SCL Path and It's related parts(Neck board PCB 2 MICOM)
check Output Voltages of SMPS
And also check dry points.
Oct 14, 2008 | LG Studioworks 700S 17" CRT Monitor
Monitor color changed
there may 2 problems
1 ) Problem with the Data Cable connector the Pins might be damaged try to arrange them if disturbed / bend . if Broken change the connector.
2) Open the monitor see the soldering carefully you can locate out the dry solders easily by seeing the flux colour around it . just put the solder over there..by soldering gun to all places where u can see the dry solder.
Sep 05, 2008 | Gateway FPD2275W LCD Monitor
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Assuming you can rule out the PC and the cable (are the pins ok?) then it sounds like it needs component-level electrical troubleshooting.
Jan 10, 2007 | Dell 17" Monitor
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
