Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Keeps on running but does stay at correct temp.
Bought used upright model# FFU149FF. Keeps running most of the time. Sometimes goes off but not for long. Door seals well and compressor looks clean.
What could be the reasons that would explain almost constant running?
Also what is the age of this model, and what is its efficiency rating?
    Sergeant:
    Champion:
  • 330 Answers
The automatic temperature switch probably out of order
Posted on Jul 08, 2008
I have a Kenmore Frostless Model #: 253.21041104 The temp. alarm keeps going off. The red light blinks and alarm goes off. Owners manual says that it is from warm conditions, but there are no warm...
Best thing to do first is get a thermometer to be sure the temperature is correct. Items still freeze at higher temperatures. If you have ice cream and it is soft, then you have a temp problem.
Jul 05, 2017 | Kenmore Freezer 13.7 cu. ft. Upright...
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezer will not turn on
Sounds like the sensor circuit may be open. Here is the problem, either it has a board that's bad or the sensor is out. Ohm the sensor circuit and record the temp the box is at in refrigerator and freezer. then the ohm reading. Contact manufacturer or representative of manufacturer, and ask what the sensor should read at the temps you have.
Generally if you get a reading on the sensor circut the sensor is ok, and the board is out BUT not always. this is why you need the temperature and the ohm readings. Sometimes the wire diagram has a legend with these reading on it. Look all around the underneath and behind sections for an envelope containing the wire diagram.
Apr 16, 2009 | Freezers
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore model 2539280412 upright freezer alarm keeps going off
might have a defrost problem check to see if it is building up with on the back panel if it is you need a defrost timer or limiter or heater or fan
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
280 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
