Question about Jenn-Air JJW8230D Electric Double Oven
It is showing a F8 in the window. Any ideas how to reset? It started when I tried to clean the oven. I have turned off the power but it did not reset. Thanks.
  • Jenn-Air Master
  • 1,902 Answers
Hello & Welcome to FixYa
F8 error refers to failed clock assembly/ electronic control board and replacing it is recommended repair. You can try to take it apart and then blow some compressed air on this electronic board, if the problem returns then the board needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Dec 31, 2010
I have a frigidaire wall oven which was on bake accidently hit clean and immediately hit cancel. Sounds like fan running and started beeping and F8 appeared. Turned off breaker and turned back on same
Hello - Typically error code F8 indicates that there is a communication error between the user interface and the control board. Try resetting the range by unplugging it or flipping the breaker off. Wait approximately ten minutes. If it proves to be ineffective, contact a professional to move forward accurately.
Nov 23, 2012 | Ovens
Self cleaning oven won't start
Hi bstetson328 - Try resetting the range by either unplugging it or flipping the household circuit breaker off. Wait approximately 30 seconds and turn on the unit. Select the self clean option, if it does not turn on then the temperature had tripped the internal sensor of the unit and needs to be reset. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside. Possibly the unit may have a communication problem with the EOC and I would suggest contacting a professional to move forward accurately.
Nov 10, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire double oven beeping and showing f8 code
there is a problem with the lock for one of the doors do they both close all the way or does one hit the latch. could be bent linkage or bad switch on lock or the control board has a bad relay on it.i need a model # to help any ferther
Dec 31, 2009 | Frigidaire 27 in. Electric Double...
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Frigidaire double ovens F8 error and beeping
good day,
hope this link below will solve your problem.
ovens
Mar 23, 2009 | Frigidaire PLEB30T8A Electric Double Oven
F8 code
It is a " Lock Switches" Display you can try to disconnect power and resetting. But it is possible with the power outage you may need to replace
Jul 24, 2008 | Kenmore 41389 Electric Double Oven
Beeping sound and f8 displayed
F8 means to replace the elctronice range control board. Evidently the power failure caused damage to the board.
May 24, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Gas oven is giving F8 error code
Unfortunately the F8 usually means an EEPROM data shift error. Try turning the power on and off several times. If error continues, you have no choice but to replace the ERC. Check on line for the best price. There is a group in the Chicago area that repairs ERCs. Check them out at www.cgiltd.com The failure of the your power system may have been associated with a surge either as the power went off or when it came back on. It may have been the surge that did the damage.
May 19, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Jenn-Air JJW8230D Electric Double Oven Logo
73 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
