Question about Philips 19MF337B/27 19 in. LCD Television
My Magnavox model:19MF337B/27 has to warm up for 20 minutes before I get a picture on any digital channel. I do get analog channels immediately. Any ideas?
  • 30 Answers
SOURCE: Vertical height adjustment on Magnavox 19 inch LCD HDTV
try to adjust at the vertical section.hope this will help
Posted on Feb 02, 2008
ramon49
  • 111 Answers
SOURCE: 47'' philips flat screen does not install channels
Go directly to theback of the set via the back RCA connectors(yellow, red, white) or component video, and turn set on Aux. If it works the tuner is Messed!
Posted on Apr 08, 2009
SOURCE: Local TV channels drop out after a few minutes
We're still hanging on by our toenails waiting for a helpful response from FixYa. We did contact Philips tech support and they basically said that we need a new TV...so they're sending one to replace this one, and we are sending back the "old" one (that we just bought in December '08).
Posted on Apr 10, 2009
  • 476 Answers
SOURCE: digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
Posted on May 19, 2009
SOURCE: Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Posted on Jun 02, 2009
I have the Phillips Magnavox 20MT133S and my cable TV provider is switching to an all digital format. Will I require the use of their converter box for analog TVs? In otherwords, is this TV a digital TV?
Hello David,
Unfortunately this is not a digital TV, so you will need a digital cable box in order to watch the digital format cable channels on this set.
Hope this helps. If you have any further questions, please let me know.
Regards,
BElectric
Feb 26, 2011 | Philips Magnavox 20MT133S 20" TV
I have a 19" magnavox
Do you have a digital converter box. If not, you need to get one to receive the analog channels.
Feb 06, 2011 | Televison & Video
How do we scan/program in local tv channels. We bought an external antenna, but get no picture. Typically, there is a protocol for scanning channels into the set. Model is Sansui TVS2746B, and the set was...
Okay, does this tv have a built in DIGITAL tuner? Most tv's only have an analog tuner. You can tell the difference while you are changing the channels. If the channel indicates 2.1 or 2.2 and so forth, it is on a digital channel mode. If you change the channel and it indicated 2, 3, 4, etc. it is analog. If it has digital capability change the input until you see 2.1, 3.4 etc. If you cycle through all the inputs on the tv like, input 1 (TV) input 2(DVD) input 3(HDMI) and so forth and you never see the digital channel you most likely do not have a digital tuner. You will need to purchase a digital converter which will convert it to analog and you can watch it by placing you tv on analog channel 3 just like the old vcr's. Hope this helps and please don't forget to rate this solution.
Jan 22, 2011 | Samsung TSL2793HF 27" TV
Channel tuning 1994 Magnavox 27'' TV
U the remote to turn to the channel 3.
Nov 18, 2009 | Philips Magnavox 27MS343S 27" TV
My t.v. will not auto install the channels with my antenna.
Try the link.It may help.
http://www.ehow.com/how_2378904_ready-change-digital-tv-broadcast.html
Jun 01, 2009 | Philips Magnavox 27MS343S 27" TV
STB with Magnavox remote (need codes) - Samsung #TXK2766
Did extensive checking and finally found out that the remote for Magnavox TB100MW9 analog/digital converter is not made for volume control. The channel changing buttons are half-way operable--sometimes yes, sometimes no--and to think they call this a remote! Therefore you must keep the other TV ready remote that you have been using (tape them together probably) for volume and mostly channel change. I know what Magnavox can do with these remotes - and you know how much more Magnavox I will be buying in the future. Nada, none,---from a very disappointed, frustrated customer.
Feb 12, 2009 | Samsung TXG2746 27" TV
TB100MW9 DTV DIGITAL TO ANALOG CONVERTER
I assume you are attempting to connect another device to the set.
Selection of the output channel is normally accomplished from the external device, not the set.
Jun 30, 2008 | Philips Magnavox 27MS343S 27" TV
Trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Jun 27, 2008 | Sanyo DS27910 27" TV
Fuzzy pictuore
It's maybe because you are an idiot. "P-i-c-t-u-r-e.
Jun 08, 2008 | Televison & Video
Magnavox hdtv
The Magnavox 27MS343S is a standard analog 27" TV. It is not high definition and therefore cannot generate a posterized or pixelated picture. I will bet you are using a digital cable box or satellite reveiver and the problem is in that box, not the TV. Hook up a regular VCR to the TV, set the TV to channel 3, put in a good pre-recorded tape and hit PLAY. If the tape plays nice and clear on the TV, the problem is in your digital box.
Sep 07, 2007 | Philips Magnavox 27MS343S 27" TV
Philips 19MF337B/27 19 in. LCD Television Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
