Question about Kenmore 22422 Top Load Washer
I've had my Kenmore 800 for less than 2 years and it just started acting up. It works great until it get to the end of a cycle. After it spins, it will add about 2 inches of water and be finished. Why is it adding water at the end?
  • 1 more comment
  • lilsmitty16 Dec 31, 2010
    Hi Rich, thanks for being so speedy. The model number is 110.29822800. We just ran the wash on a double rinse and it didn't leave water in the bottom, if that helps. ~Liz
    Thank you so much Richard! I went ahead and ordered it. Have a great New Year!
    ~Liz
  • lilsmitty16 Feb 12, 2011
    We finally put the new water inlet valve in and it fixed our problem! Thank you so much for your help! I tried to find where I can rate you/leave comments and I can't find it so I'm just going to leave it here. Richard get 4 thumbs up from me.
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Sounds like you need to replace the water inlet valve. What is the model number displayed under the lid?
Posted on Dec 30, 2010
  • Richard Roth
    Richard Roth Dec 31, 2010
    Sounds like the "water inlet valve" has an intermittent problem. Yours is showing signs of failing and when they go out, you will find the water won't stop filling even if the machine is off. You would have to cut the supply off at the wall. If you should decide to replace the valve, here is the part you will need.
    Regards,
    Richard
  • Richard Roth
    Thank you! You have a great New Year also!
    If you get a chance, please some feedback for me on this site. I would greatly appreciate it.
Spin vibrations
Make sure the legs on all four corners are down tight and even level the machine with this 4 pads. If the machine is level it will vibrate less, and then not all machines are completely quiet when working, especially on spin cycle..
Jan 22, 2014 | Kenmore Washing Machines
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore model 41743142200
Un plug washer remove belt by lossing the tensioner , bring to appliances center and assemble again /
Jan 07, 2008 | Kenmore 45081 Front Load Washer / Dryer
Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Heavy Duty Washer
Whirlpool is still made in USA, I think. Avoid electronic timers and geegaws you don't need.
Dec 22, 2007 | Kenmore Elite 45986 Front Load Washer
3 audible beeps every 20-25 seconds
Try unplugging the washer for about 20 minutes then plug back in and use. I have found that this actually works! The only thing I can figure out is that it takes time for the electronic control to clear. If that doesn't fix the problem I would call sears tech since it is less than a year old. They have a 1-2 year warranty.
Dec 21, 2007 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore 22422 Top Load Washer Logo
128 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
