Question about Microwave Ovens
Durabrand stainless steel kettle-- I bought this kettle Jan.02/2010 I had problems almost from the start, it would not always shut off automatically, the way it was designed to do, after awhile I noticed the lid would not close completly, I had to do it manually, it would work as long as I made sure the lid was down, approx. a month ago I could not close it tight anymore, it would stay open about 1/2 an inch. then about a week ago it will not close at all, the lid stands straight up (vertical) I bought it at Wal Mart in Red Deer, AB. Store #3194, the Kettle is the cordless type, auto shut off, 1.2 liter capacity, Model #MK-12SOIC
  • busyvee1 Jan 05, 2011
    I have the manual
  • busyvee1 Jan 18, 2011
    Hi Mr. Guru, I do have the manual, but no phone number in it, the Gal at Wal Mart looked for the number in the manual also, could not find it, so she gave me the e-mail address
  • 2,069 Answers
Well this gets surely straight, the problem is the LID. if at the start you had actually considered having it replaced ( i mean the whole unit) this would have been ok assuming it had warranty. If the lid doesn't close completely, the auto off fails to engage definitely. a technician would dismantle unit, check whether the lid lock mechanism has broken or is simply stuck and get you a quick fix.
Regards
Posted on Jan 06, 2011
My GE stainless steel 1100 watt microwave starts beeping out of the blue and the display panel shuts off and when I open the door it resets itself and then starts to beep when I close the door again.
Try removing the power cord for about a minute, push all the touch pad 'buttons' and then plug it back in. If this doesn't work it sounds like you may have a bad door interlock switch or a bad PCM .. Good luck !
Feb 11, 2015 | GE XL1800 1100 Watts Microwave Oven
Led lights flickering
It has nothing to do with the microwave. Unfortunately, it sounds like the LED bulbs are defective and should be replaced.
May 15, 2017 | Microwave Ovens
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
We have a sunbeam peace and quiet kettle ke7500s it is approx 3months old. When we reboil the water there's always a tainted water taste in the tea and coffee .The taste is so bad we tip out the hot...
As you know friend, some water when it is boiled it really taste bad so I suggest use a water purifier to filter other out dirt, dust, other particles in a water street supply. Sure when you drink the water (not boiled) it doesn't taste bad, that's normal because we can't distinguish it easily. Also try to clean your kettle using baking soda it will eliminate tainted taste.
I hope my advice help you with your problem.
Mar 23, 2011 | Microwave Ovens
How to clean a kettle thats been cooked dry on the stove. Bottom has been discolored!
It depends on what material the kettle is made of. If it is aluminium you can only really scour it with steel wool and abrasives. It it is stainless steel, there are chemical cleaners that are available. These are acid based and the kettle can be left with the cleaner in it - follow the instructions on the container. The aluminium instructions will also work, but the chemical is less work although a bit of follow-up hand cleaning may be necessary.
Mar 19, 2011 | Microwave Ovens
I seasoned my new stainless steel skillet in the oven now I have built up oil stuck to the sides inside the skillet. How can I remove this without damaging the stainless steel finish? HELP!
You only need to season a cast iron skillet, not stainless steel. Soak it in hot soapy water and use something like a mister clean pad to clean it.
Dec 07, 2010 | Microwave Ovens
I bought a Bellini electric cordless kettle about three months ago from Target and now the lid won't shut, hence the kettle won't stop from boiling. What do I do - is there any guarantee?
i brought a belline kettle from target 2 months ago and now the lid wont shut where would i find a contact no for the company as target wont issue me a new one and i dont have my reciept after all who would have thought it would be faulty after 2 months
Aug 09, 2010 | Microwave Ovens
Amama 2.0 Cu ft. Radarange Microwave model# UXA3036BAB
This model does not list Stainless Steel as a feature. Stainless Steel is used in the interior (CAVITY) of a Microwave if it is a Combination Convection/Microwave Oven. The Convection Oven can reach temperatures of 400+ degreesF. This Temperature would MELT the paint off a painted interior.
Stainless Steel can be tested with a Magnet. It will not be attracted or "Stick" to Stainless.
Hope this answers your concerns!
Thanks!
Feb 05, 2008 | Amana ACM2160A Microwave Oven
Stainless Steel Kenmore Elite 36 in. 2.0 cu. ft. Microhood Combination Model 63763
Generally the F9 code indicates a problem with the door latch (usually upper) or with the control board. You can do a Google search for my text file "doorsw.txt" to help you diagnose and repair door switch trouble. BUT - since it always stops at 53 seconds, that leads me to think you have trouble with the control unit (circuit board / controller assembly). Once you read and digest the info on door switches, please feel free to do an updated post and I'll be happy to help you further. It may be corrupted ROM in the control unit. But let us know what you find out. - online they call me "William E. Miller, AS-EET"
Oct 15, 2006 | Kenmore 63763 Microwave Oven
Microwave Ovens Logo
124 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
