Question about Sony KP-51HW40 51" Rear Projection Television
I turn on my sony TV and it goes straight to blues screen. model number is kp-51hw40
    Top Expert:
  • Sony Master
  • 14,553 Answers
These sets have a history of bad picture tubes, the blue is most common, there is a way to without replacement of any parts to attempt to correct this.
you have to remove the entire grill on the front below the screen; it is usually held in either by two screws at the front (under little plastic caps) and or screws on the back on either side.
The grill will pull out and is engaged with large plastic tabs at the top; with it out since the front keyboard is mounted into it you lift and tilt it to the left. Remove the inspection plate behind it: look for the screen/focus block (see attached photo) and note the six controls: three are screen and three are focus----do not touch the focus ones.
They are usually marked (may be hard to see: r,g,blue) You want to locate the BLUE SCREEN CONTROL and with the set on on a unused video input turn the screen control SLOWLY (usually to the left) until you see no blue in the background; if you do it correctly all you should see is the Video 1 etc.
The idea here is to lower the blue screen setting just slightly-if it works you may only be buying some time as these sets are prone to problems like this.
I have done this several times and many see a few more years of use before they have to be replaced.
Let me know before you attempt this if any questions.
SD TECH
Posted on Dec 31, 2010
Sony television,model number KP51HW40,serial number 9026465,the problem is turn on the tv within in 30second the screen come to blue but sound is coming,no picture
If you are saying it goes to a bright blue screen I can tell you what to try.
This model has a history of bad picture tubes--red,green and mostly blue.
The blue screen can be turned down and I can tell you how.
The way you will know if this is your problem is take the set to a unused video input--all you should see is video 1 etc in green; if you see blue with or without trace lines you have the problem.
Let me know what you find and if so I will tell you how to adjust the set manually to try to correct it.
SD TECH
Aug 17, 2010 | Sony KP-51HW40 51" Rear Projection...
Screen turned orange, heard a sizzle sound tv
A capacitor has burned out. It may be on the motherboard or power supply.
Jul 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Screen shakes / jumps vertically on my Sony KP-51HW40
The jitter is called a vertical sync problem. The problem is on the "A" board. It can be replaced or rebuilt but will be quite expensive to service.
michtech
Feb 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Blue screen
This is easy to fix, pull off the front grill and turn the bottom left trim pot anti clockwise until the picture comes back. I am asuming the picture there and then it fades to blue. There is a step by step instruction on how to get the whole thing apart http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 15, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-51HW40
sounds like the tuner may be going out on the set.
Aug 10, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony kp-51hw40
Bad blue CRT................common problem.............T.
Dec 02, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
80 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
