No reverb Hi robotek, I have the same problem as hoopnholler. No reverb. I accidently plugged the footswitch into the extra speaker output, but the reverb seemed to work for about a day after that. Did you mean replace the reverb tube as shown in the schematic? I noticed that it is not golwing? Should it be? Thanks
  • 1,512 Answers
Hey mate
Dont think the wrong plugin hurt you. Is just the fickle finger of fate pointing at yo:)
All tubes should have a glow in them, the smaller ones can be a bit hard to see at times. A way to check is carefully check if it is getting hot, or at least as hot as the others. It can sometimes be a crook valve socket also. Depends on the age of the beast :) A bit of a wriggle, or a reposition in the socket can bring back the heater to one that is out from a dodgy socket. Only long term solution to a faulty socket is to replace it. I have a tiny file round that I clean em out with, but once they are crook, they give trouble. Good luck, hope you get it sorted. Let me know how you get on. Cheers mate!
regards
robotek
Posted on Jul 08, 2008
No reverb on my fender ps 160 Vocal amplifier
Here is a link to the schematic drawing
http://www.prowessamplifiers.com/schematics/fender/ps160.pdf
items to check are
1-the footswitch and plug
2-the reverb unit ,usually found at the bottom of the box
3-the reverb unit is plugged in to the amp
4-V6 a 7025 valve
5- the reverb switch is in the on position
Hope this helps
Len
Oct 14, 2014 | Music
How can I fix reverb?
Either the spring driver circuit blew or the SPRING INSIDE BROKE.
You gotta get in there. Take out the spring unit and check if there is a tensed spring in there. If so, check the connectors. Also check the footswitch plug in the back of the amp, plug and unplug a cable several times, sometimes it becomes dirty and does not let signals through. You can check if the reverb has no drive by tapping the spring while the amp is on and the reverb volume is up. If it sounds, your reverb is fine but not receiving input. That would be the driver circuit. Take it to a Tech and explain.... GOOD LUCK !
Apr 30, 2014 | Stagg 40AA R 40W Acoustic Guitar Amplifier...
Latency and reverb
Is the reverb caused by picking up the speaker output? You can't have a monitoring speaker feeding back into the microphone.
Apr 10, 2014 | Samson C01U - USB Studio Condenser...
Just got a new Marshall DSL40C. The reverb does not work on either gain control or with the footswitch. Why?
Nothing wrong with the amp. Google it- these amps have extremely weak reverb. All of them are the same. It's the one weak point about these amps. And I love mine. I mic it when we gig. Sounds awesome both clean and driven. But you'll have to get a separate reverb pedal if you want "girl crush" or "pipeline" reverb. Don't listen to the above posters. It's the way these amps are.
Nov 30, 2013 | Marshall Music
Can I use a footswitch for the reverb, to allow me to switch it off when talking ON MY Behringer Xenyx 1202 FX
Sorry, the Xenyx1202FX does not have a footswitch input. I would suggest if this function is needed to use an external FX unit which has a footswitch input.
Apr 26, 2011 | Behringer Xenyx 1202 12-input 2-bus Mixer...
Hot rod deluxe reverb is on today tommorre it is off ???
Without more info can't be much help. IF you are using the foot switch, poor contact of the plug AND also of the switch contacts of the footswitch jack will lead to intermittent reverb. There are MANY components that can cause the problem, including some may be temp sensitive... you need to characterize what MIGHT be changing in the environment. Also does vibrating the unit cause any change? You could even have a loose connection or bad cables that goes to the reverb tank...
This may take electronic test equipment to find the cause. COuld be failing component, crack on the circuit board, bad connector, cable...
Feb 12, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Footpedal for a Fender Princeton 112 plus amp
This one SHOULD work... use a plain 1/4 inch speaker cable to connect to the amp.
http://guitars.musiciansfriend.com/product/Fender-FM65DSP-and-SuperChamp-XD-Footswitch?sku=482846
Please note that information is sparse...
I would recommend calling Musicians Frien.com or Same Day music.com and have them verify if this will work.
Sep 02, 2009 | Fender Audio Players & Recorders
The footswitch for bugera 6262 valve amp seems to have a logic problem. The clean channel leaves 'lead and reverb' leds lit on footswitch, pressing 'lead' lights the crunch channel on the amp... and reverb...
Hi ! Check and make shure that the cord conections between the pc board on the backplate of the amp to the logic board are firmly pushed in there slots.
Good luck , Stefan from Sweden
Aug 18, 2008 | Audio Players & Recorders
Further musings on the Fender Amp no reverb problem
Hi, sorry for the delay. Sounds like a faulty cable, or the termination at the jack plug is faulty. These can create the problem you have. What model do you have again, don't remember getting that from you.
cheers
robotek
Jul 08, 2008 | Audio Players & Recorders
Fender deluxe reverb
Hi Hoopnholler
I would start by changing out 12AT7 (V4), is a common buffer stage to the vibrato and reverb audio path. If you have trouble identifying it, you can just swap out with a known good tube and see if it resolves your problem.
If that does not help, then time to go see an amp doctor. If youy are inclined. here is a circuit diagram that you may find useful in faultfinding the problem yourself.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 16, 2008 | Audio Players & Recorders
56 people viewed this question
 Grubhead
Grubhead
