Question about Jacuzzi Amiga, Soaking Bathtub with Integral Skirt - T715
How do you remove the front access panel to check for leaking?
  • 83 Answers
Should be able to either push down or up on skirt..has clips that hold it together bottom or top>>are longer shorter to allow movement
Posted on Dec 31, 2010
Do I access the tub area from the front panel or the top?
The 5500 Neptune washer and all predecessors are accessed from the front. by removing the 2 hinge screws, and the opposite 2 screws. The front goal post panel can then be removed, then the door can be lifted off. Maytag made a 1 piece tub and a removable front tub cover. Once the tub cover is removed by pulling all the tension clips you can remove the stainless spin basket one of 2 ways, either remove all 3 of the basket tumblers, then the 3 basket bolts, then the basket can be removed leaving the spinner support behind, or you can remove the rear panel, then the main pulley, then tap out shaft with a 2X4, this will remove the basket and spinner support together. You have not described the nature of your leak. Pleazer Appliance...
Apr 27, 2014 | Maytag Neptune MAH5500B Front Load Washer
Water leaking during wash cycle. How do you get access to inside
I use a putty knife about 2" inward , between the top and the front panel on each side . Give a good hit on one side while slightly pulling the front panel forewafd . Then do the other side . The front panel tilts foreward and hinges on the bottom with tabs . Then lift to remove .
Aug 02, 2010 | GE WBSR3140DW Top Load Washer
I have LG WD -1050F Intellowasher 7kg front load washer, while operating time getting water leakage under front door. need solution.
The problem is due to the rubber boot is been torn that is causing you the leak. You have to check the rubber boot for leaks by removing the clamp assembly that secures the rubber boot to the outer lip of the door opening. Peel off the rubber boot then inspect it for any holes where it may be leaking. The rubber boot in your washer can be accessed only when you remove the front panel. This requires the removal first of the top panel then the console. Also check your inlet hoses on the outside of machine, also check the connections inside the panel in back.
Thank you !!
Jul 26, 2010 | LG Washing Machines
Leaking water from the front
Thank you !!
Jul 06, 2010 | LG WM-2277HW Front Load Washer
LAT 7793 ABL model number. Washer leaking during fill...? a seal or gasket but not sure how to remove the spin bars to access it
On Your washer to locate a leak, remove the front panel first. Should be two clips at the bottom of front panel, use a putty knife to pry them down while pulling lower of front panel forward (older models used two screws right through front panel on left and right sides). After getting both lower clips loose, pull bottom of front panel forward to remove from top.
Set front panel aside and then use a 3/8" socket or nut-driver to remove two screws (one each) in the front right and left corners that secure the top to the side panels of the washer (inside in front corners going upwards). After screws are removed slide machine away from the wall about 8-10" and lift front of top up. Will pivot up like the hood on a car. This will allow you to examine machine for leaks.
Let me know when you come up with leak location if you need any more help!!
Jun 30, 2010 | Maytag LAT3600A Top Load Washer
Leaking water from my lg front loader during washing cycle- wm2487hrm
Thank you !!
Jun 13, 2010 | LG WM-2277HW Front Load Washer
Whirlpool duet ghw9100lw
You should be able to access the water pump with just the removal of the lower front panel. Once there, check for leaks by running the appliance.
Apr 13, 2010 | Whirlpool GHW9100L Front Load Washer
Machine leaks when clothes are washed but not
this could be a simple issue or a severe issue.
if you feel adventurous disconnect unit, and remove Rear access panel. inspect the rear bearring at the pulley, check for oil leakage and water residue. if there is water around the bearring the unit requires an overhaul. if nothing you should be ok.
it could be a disconnected vent at the top of the machine.
remove front access panel and inspect all rubber boots and connections for water.
this is best done just after washer has leaked, inspect where water is comming from.
there are many things that could be causing this.
Jun 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
Leaking
You will need to determine where the leak is coming from, you will need to remove the front panel to investigate, using a flat blade insert between the joint on the top and front panel approx 4" in from each side to release the clips, the top cover will now lift and hinge at the back. Remove two front panel screws, which are now accessible and remove the front panel by lifting off the bottom clips.
You should now be able to see where the leak is coming from and repair as necessary.If you put the top down you can run the machine without the front panel.
The sqeeking could be a wet drive belt.
Apr 19, 2008 | Maytag PAV2300 Top Load Washer
Jacuzzi Amiga, Soaking Bathtub with Integral Skirt - T715 Logo
371 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
