Question about Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2 Inch 15 Gauge Finish Nailer
Hello I have an old Senco MAX S10 that I need Parts for It is leaking air out the back vent hole Whewe can i buy parts in Alberta or find a parts manual Tks. Bob
    President:
  • Senco Master
  • 1,388 Answers
Best place/most complete listing for Semco parts is:
http://www.juldan.com/partlinks.html
Good holiday
Posted on Jan 01, 2011
Stapler leaks ouy of top
Try oiling it first. If it still leaks I would check the seal (reference #11) on this parts diagram.
http://www.ereplacementparts.com/senco-sns41-nailer-parts-c-117621_117622_117782.html
Mar 07, 2012 | Senco SNS41 16Ga Stapler 1" 2"
I have a senco coil roof nailer that all of a sudden is leaking air big time and will not coil and fire nails. What parts do I need to replace.
depends on where the air is leaking from. If you go to senco.com and type in your model number you can look at a breakdown and they will list the rebuild kits specific to the leakage, they make an upper o ring kit and a lower kit for this problem. Let me know if you need more assistance or where the air is leaking along with the model number and I will find a number for the rebuild kit. Also the senco kits have detailed instructions on how to install them.
Apr 04, 2011 | Senco Tools & Hardware - Others
Senco sns40 stapler replaced all o rings still leaks air. Even seals in trigger assembly. Leaks out the exhaust port.
Air leaking thru exhaust on sns40 gun is indication of pinhole in rubber diaphragm of firing valve (part #BA0120). This gun is oil-less type and will develope leaks if oil is used. Most likely need to replace firing valve to restore to working order. Parts are at www.toolpartsdirest.com. Good luck
Mar 11, 2011 | Senco Air Tools & Compressors
Air tends to leak near trigger of my senco sls15 1/4" crown stapler . how can i stop it?
You have worn or broken o-rings/seals inside the gun. You need a Senco repair kit YK0393. Senco doesn't make them any more but there are still a few to be found on the internet. If you can't find one, go to the Senco webpage, find the parts breakdown for your gun and order all of the o-rings, seals and gaskets and rebuild your gun.
Feb 09, 2011 | Senco Finishpro 15 Finish Nailer & Sls15...
Do i need to buy piston driver assembly or can i by just the driver blade
These new Senco FinishPro tools are chinese made and unlike the old US made tools, you need to buy what's termed a 'piston driver unit'. It should be fairly cheap though, compared to old Senco parts.
Jan 17, 2011 | Senco Finishpro 15 Finish Nailer & Sls15...
I have some air nailers and staplers that have some leaks and aren't working properly. I would like to try rebuilding them, they are bostitch, paslode, and senco. I have found the rebuild kits for trigger...
The kits for the senco guns, have all the o-rings and seals needed to stop most leaks, no hard parts. You have to replace all of them, no oil is needed, but it needs to be clean, some have little tubes of grease for the o-rings. I'm sure the other guns are the same way. Some of them will give you a fit. I had a senco sfn1, totally rebuilt, still leaked, tried it again, still leaked, called senco, they said send it to us, they fixed it for free, but never said what the problem was. Some times the triggers go and you end up building the whole gun for nothing, and the trigger still leaks, they are the toughest to spot. I have seen a lot of complaints about paslode. We tried them all in our shop, and the senco was/is the best, So we fazed out all the other guns and kept the senco, so all the nails were from 1 dealer, all the parts, we weren't looking all over town for a box of staples.
Feb 23, 2010 | Stanley Air Tools & Compressors
I just rebuilt my Senco SN4 nail gun because it leaked air.
I think that you are referring to the firing valve and no it should not be split. I suggest going to Senco.com and typing in your model number fora breakdown for this tool. They offer different kits for various failures. Let me know if you need more help
Nov 23, 2009 | Tools & Hardware - Others
Pneumatic stapler leaks at the top
your problem is you have blown a seal. On some of the cheap chinese guns, it might be a flat gasket instead of an o ring.
May 25, 2009 | Air Tools & Compressors
Senco sn2 air leak around out top only when the trigger is pulled
There is a cracked seal on the firing valve. It looks like it cant be replaced but it can. Look in your parts breakdown .It seals the firing valve to the cylinder
Apr 08, 2009 | Air Tools & Compressors
Senco SLP20 not working
Senco makes a line of nailers including the slp20 that use a firing valve (part # ba0119) that fires piston when trigger is depressed. These guns do not use oil because the oil will swell the rubber parts in the valve. When the rubber swells and tears slightly, symptoms that you describe will develop. Also remove the cylinder and look for cracks and make sure that the lower oring (LB0030) is in place and that tiny vent holes are clean. The lower oring is the checkvalve and causes the piston to retract. Use only the slightest bit of silicone lube on orings. Parts are available at www.toolpartsdirect.com. Good Luck
Jan 22, 2009 | Senco Fastening Systems No.43OOO1N SLP20...
Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2 Inch 15 Gauge Finish Nailer Logo
107 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Trippy Tripp
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
