Question about General Electric 27956FE1 Cordless Phone
My GE photoframe phone has a blank screen - General Electric 27956FE1 Cordless Phone
Will I need a cable for my Philips PhotoFrame to conect to the computer?
No, the Philips PhotoFrame has a USB flash drive connector, you can plug-in a flash drive and transfer the pictures from that. No cables needed.
Jul 26, 2010 | Philips PhotoFrame -10 Digital Picture...
The photo slide show is now blank. I have a GE model 27956 DECT6.0 Cordless Handset with Caller ID & Slide Show. I can not view or add new photos to the slideshow. I pushed the reset button, but it...
1/15/09
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
You can do this w/o the phone cord attached.
Dec 30, 2009 | GE Lands Phones
GE photo phone. Phone works. Photo frame was blank. 0 pictures
Remove the battery, unplug the phone, wait 48 hours. That might fix it. Or just get a new phone, these are poor.
Oct 25, 2009 | General Electric 27956FE1 Cordless Phone
The screen is blank
I solved the problem by going to Sears at the Mall of America and purchasing another complete phone for $14.00. I figured it was faster and cheaper to do that.
Apr 10, 2009 | GE Thompson GE-25922GE1 Phone
Downloading photos from computer to phillips 8ff2fpb photoframe
Your PhotoFrame does not have internal memory acording to the Phillips data sheet, therefore you need to load your pictures directly onto a memory card (one from your camera will proabably work.) If that isn't convenient, you can generally get a good price on a SD memory card which is supported by your PhotoFrame.
If you wnat to transfer pictures from your PC to the memory card and have a card reader, you can transfer the pictures in Windows Explorier from your PC to the memory card and then plug the card into your PhotoFrame. If you do not have a card reader, plug the memory card into the PhotoFrame and connect it to your PC using a USB cable (you may have to buy one as acording to the Phillips data sheet it is not supplied.) When the PhotoFrame is pluged in it will appear in Windows Explorier as a new hard drive, and you can copy your pictures to it.
I hope this helps,
Mike
Jan 03, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Copy photos from pc
Look for an option when you open photo manager that says upload picture. Browse the locations then choose my computer, pictuers and click open the picture that you want in photo manager. Other wise, try to put/copy the picture in a new folder in you computer, then click cut and paste to photo manager.
Artgirl
Jul 20, 2008 | Philips 9FF2M4 9" Digital Picture Frame,...
Dect6.0 27951 GE phone
It sounds like the battery may be defective, since it is clearly not holding a charge like it should. If it is still under warranty (which it likely is having only purchased it in March), then you would first want to contact GE for assistance. They should be able to help you with replacing the battery or the handset if that is determined to be defective.
Jul 01, 2008 | Uniden Cordless Phone
Blank screen
I have model 27950/27951 and I have a blank screen too. It' frustrating. Just got the phone in March and it started doing this last week. Love the phone, BUT! dadaslew
Jun 26, 2008 | Uniden Cordless Phone
I have GE telephone model # 21028GE3-A, and the screne is blank on both units. Instruction book said to replace the battery and charge it for 16 hours. the screen is still blank. What do I do now?
Did you get an answer to this? We have the exact same problem and cant find out manual. The screen is blank and after we had a power outage we were not able to get a dial tone. Without the screen we too are blank.
If you know how to get this thing started pls email us BaybeeDimplez@hotmail.com. Thanks
T
Jun 06, 2008 | GE Lands Phones
General Electric 27956FE1 Cordless Phone Logo
59 people viewed this question
Top General Lands Phones Experts
ka4iup
ka4iup
Are you a General Lands Phone Expert? Answer questions, earn points and help others
