Question about Thermador SC302T Electric Double Oven
Lower oven do not heat on bake or broil - Thermador SC302T Electric Double Oven
  • 1 more comment
  • resservicesl Dec 31, 2010
    First I never said problem started with self clean operation ,we always use the upper oven & to my knowledge the self clean was never used.
    2nd the thermo switch I already checked it's fine.
    About 2 years ago I replaced the main led board.
    display control works fine- clicks and the blower runs just no element heat.
  • resservicesl Jan 01, 2011
    the only apparent problem; no power to the elements----no codes showing
    where are the limit switches ?
  • Thermador Master
  • 2,605 Answers
Welcome to FixYa.
I`d start by looking for an over-temp cut-out tripped. Since this problem started following a self clean cycle, it leads me to believe it is just that.
Here`s what and where to look for for this,
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the lower door next to the lock latch assembly.
**Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...as shown here,
lower oven do not heat on bake or broil - macmarkus_192.jpg If indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...
Ultimately it could be a faulty relay board or related to the timer, but I`d start with the hi-limit cut-out tripped first.
Other than that if you call in a pro, I'd suggest you be sure they are an authorized B/S/H/ service provider ( B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens products ).
Let me know and I`ll watch for your reply and respond as soon as I can. Good luck.
Regards,
Macmarkus :)
Posted on Dec 31, 2010
  • 2 more comments
  • Mark MacDonald
    Mark MacDonald Dec 31, 2010
    Hello again,
    Sorry about that, my bad. I had your post confused with another...a negative side effect to my profession, many ovens on my mind lol :)...So let me back up then. I see you made no mention of an error code, so can you possibly elaborate on the series of events to this point ? The display control both ovens, so when you select either bake or broil there is so response ? OR it responds as if it where heating but never does ? Do you hear any "clicks" on & off, or the blower come on ( lower cooling fan ) ? I should also add, so I'm not assuming, you know their are seperate hi-limits for the upper & lower ovens ? and it wouldn't necessarily be tripped due to a self clean cycle...I've reset what where thought to be good hi-limits after power outages and such. Let me know and I'll try and help in any manner I can from here.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Hello again,
    I'm still wondering if you can address the other things I asked and mentioned...It's important to be clear as there are a great many things which can effect the functions you're missing.
    Any error codes ?
    You know their are separate hi-limits for the upper & lower ovens ?
    Thank you.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Jan 01, 2011
    Thank you for the response. Based on your reply ( no power to the elements no codes showing )
    I'd say it certainly sounds like the hi-limit has been tripped.
    **Again, Turn the power off at the breaker panel or power source...safety first**
    The hi-limit for the upper oven is behind the upper door latch grill, the lower is located in the same area in relation to the lower oven as shown here...
    You should be able to access the lower one by way of removing the grill screws between the upper and lower oven, as shown here...careful not to pull the wires off the door switch, or mark them, take a picture etc.
    Once you've pushed the hi-limit to reset, give it a try and let me know the results. If it doesn't resolve the issue, you'll need to check the thermostat itself.
    1) You can perform this by "jumping it out/by-pass it ( for test only ) or with the aid of an ohmmeter...Set the ohmmeter to Rx1 scale.
    2) Remove one wire, doesn't matter which one.
    3) Touching the meter to the leads should move the meter showing continuity.
    4) If there is no reading, remove and replace the thermostat. Part number 1433863, available at "repairclinic.com" for around $20USD and includes what is shown here...
    I've got my fingers crossed for you. Good luck. I'll watch for your post.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Don't know why my first image didn't go through. Hopefully it works this time.
    This is what you should have seen...
    Macmarkus :)
fridgetech
  • 473 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Posted on Nov 11, 2007
watugot
  • 290 Answers
SOURCE: OLD GE Wall Oven doesn't heat properly
On these older ovens ther is usually always 120 volts on the elements at all times.
If you check across the element ends with it in bake you should read 240V. If not, there is a problem with the control. With the voltage drop you describe, it sounds like you are losing power on one line of voltage coming to the element.
Post back to let me know what you find out or if you have any questions.
Posted on Nov 24, 2007
  • 22 Answers
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Posted on May 13, 2009
  • 3230 Answers
SOURCE: GE JTP 1580W288 Set oven to Bake, switches to broil at bake temp
The F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
How to remove and replace the temperature sensor. In most GE ovens, when you open the door, you'll see the rod-shaped temperature sensor sticking out of the back wall at the upper left. It's about six inches long and a bit more than 1/8" in diameter, held in place with two screws.
Turn off the circuit breaker (built-in ovens) or unplug the range before attempting the replacement.
The replacement sensor will come with instructions, but basically it's a matter of removing the sensor, pulling out the wires to where they are connected and disconnecting them. You may have to snip. The replacement sensor will come with high-temp wire nuts to hold the new connection. Polarity doesn't matter; it's a straight resistance thermocouple. Hook it up, be sure you poke the connections back far enough so that they're on the other side of the thermal insulation and not resting against the back of the oven.
If you continue getting the F2 error after replacing the sensor, then the problem is likely in the control module - this is the circuit board behind the keypad and clock.
You'll need to remove the decorative bezel to get behind the control panel. Remove screws and set off parts in order - it's not complicated. Once the bezel is off there are two more screws that hold the panel in place. Then you can lift the panel up about a half inch and pivot it forward toward you. You'll see a bunch of wires going to a circuit board.
On the panel you will notice some black plastic boxes that say "Potter & Brumfield" on them. These are relays. Check the relays - slide the black plastic cover straight up to expose the coil and the contacts. The coil, when energized, closes the contacts - look at all the relays. You can manually close the contacts with your finger (be gentle). If the contacts of one of them are stuck, they might be welded together. You can fix the problem by prying apart the welded contacts gently with a knife blade. Take some time to gently polish the relay contacts with a folded bit of fine grain sandpaper - this will get some more life out of them. Be gentle and careful - the relays aren't complicated but if you bend the contact or rip it out, you'll have to replace the controller, which will set you back a couple hundred dollars. If you unstick and burnish the relays, they will probably eventually weld together again as the rough spot will spark, but when you burnish them with sandpaper they should be good for some more life before they need to be replaced.
If the problem isn't the temp sensor or welded relay contacts then the problem is obviously somewhere else, but temp sensor and relay contacts will account for the lion's share of F2 errors.
Once again, be safe, be careful, be gentle. Ovens are not very complicated and they're tough, but always exercise care. Always disconnect electricity before messing with them.
good luck,
Posted on Jun 28, 2009
Bake and broiler element come on when bake is selected. Why?
Understand that I am not a professional, so this answer is subject to revision by someone who is more knowledgeable.
Where I live now I'm on Natural Gas, but in the past I've had electric stove/ovens. Based on my best recall the situation you describe is NOT abnormal.
When in the Broil mode, the Bake element is NOT on, but the Broil element is on FULL-bore to provide that strong radiant heat required for the Broiling process, AND for the good browning /crusting of the product being Broiled!!!!!
On the other hand, when Baking, not broiling, IF the Broiling element were on high it would provide too much radiant heat to the top of the product being Baked, and would burn the top.
While Baking, by energizing the Broil element in a lower power setting, the Baking process is enhanced with more heat by the assistance of the Broiler element, BUT without the hazard of burning on the top!!!!!
Hope this is right and helps your understanding.
Jan 16, 2015 | Ovens
Whirlpool oven WGP30801
Your model suggest a gas unit on gas units only bottom burner operates in bake on electric bottom elements heats broil cycles.
Feb 12, 2014 | Ovens
Whirlpool wgp30801
It is common to have the broil element pulse on or they will send 120 volts to the broil element to even the heat in the oven. Some ovens have a preheat function that will power the broil and bake simultaneously until the oven reaches temperature then the broil element will shut down. If they both stay on red continuously through the entire bake process then something is wrong. Probably a stuck contact on the control.
The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
My bottom oven ( non-confection) will not go on-it will just sat 100 degrees but won't get warm or hot. Top seems to be working fine. This started after I tried to use the self cleaning feature.
If broil and bake do not work on your bottom oven, it is probably your lower thermistor or control board. If the bake works but broil doesn't or broil works and bake doesn't, it is very likely your heating element. With an ohmmeter, the heating elements should be about 40 ohms. Much higher or lower signals a problem. If you suspect the control board is the problem, they can be repaired quickly and reliably at www.fixyourboard.com
Oct 11, 2010 | GE Profile JTP56 Electric Double Oven
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
Upper Oven doesn't heat in bake or broil. Lower /Ctrl panel OK
check to see if both ovens are the same circuit if they are you have a internal problem with your upper oven internal circuits or damaged wirering contact a qualified service tecnitian
Oct 07, 2009 | Ovens
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
Mar 12, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
304 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
