Question about Dryers
Kenmore electric dryer model 42890 wont heat up or stay running, is it thermister
  • 4 Answers
Dryers need airflow to work properly.
Unplug the unit and pull away from wall. Use flashlight, gloves, etc. as neccessary to inspect ducting for dryer lint. Remove any and all lint. Use a shop vac to clean vents and area. You might also need to use the shop vac to vaccuum out or blow out ducting.
Another typical solution is to replace the two thermostat controllers.
Parts available from Sears parts online for around $20 each.
Unplug Dryer and remove back panel from unit (8-10 screws.) A Simple pair of pliers will do the trick. Use shop vac to remove any and all dryer lint from inside unit. Thermostats look to be central right and easily accessible.
I am not a professional by any means, but I was a mechanical engineer on a nuclear submarine's reactor plant and I did work for 6 months installing and light repair on Maytag appliances.
I have seen several websites with info that supports the problem being the thermostats. My guess is that I would treat this like replacing headlights for your car. Never replace just one, because the older one will not be as bright and will most likely fail in the near future. For the low cost and high effort to go back and replace a second thermostat...you might as well replace both at the same time.
Posted on Dec 30, 2010
Our kenmore s70 dryer heats up but wont stay hot all lint is out,never a problem why wont it stay hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 03, 2011 | Kenmore 72822Gas Dryer
Dryer stops before clothes are dry...have to wait a few minutes before it will start again but only stays running for a short time.
if the dryer is running and then the motor stops when it gets hot it sounds like you have a bad motor.when was the last time you cleaned out the dryer and vent line?also i need the model number,on some kenmore dryers they have even heat that can cause this to happen if it's in your machine the timer will count down faster than normal and shut down ,or you could have a bad thermister so send the model number and i can check it out for you.
Mar 26, 2011 | Kenmore Dryers
The dryer will run, but it will not heat
That might be the thermister but it could very well be the element or one of them safetys on it is blown due to blockages
Sep 02, 2010 | Kenmore Elite HE4 Electric Dryer
How do I remove the heating element from my Kenmore 65962401 dryer?
Remove the service panel bottom front and the element will be on the right hand side. The element yanks out of its housing.
9324bf1.jpgThis video shows how to replace the thermister. The element is directly to the right of that.
Here is an older model like yours:
Aug 28, 2010 | Kenmore 659 Electric Dryer
The dryer timer will not advance in permenent press section of the dial. it works correctly on all other sections. i replaced the timer and the problem is still present
could you send the model number and is it gas or electric?when you have it on permanent press is there heat?usually the dryer heats,the heat shuts down and the timer moves,timer stops and the heat comes back on.could have a bad thermostat or thermister but i need the model number to see what is in your dryer
Jun 12, 2010 | Kenmore Dryers
Electric dryer only heats occastionally
Could be a circuit breaker getting hot an opening on the heat load side
or it might be a faulty control thermostat or thermisterf1ba79e.jpge295fb2.jpg60438dd.jpg
May 08, 2010 | Kenmore 62882 Electric Dryer
Dryer not Heating
Take the bottom front panel off and the thermal fuse is mounted on the blower duct near the thermister
Jan 18, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore electric dryer no heat
Test for 240 vlts in the back of dryer while the dryer is running.It can heat the first time but ounce dryer is under a load it can loose the voltage. Have you tested voltage to the thermistate while dryer is running?
Jul 25, 2008 | Dryers
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
