Question about Ultra 3K RazorBook 400 CE Notebook
"3K computer razorbook not able to get online.
Tip
How to obtain public IP from Time Warner
<p>There are two basic types of IP addresses of internet service providers (ISPs) to provide customers with Internet services: a dynamic address or DHCP and a static IP address. A static IP, as the name implies, uses the exact same IP, and you're online all the time. The DHCP IP configuration uses a "stack" of available IP addresses each time a modem is online and an IP address of the network of the ISPs is simply grabs the first available IP address from the stack. The IP configuration of DHCP, then it is very easy for a new public IP address from your provider at any time <br /> <p><br /> <p>1. Unplug the cable modem from Time Warner. Total count of 30 seconds and close. <br /> <p><br /> <p>2. Allow the modem to reboot every five minutes. During this time, goes through the boot cycle, contact your provider and ask for a dynamic IP address. <br /> <p><br /> <p>3. Navigate to the computer's IP Configuration Manager. For most versions of Windows, the easiest way to do this is to open the Start menu, click All Programs, then select "Command Prompt" from the "Accessories" menu (for future versions of Windows, you may need to the right button on the Command Prompt and select Run as Administrator "to show itself sufficient permissions on IP of the computer information). <br /> <p><br /> <p>4. IP address to test your computer by typing "ipconfig" and "Enter" Command to the numbers printed next to "IP address", like "IPv4 or IPv6 address." The number displayed on the public IP address of the DHCP as the modem from Time Warner will receive net. <br />
on Jun 22, 2011 | Computers & Internet
I run the Scangear tool, but it cannot find the scanner, by accessing by web, or physically on the display; the device says that the scanner is ready. When clicking in the discover button, it finds...
what kind of cable you use? is the computer and the machine connected to a switch or to each other?
if it is connected to a switch try a cross LAN cable.
Nov 11, 2010 | Canon imageRUNNER C2620 Color Copier
Cannot connect to the internet wirelessly. says i
If you are getting invalid ip try the following:
  1. Click Start and type "cmd" in search press enter
  2. In the command prompt window type ipconfig /all
  3. Check the ipv4 ip address
  4. If you are getting an ip address as 169.254.xxx.xxx
  5. Go to device manager
  6. Uninstall the Network Adapter
  7. Reboot the computer
  8. Re install the driver for you network adapter if prompted
  9. You should be able to get a Valid ip address and get connected
If you have a pci network card installed
Try to remove the card and install it in another slot.
Hope you find this solution helpful.
Thank you for choosing Fixya.
Jan 22, 2010 | Acer 91.AB370.001 Network Adapter
IP ADDRESS IS WRONG CANT GET ONLINE
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
Oct 23, 2009 | E-Machines eMachines Desktop PC
Would like to view owners manual on 3K razorback 400 computer
Sorry.
Everything points towards the fact that no manual exists.
Suggest contacting the manufacturer directly to request one.
Oct 03, 2009 | PC Mall RAZORBOOK 400 Notebook
Says I have an invalid IP address
Go to control panel select network right click icon go to tcp/ip properties and choose get ip address automatically DHCP
May 01, 2009 | Gateway GT4016 Desktop PC
Internet connection
Here's How:
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically.
Jun 18, 2008 | Dell Inspiron E1505 Notebook
Ultra 3K RazorBook 400 CE Notebook Logo
70 people viewed this question
Top Ultra Computers & Internet Experts
just-ice
Alun Cox
ed_coyle
ed_coyle
Are you an Ultra Computer and Internet Expert? Answer questions, earn points and help others
