Question about AOpen 19" LCD
AOPEN LCD monitor
My desktop's LCD monitor goes off and makes a clicking noise and the power light blinks amber. Sometimes it displays but it seems like now it won't come on at all. I took it apart but I can't visually see anything wrong.
Thank you,
Chuck
  • jackr1111 Nov 21, 2008
    Monitor won't come on. Makes clicking noise. Light is green.
  • Angelo M Dec 12, 2008
    Same problem, I'm using the VGA cable (Not the DVI). It appears to happen when the computer sends the sleep mode signal to the monitor, the monitor will not snap out of the sleep mode.
    Another interesting problem is the power switch. Even though I press it, 9 out of 10 times it does not turn off.
    I've discovered if you plug this monitor in as a secondary monitor and in Windows you attach/unattach the screen a number of times it will eventually come back. It is taking longer and longer for it to come back though. Anyone got a permanent fix?
    Problem Solver:
  • 14 Answers
Hi
If you switch on your screen it just goes dead again. If this is the case then all you have to do is replace your backlights of your lcd. The backlight are florescent tubes Which are gas filled and they have a lifespan of plus/minus two to five years. Once the gas is depleted the backlights try to go on then switches off
This problem occurs alot on all different lcd screens eg. ibm, gigabye and alot of other name brands and even the cheapies. the backlights come in different lengths so you have to open your screen and remove them carefully so that you dont damage or crack the liquid crystal. i have been repairing lcd screens for a while and this is the problem most of the time.This also affects your power supply as the backlights sometimes arc inside and causes the power supply to act funny the reason for power light flashing
You can order the backlights from RS components. They supply and sell backlights if you wish to do it yourself
Glad to be of any assistance
Posted on Jan 10, 2009
Optiplex 755 blinking amber light, simple solution, I'm no IT professional.
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.A power supply or system board failure has occurred. Try to isolate the problem by removing or disconnecting all cards, i.e. video, sound cards and disconnecting CD/DVD and hard drives.
Oct 20, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
The on/off of pc monitor (LCD) is blinking.
Most LCD monitor (depends on the brand) power indicator light will either turn from Green to Amber, or flashing Amber, or flashing green, when it does not detect video signal feeding it. So it may be normal with your monitor. Are you haivng problem with the display? If it displays he pictue OK then there is nothing to worry about.
Apr 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
How to fix aopen F75PS Display Power Light Blinking, Display Won`t come on.
A blinking power light typically means there is no signal from the video card, so check the connections and try another monitor (or plug the monitor into another computer) first to see if the video card is perhaps the real culprit.
Mar 14, 2010 | Computers & Internet
I have an Acer AL1912 that when you plug in the ac, the green power light will blink for about a minute and a half then go solid. The backlight will come on and you can see a faint ghost of vertical lines...
If it is still in warranty call the manufacturer.
if not give more info elah4@zoominternet.net. May be somthing simple like a cable
shutdown computer unplug then disconnect the video cable on the computer from the monitor, plug monitor back in and turn it on, there should be a display that says no video source within a few seconds, if unit is working properly. shutdown and connect video again and then reboot computer. sometimes it just takes a compleat power disconect to reset things,
Jan 30, 2010 | Acer AL1912B 19" LCD Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Dell flat panel monitor -power button blinks green to amber - no
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 10, 2009 | Dell Dimension 2400 PC Desktop
LCD won't come on.
hi
Jul 08, 2008 | AOpen 19" LCD
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Power light going to blinking amber
Sounds like a problem in the monitor's power supply. This will need component-level troubleshooting.
Jan 01, 2007 | Videoseven R17PS 17" LCD Monitor
AOpen 19" LCD Logo
654 people viewed this question
Top AOpen Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
