Question about Colibri CX Gear Clip Watch
How to set alarm on Colibri CXGEAR Lock Clip Key Ring w/Watch Sport Design Digital Watch Compass Flashlight PWS095686
4 Suggested Answers
escapement
  • 2334 Answers
SOURCE: How do I change the date on a Colibri Pocket Watch?
Usually all quartz watches are supplied with calendar setting mechanism and it is very simple-
try to pull out crown and you will notice that there are two clicks,so, when the crown is pulled out to the first click, the date can be adjusted by the turn of the crown. When crown is pulled further out (second click)- the watch is in hand setting position and you can adjust time.
Did it help?
Posted on Dec 17, 2008
SOURCE: turn off the alarm
try pushing the two right hand side buttons at the same time until you hear a beep
Posted on Apr 26, 2009
dunnbiker
  • 8546 Answers
SOURCE: i have Timex Men's T45181
There are two ways to find the user manual for your Timex watch.
  1. Find your watch on the list below and click on the language link for your manual.
  2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table.
If you are still unable to locate your user manual, you may emailTimex Customer Service or call us toll-free at 1-800-448-4639
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Posted on Feb 23, 2011
Pro trek 3500 compass only going up 300 degrees. Doesn't reach 360 north???
THe PRO-TREK watch compass is very sensitive to nearby Iron (eg. cars, fridges, steamships, artillary canons, battering rams, guillotines, etc) and anything wearable or embedded in your body. I had to calibrate mine in the middle of a baseball field.
Aug 09, 2017 | Casio Digital Compass Twin Sensor Sport...
Can a cloth "sport type" watch band be used on a
mcdevito75 here, As lomg as the watch band, no matter it"s material fits the watch lugs and your wrist, any band can be used. Your answer is yes.
Feb 09, 2011 | Casio Pathfinder AltimeterBarometer...
What size battery do I need for armitron digital sport watch 40-8117 m-690
If the watch #/size is not printed on the back of the watch, you will actually have to remove the battery to figure out what size you need. Best regards.
Aug 21, 2010 | Armitron Compass Bezel Chronograph Sport...
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
How do I calibrate the compass on a Timex Adventure Tech Digital Compass wristwatch?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, please
Mar 14, 2010 | Timex T42371 Digital Adventure Tech...
How to set the compass on a casio SGW 100
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 24, 2010 | Casio Digital Compass Twin Sensor Sport...
How do I set alarm for Armitron All- Sport Watch #45/6975?
Click mode once then use st/stp to cycle trough the chime (which looks like a little signal) and alarm(which looks like a little flashlight) at the top.Note (you can have both on at once)
Oct 27, 2009 | Armitron Two Tone Sports Watch
Need a battery
we carry all types of watch batteries
if you are in chicago stop by at our store
at
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
312 641 7000
Aug 27, 2009 | Colibri CX Gear Clip Watch With Flashlight
Turn off the alarm
Apr 24, 2009 | Watches
Aspen watch
Setting my Aspen Digital Watch
Button designations:
(NITEGLOW) B C (START/STOP)
10:47
(MODE) A D (SPLIT/RESET)
To Set Time, Date and Day:
Press A 3 times; Seconds Flash; Set to 00 with C
Press D; Minute Flashes; Set Minutes with C
Press D; Hour Flashes; Set Hours with C
Press D; Date Flashes; Set Date with C
Press D; Month Flashes; Set Month with C
Press D; Day Flashes; Set Day with C
Press A to Quit
To Set Alarm Time:
Press A 2 times; Hour Flashes; Set Hour with C
Press D; Minutes Flash; Set Minute with C
Press A to Quit
To Set Alarm ON or OFF:
Hold D in to see Alarm Time and Press C to toggle Alarm ON/OFF
Operation:
Hold C to see Month and Day.
Hold D to see Alarm Time; Press C to toggle Alarm ON/OFF.
Mar 27, 2008 | JCPenney Armitron Sport Link Bracelet...
Colibri CX Gear Clip Watch Logo
53 people viewed this question
Top Colibri Watches Experts
NOEL
NOEL
Are you a Colibri Watch Expert? Answer questions, earn points and help others
