My printer keeps coming up with EL error - Office Equipment & Supplies
    Sergeant:
    Champion:
  • 217 Answers
It sounds like your printer isn't recognising the ink cartridge.
Reset the ink levels and this may cure it.
Posted on Dec 30, 2010
Me salta error de calor abierto en la impresora lexmark x215, quiero saber si sustituyendo el fusor se resuelve el problema o es otro el motivo del error
Si se obtiene un error de calor abierto, significa que la impresora detecta que el termistor no está conectado o defectuoso.
Si el problema persiste la unidad fusible se ha sobrecalentado y necesitan ser reemplazados.
Para obtener asistencia adicional, póngase en contacto con asistencia técnica de Lexmark.
Feb 21, 2011 | Lexmark X215 MFP All-In-One Laser Printer
QUE ES EL ERROR 1200?
Tienes que cambiar el tinte!!! El error 1200 es por el TINTE.
Jan 20, 2011 | Lexmark X4270 All-In-One InkJet Printer
Have an HP 8000s DESIGNJET an error 1290 keeps coming up when iniatialization please help
error 1290, simples de resolver, basta ligar a maquina com a tampa aberta, voltara a funcionar, depois tem q entra no menu t?cnico , e procura counter, e reseta all, esse procedimento zera o contador, mais explica??es msn: amigodanet1000@hotmail.com
Jan 14, 2010 | HP DesignJet 9000 InkJet Printer
How 2 unlock c 0500
on a c350:
1.leave the machine on and open the front door
2. locate a small rectangular hole inside the front dooron the bottom right side corner
3. insert a small object such as a small ball point pen to actuate a switch that resets the error code the screen will indicate door open when the error is reset.this is a fuser error code so if the error keeps coming back the fuser will have to be replaced
Nov 14, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Service code 990 savin 2545 copier
If changing the cylinder, developer and blade the problem is not solved, proves to resetear software pressing by more than 10 seconds the point (.) and the numeral (#) both simultaneously, until it is extinguished and it returned to ignite the machine, this resetea software. If the problem persists, then the problem can be in the hard disk, replaces hard Disk.
Si cambiando el cilindro, revelador y cuchilla no se soluciona el problema, prueba resetear el software presionando por más de 10 segundos el punto (.) y el numeral (#) los dos a la vez, hasta que se apague y vuelva a encender la máquina, esto resetea el software. Si persiste el problema, entonces el problema puede estar en el disco duro, reemplace el Disco duro.
Aug 03, 2009 | Ricoh Aficio 450 Copier
Erox dc 12 error 9-342
In Spanish
Quita la tapa de el drawer
Obseva la media lunita de el 2nd BTR Black & yellow Cheat el sw de la puerta Si no hace el intento de girar . Quita la tapa posterior y observa si gira el motor principal y el motor de el cilindro si no giran tienes un problema en la AC driver 5Volts o en los 24 volts verifica tambien los fuses de la PWB de interconexion y de la Ac driver suerte
Nov 12, 2008 | Xerox DocuColor 12 Printer
Getting error 0xc18a0206
Aquí es el contenido de la charla, espero que te ayuda también! Christina es la persona de soporte técnico.
Cristina: Vamos a realizar algunos pasos para aislar el problema y encontrar una solución para ello.
Christina: Por favor siga los siguientes pasos y que me haga saber el mensaje que se mostrará en la impresora.
Christina: A. - Mantenga pulsado el "*" tecla.
B. - Presione la tecla "#" y suelte ambas teclas.
La pantalla debe decir "Intro Especial clave Combo"
C. - Presione y suelte en la secuencia de "1", "2" y "3" botones.
CustomerName: ok
CustomerName: pantalla dice "apoyar" R0631M
Christina: Fine.
Christina: 2. Oprima y suelte el botón de flecha derecha hasta que la pantalla dice "Menú de configuración del sistema".
Christina: 3. Oprima y suelte el botón "Aceptar".
Christina: 4. La pantalla debe decir "estado de error de hardware". Si no existe ya, tecla de flecha a "estado de error de hardware",
Christina: 5. Oprima y suelte el botón "Aceptar".
Christina: 6. La pantalla debe decir "estado de error de hardware: Despejado. Pulse OK para borrar ".
CustomerName: yup
Christina: 7. Oprima y suelte el botón "Aceptar". Mensaje a los cambios "estado de error de hardware Resueltos. Pulse Cancelar para continuar ".
CustomerName: ok
Christina: 8. Pulse y suelte el botón "Cancelar" tantas veces como sea necesario, de modo que, o bien el "Bienvenido a Photosmart Express" aparece la pantalla, o, el "fallo del sistema de tinta" aparece la pantalla. POR FAVOR, NO intente imprimir en esta etapa.
CustomerName: ok
Christina: 9. Utilizando el botón de encendido, apague la unidad y desenchufe el cable de alimentación de la parte posterior de la impresora y la pared.
CustomerName: hacer
Christina: Fine.
Christina: 10. Espere 30 segundos para obtener el poder de vertido y, a continuación, enchufe el cable en la toma de corriente y, a continuación, en la parte posterior de la impresora
CustomerName: hacer
Christina: 11. Encender la unidad. La impresora puede mostrar mensaje "BOTóN PARA PODER UTILIZAR LA IMPRESORA SHUTDOWN" seguido de "Pulse OK para continuar". Pulse Aceptar. La impresora comenzará la "TEMNE UNA TINTA proceso de inicialización". Permitir que este proceso para completar y no interrumpir. Una vez que el proceso de inicialización se ha completado, la impresora imprimirá una página de diagnóstico.
CustomerName: hizo una buncha ruido, y no imprimir una página de diagnóstico
Christina: Bueno.
Christina: ¿Es todavía el mensaje de error que se muestra en la impresora?
CustomerName: No
Christina: Bueno.
CustomerName: debo intentar imprimir algo?
Cristina: Vamos a imprimir una página de prueba libre, para comprobar la funcionalidad de la impresora.
Christina: Pulse sobre el menú de configuración "todo en uno" luego desplazarse utilizando la tecla de flecha y seleccione la opción Imprimir a continuación, seleccione Informe de Autoevaluación Informe de ensayo.
Oct 22, 2008 | HP Photosmart C5180 All-In-One InkJet...
I-4208 DataMax printer
We had the same error after labels got wrapped around the feed roller. When we were called to investigate the problem, the fault error was there. After 2 1/2 hours of troubleshooting both on the printer and online we came across this page. I took the roll of labels out, cleaned the media sensor and re-threaded the labels. Well, that didn't work too well as I still had the same error. Since we have 2 thermals setting side-by-side, I opened up both hoods and noticed that the "green" slider just beneath the sensor was slid all the way in. On the other printer however, the slider was slid out until a white etched line was at the tappered endpoint of the sensor. I slid out the other printer that had my error, hit the feed button, and whaaa-laaa, the error disappeared. There are some minor distance feed that we have to reset, but it is up and running! I hope this may help you out in your situation too.
Aug 08, 2008 | Datamax I-4208 Thermal Label Printer
Oki C3530 MFP
Con el cartucho instalado en su posición, tiramos de él para arriba y sacamos todo el alojamiento del mismo. En la parte derecha del mismo hay un cuadradito con una ventanilla de plástico que debe estar totalmente liberada. El problema es que ésta a veces se queda medio tapada y el sensor no detecta el cartucho. Levantar ese plástico hacia arriba todo lo que se pueda ( con algo que tenga punta, un boli por ejemplo) y volver a poner todo el alojamiento en su sitio. Suele funcionar a la primera, y si no, apagar y encender de nuevo la impresora.
Jul 16, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
Toner sensor problems
sensor window on the drum is closed - or the r/h side of the printer has a sensor that needs cleaning.
Dec 24, 2007 | OKI C3100 Led Printer
29 people viewed this question
jasbo
jasbo
