Question about Maytag Dryers
I am getting no heat from my dryer. I have taken out the heat coil and did a continuity test an it checked ok. there is a sensor on top of the heat coil and towards the left side they both had continuity. what am I missing. is this the proper way to check these items
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 31, 2010
I have a beko dcu9330 dryer givin n heat. changed blown sensor and tested both sesors, still no heat, no power getting up to heater. whats next step?
Electric dryers have a heating coil over which air is drawn to heat it up. Unplug your dryer and use a continuity tester to check the heating coil for breaks. Attach one lead to one coil terminal and the other lead to the opposing terminal. No reading indicates a burned out coil (very common). All coils are replaceable.
Oct 22, 2014 | Dryers
My front load Kenmore Dryer tumbles and blows air but not HOT air to dry the clothes. We have taken off the vent from the back of the dryer and completely cleaned it and always clean the filter after each...
Hi cisdacbm...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure on the shaft and not plugged with lint.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Jul 07, 2011 | Dryers
There is no heat when my dryer is on so it takes forever for things to dry. We checked the element and it is good. Could it be a sensor?
Check your Wiring
wire is attached.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
For video and pictures on how to replace an element go to the following website:
This is a FREE answer, Please rate me
Apr 12, 2011 | Roper RES7646KQ Electric Dryer
My electric whirlpool stopped heating. i took the heat coil and the two sensors in, they said it was a sensor. i put the new one in and it worked great for fifteen minutes, then it quit. the electronic...
Check your Wiring
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
If it overheats the dryer will not operate properly.
It cannot be reset. A vent clogged with lint can cause it to overheat.
You can test it with an Ohm meter/continuity checker, if no continuity,
replace it)
For video and pictures on how to replace an element go to the following website, it will give you an idea what you are in for:
Jan 13, 2011 | Dryers
Whirlpool Dryer Model LER4634EQ2 starts and runs, but will not heat. Circuit breaker does not seem to be tripped, but has been reset anyway with no result. What steps should be taken next?
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
For video and pictures on how to replace the element go to the following website:
Dec 27, 2010 | Whirlpool Dryers
Everything works ok except my GE dryer won't heat up. Model number DRSR483GD2WW.
Check your Wiring
Dec 12, 2010 | GE DPSR483EA Electric Dryer
Dryer heats up ok but takes forever to dry anything
Check your Wiring
Dec 05, 2010 | Amana Dryers
My Bosch Exxcel dryer does not heat up, the drum turns but the exhaust air is cold. Is it the heating element or a faulty sensor
Could be either the heating element or the thermostat/s.
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
Oct 05, 2010 | Bosch Dryers
How do i get to the heating element of my dryer
Sep 25, 2010 | Speed Queen AES28AWF Electric Dryer
I have maytag bravos and doesnt blow hot air just cold . i checked went its ok . i think thats heat sensor ? located inside black plastic with one one terminal plog in ? im looking for replacment
Please rate me
Sep 18, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
