Question about Acer Aspire One PC Notebook
Stalls on boot up - Acer Aspire One PC Notebook
  • graeme ian hunter Dec 30, 2010
    at what point does it stall?
  • rrowles Jan 05, 2011
    Ok I held the "alt" through the entire process and it was not any help.
    In bios Ialso tried once again to load system defaults. If they in fact did load, it made no difference.
    Again, When I watch the files go by on a "safe ' start up- it always hangs on the same file.
    I hate being beaten- I am really at a loss here. Over my head, so-to-speak.
    Thanks for your patience.
  • Acer Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
Posted on Dec 30, 2010
  • 4 more comments
  • rrowles Jan 04, 2011
    Yep. I did all that and still no help. If I start the booting process and watch the files on the screen , it only boots a dozen of so files, and then hangs. And it's always the same file.
    Any ideas? And thanks for your suggestions!
  • Brian Sullivan
    Brian Sullivan Jan 05, 2011
    during the boot up proces hold the delete button to see if you enter bios
    also
    do this if you are willing to start from scratch
    turn Off the computer, now as soon as you hit the power button, keep on holding “Alt” key
    I do get into bios and did change to default settings bit the same problem persists.
    And, what does 'start from scratch' mean?
    Thanks bronk50 for your suggestions.
  • Brian Sullivan
    start from scratch means factory settings you will have to set your computer to your own personal settings
  • Brian Sullivan
    Turn Off the computer, now as soon as you hit the power button, keep on holding “Alt” key
  • graeme ian hunter Jan 05, 2011
    This is looking like there is corruption with the windows install. As this laptop does not have an optical drive, you may now need to perform a fresh install of Windows. This can be done by creating a boot disc on another computer and booting from a USB stick, external USB CDRom.
    The steps are a little complex and too much to type out so I include this link to see if it is of any help..http://komku.blogspot.com/2008/11/instal...
    If you can lay your hands on a USB CDrom, the baove may not be necessary, as you might be able to do a restore from the CDrom rather than a fresh installation
2000 ALERO STALLS AT TRAFFIC LIGHT , NEW SPARK PLUGGS AND BOOTS ALONG WITH NEW FUEL FILTER BUT DSTILL STALLS
Could be a dirty throttle body or a faulty idle air control valve.
Is the check engine light on ?
Sep 05, 2012 | 2000 Oldsmobile Alero
ASUS Eee PC 1001HA factory restore
start tapping f8 @ boot to see if you can get to boot menu, if it doesn't work then you'll have to get an external dvd player and boot from that to do a repair.
May 12, 2012 | ASUS Eee PC 1001HA, ASU......
I'm trying to install Vista for a friend of mine on his computer. It uses vista boot loader 2.1.1 (or something similar) The first time it will boot just fine - vista will boot after first start and...
one check the crack make sure it is for what your installing ( i mean ver and sp) if all else fail try a differant crack you know as well as i do they dont all work all the time and check you registry cant tell you here but look in registry file
Sep 24, 2010 | Computers & Internet
My server stalls in the middle of boot up.
The solution depends on exactly where it stalls. IF it stalls while booting the OS, either the OS files are corrupted so better try the recovery console or using the recovery CD.
Verify in the boot bios screen whether all the hardware are detected properly
Feb 12, 2010 | HP Compaq Proliant DL350 (345101-001)...
Emachine starts boot process but stalls, no beeps
most likeley if you see something on the screen but it wont boot it is a mem problem, does it load bios, if so it is prob not memory
Nov 17, 2009 | E-Machines eMachines Desktop PC
Won't fully boot. Get windows screen, then it stalls gray
reformated twice? have you already ran diagnostics on the hdd? check first the hdd thru diagnostics it might the hdd causing the problem. if no errors found in hdd make sure it was reformated as clean install. your hdd might have partition and just reinstalled OS on he same partition without deleting partitions. Try deleting partitions then create new partitions then reinstall OS.
Oct 21, 2009 | Dell Latitude D610 Notebook
Vista 64 - slow boot with WD MyBook attached
This is caused if there are any system files on your external drives OR if you have set the bios to be able to boot from usb devices
One or the other is where you need to look.
Aug 17, 2009 | Western Digital 320GB MyBook External USB...
Car won't Idle
do a compression test,if that checks out,oil gets in spark plug wells and sometimes not running on all 4 plugs pull spark plug boots and use paper towels twisted up and clean out oil around plugs and clean the end of the boots,
Mar 31, 2009 | 1996 Plymouth Breeze
E-machine
Try going to setup or safe-mode. The first boot display will say how to get to setup at the bottom of your display. F8 will get you to safe mode. Also please state your operating system. Steve Medley
Dec 15, 2008 | E-Machines eMachines Desktop PC
Acer Aspire One  PC Notebook Logo
107 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
