Question about AOpen 19" LCD
LCD won't come on.
My desktop's LCD monitor goes off and makes a clicking noise and the power light blinks amber. Sometimes it displays but it seems like now it won't come on at all. I took it apart but I can't visually see anything wrong.
Thank you,
Chuck
    Problem Solver:
  • 14 Answers
Hi
If you switch on your screen it just goes dead again. If this is the case then all you have to do is replace your backlights of your lcd. The backlight are florescent tubes Which are gas filled and they have a lifespan of plus/minus two to five years. Once the gas is depleted the backlights try to go on then switches off
This problem occurs alot on all different lcd screens eg. ibm, gigabye and alot of other name brands and even the cheapies. the backlights come in different lengths so you have to open your screen and remove them carefully so that you dont damage or crack the liquid crystal. i have been repairing lcd screens for a while and this is the problem most of the time.
You can order the backlights from RS components. They supply and sell backlights if you wish to do it yourself
Glad to be of any assistance
Posted on Jan 10, 2009
Optiplex 755 blinking amber light, simple solution, I'm no IT professional.
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.A power supply or system board failure has occurred. Try to isolate the problem by removing or disconnecting all cards, i.e. video, sound cards and disconnecting CD/DVD and hard drives.
Oct 20, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
My computer won't start up and is blinking yellow. How do I fix it?
An steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Nov 16, 2011 | Dell Inspiron One 19 All-in-One Desktop PC...
The on/off of pc monitor (LCD) is blinking.
Most LCD monitor (depends on the brand) power indicator light will either turn from Green to Amber, or flashing Amber, or flashing green, when it does not detect video signal feeding it. So it may be normal with your monitor. Are you haivng problem with the display? If it displays he pictue OK then there is nothing to worry about.
Apr 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
I have an Acer AL1912 that when you plug in the ac, the green power light will blink for about a minute and a half then go solid. The backlight will come on and you can see a faint ghost of vertical lines...
If it is still in warranty call the manufacturer.
if not give more info elah4@zoominternet.net. May be somthing simple like a cable
shutdown computer unplug then disconnect the video cable on the computer from the monitor, plug monitor back in and turn it on, there should be a display that says no video source within a few seconds, if unit is working properly. shutdown and connect video again and then reboot computer. sometimes it just takes a compleat power disconect to reset things,
Jan 30, 2010 | Acer AL1912B 19" LCD Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Dell flat panel monitor -power button blinks green to amber - no
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 10, 2009 | Dell Dimension 2400 PC Desktop
AOPEN LCD monitor
hi
This problem occurs alot on all different lcd screens eg. ibm, gigabye and alot of other name brands and even the cheapies. the backlights come in different lengths so you have to open your screen and remove them carefully so that you dont damage or crack the liquid crystal. i have been repairing lcd screens for a while and this is the problem most of the time.This also affects your power supply as the backlights sometimes arc inside and causes the power supply to act funny the reason for power light flashing
Jul 08, 2008 | AOpen 19" LCD
LG Flatron L1550S power light blinks green.
shorted components on the circuit. send it to a repair shop if you don't have experience on electronic troubleshooting!!!
Nov 27, 2007 | LG Flatron 995FT 19" CRT Monitor
Power light going to blinking amber
Sounds like a problem in the monitor's power supply. This will need component-level troubleshooting.
Jan 01, 2007 | Videoseven R17PS 17" LCD Monitor
AOpen 19" LCD Logo
261 people viewed this question
Top AOpen Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Gareth Cockram
Gareth Cockram
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
