Question about Samsung SCH-U450 Cell Phone
I can't get remember my security code to my samsung intensity 2. Is it the same as the voicemail code?
  • 903 Answers
Hi, it may be the same as the voicemail code if that's how it was set up. Generally, the default code is the last 4 digits of your mobile phone number. If that doesn't work, try 0000 or 1234.
Posted on Jan 21, 2011
How do I block at number?
You can block calls without changing your phone number. First, go to your phone`s menu. Then, click on Settings and Tools. Go to Phone Setting and click on Security. Enter your 4-digit code. (If you do not know it, it is the last four digits of your phone number). (Yes, you can change it). Next, go to Restrictions and click on Calls. You can change your Ingoing and Outgoing calls settings. You should see these three options, 1) Allow All, 2) Contacts Only, 3) Block All. Choose the one that best suits you and you should be set from there.
Read more: How to block calls samsung intensity 2 - Blocking a phone number on the samsung intensity ii cellphone ::
http://cache.vzw.com/multimedia/mim/sam_intensity2_grey/intensity2.pdf
Jun 22, 2015 | Samsung Intensity II
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
What is the default voicemail password samsung - verizon?
what you might have to do is contact your service provider
Jun 03, 2014 | Samsung Alias 2 SCH-U750 Cell Phone
Samsung Intensity - Sudden "Invalid Password" Error
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 07, 2012 | Samsung Cell Phones
I forgot my voicemail password on my samsung intensity
Have you changed it from the default? If not, it is probably either 0000, 1234, 1111, or the last four digits of your mobile phone number.
Nov 10, 2011 | Samsung Intensity II U460 Verizon
I forgot my security code to my Samsung Intensity phone and i cant do anything on it can u help me without me having to leave the house?
Hi, the security code is generally set up as the last 4 digits of your mobile phone number (unless you've changed it at some point).
Dec 21, 2010 | Samsung SCH-U450 Cell Phone
How do i retrieve voicemail from my samsung phone
Some variation on this with each wireless service provider (I have had 4 in the past 9 yrs).
Dial your own phone number from your cellphone.
when asked to enter your security code - enter 0000
then - you will be asked to change your security code....
Once done, you will now just dial your number from your phone, then enter your new security code.
That should do it (for Verizon, Alltell, AT&T, etc.)
Oct 14, 2009 | Samsung U900 Soul Cellular Phone
Need to listen to my voicemail but forgot the password
Just call Spint, they will verify who you are & allow you to reset the password without losing the messages. Good luck.
Not sure what you need the security code for the phone for but this solution will at least let you keep the voicemails intact.
Jan 30, 2009 | Sprint PCS Vision A640 by Samsung(r)...
Cannot access voicemail on Motorola Razr
If your wife never reset the codes when she used the phone, the "unlock" 4 digit PIN code is usually 1234, or sometimes the service provider resets it to the last 4 digits of your cell phone's number before sending it to you.
The SECURITY code is a 6 digit code which is set to "000000" when the phone is first sent to you and since your wife never used it that should still be it. I'd try entering 000000 for the "invalid security code" message you are getting and see if that does it. Some service providers may reset that security code before sending the phone to you too, so if any of those codes don't work you'll have to call your cell phone service provider to find out the codes. This info about all the codes was in my Razr V3 manual. Hope it helps.  If that does work for you and you can get into voicemail, then to reset the codes to your own personal ones go to ....Settings > Security > New Passwords and reset them.
If you get to the voicemail message screen and the message  stored there, (it's probably a message from the service provider) you have to call the voicemail number to retrieve the message, I just  press the keypad "dot" on the top right side under where it will say "call " and it dials & brings me to my voicemail.  The voicemail number should be stored in the phone, but because it was never set up you may have to call the provider to do so, I can't remember if it was already in there or not when I first set my phone up. Anyways......Good Luck & Happy New Year ; )
Dec 28, 2008 | Motorola Mobility RAZR V3
Samsung SCH-U450 Cell Phone Logo
319 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
